Civil Engineering Association Software Software Product Autodesk Products Autodesk Autocad Civil 3D 2021
 babakfeyzi
Romania
User ID: 177117
Threads: 15
Likes: 626 in 97 posts
Given Likes: 1392
04-16-2020, 07:17 PM (This post was last modified: 04-27-2020, 12:03 PM by rami1976.)
AutoCAD Civil 3D 2021
AutoCAD Civil 3D is the software of choice for anyone who is active in civil engineering. For each phase of a project is within AutoCAD Civil 3D to find a suitable job. Whether it is about the process of surveying inwinningen or the design of roads, sewers, embankments and other volume objects (wells, dykes etc.), AutoCAD Civil 3D provides the right features to make this happen. AutoCAD Civil 3D is a comprehensive solution within the civil sector, where both a software design and documentation, 2D and 3D data and powerful tools for BIM in processes are.
AutoCAD Civil 3D provides the functionality of both AutoCAD and AutoCAD Map3D and complements this with intelligent and dynamic models, an object oriented environment and functionalities, and reporting and presentation tools for civil draftsman or designer.
[-] The following 4 users Like babakfeyzi's post:4 users Like babakfeyzi's post
  β€’ mowafi3m, zrilek, PinkPant, oanm2000
 giovas
User ID: 8386
Threads: 17
Likes: 179 in 20 posts
Given Likes: 210
04-16-2020, 10:46 PM
[-] The following 6 users Like giovas's post:6 users Like giovas's post
  β€’ zrilek, Dell_Brett, PinkPant, oanm2000, rimrany, wchum
 babakfeyzi
Romania
User ID: 177117
Threads: 15
Given Likes: 1392
04-24-2020, 05:07 PM
Autodesk AutoCAD Civil 3D 2021.0.1 Hotfix
  β€’ zrilek, Dell_Brett, oanm2000, arspi
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1405
04-27-2020, 09:48 AM (This post was last modified: 04-27-2020, 09:49 AM by rami1976.)
Direct links :
  β€’ oanm2000, zrilek, Dell_Brett, mgdario, arspi
 rami1976
User ID: 34597
Threads: 355
Given Likes: 1405
05-07-2020, 09:33 PM
Autodesk Civil3d 2021.01 Hotfix (mirror to post no3 - direct link)
[-] The following 3 users Like rami1976's post:3 users Like rami1976's post
 babakfeyzi
Romania
User ID: 177117
Threads: 15
Given Likes: 1392
05-29-2020, 03:55 PM
Hi
Civil 3d 2021 last update
PHP Code:
https://nitroflare.com/view/B341DB48B3B4D01/sanet.st_C3D_2020_4_Update.rar
Mirror
PHP Code:
https://rapidgator.net/file/427e9c0187b9e7379cc7989a6e70213b/sanet.st_C3D_2020_4_Update.rar
[-] The following 1 user Likes babakfeyzi's post:1 user Likes babakfeyzi's post
  β€’ cheosmith
Threads: 1,118
05-29-2020, 05:49 PM (This post was last modified: 05-29-2020, 05:50 PM by BennyP. Edit Reason: N/A )
See Wikipedia.
Dyslexia is a learning disorder that involves difficulty reading due to problems identifying speech sounds and learning how they relate to letters and words (decoding). Also called reading disability, dyslexia affects areas of the brain that process language.
Civil 3d 2021 last update compared with
C3D_2020_4_Update
I am Own My Way signature is right.
  β€’
 rami1976
User ID: 34597
Threads: 355
Given Likes: 1405
03-07-2021, 10:47 PM (This post was last modified: 03-07-2021, 10:49 PM by rami1976.)
Geotechnical Module for Civil3D 2020-2021
Project Explorer for C3D 2020 2021
[-] The following 7 users Like rami1976's post:7 users Like rami1976's post
  β€’ cheosmith, zrilek, blaze, Dell_Brett, ashcivilea, oanm2000, cace-01
 Vatsalbu89
User ID: 176711
Likes: 2 in 2 posts
Given Likes: 12
05-19-2021, 08:59 AM
Post # 8Β
The licence server manager is not working withΒ Project Explorer for C3D 2020 2021.
Any Help?
  β€’
  AutoRebar for Autodesk AutoCAD poolmand 1 12,609 08-18-2025, 09:58 AM
  Autodesk AutoCAD Civil 3D 2025 poolmand 2 6,132 12-02-2024, 01:09 PM
  Autodesk AutoCAD Plant 3D 2022 (x64) Pre-Cracked BennyP 1 10,733 10-27-2023, 04:10 PM
Last Post: Dalvisahi014
  Civil Survey Applications ( ex . Solutions ) Civil Site Design v24.0 for Autodesk Civ poolmand 1 5,407 05-06-2023, 02:32 PM
Last Post: Mobadi
  Autodesk AutoCAD 2022 (x64) BennyP 5 13,944 03-29-2022, 11:33 AM
Last Post: Arigato
  Autodesk AutoCAD Civil 3D 2022 poolmand 2 11,774 03-13-2022, 03:04 PM
Last Post: pilitro
  Autodesk AutoCAD Raster Design 2019 BennyP 5 11,058 09-22-2021, 09:07 AM
