Civil Engineering Association Software Software Product Autodesk Products Autodesk Autocad 2021 64Bit
 babakfeyzi
Romania
User ID: 177117
Threads: 15
Likes: 626 in 97 posts
Given Likes: 1390
03-25-2020, 08:23 PM (This post was last modified: 04-27-2020, 11:45 PM by rami1976.)
Autodesk AutoCad 2021 trial
[Image: 92283993659940095355.jpg]
Description:
Autodesk AutoCAD 2021 design and documentation software, of the world’s leading 2D and 3D CAD tools. It will allow you to design and shape the world around you using its powerful and flexible features. Speed documentation, share ideas seamlessly, and explore ideas more intuitively in 3D. With thousands of available add-ons, AutoCAD software provides the ultimate in flexibility, customized for your specific needs. It’s time to take design further.
System requirements:
OS:
-Microsoft® Windows® 7 SP1 with Update KB4019990 (64-bit only)
-Microsoft Windows 8.1 with Update KB2919355 (64-bit only)
-Microsoft Windows 10 (64-bit only) (version 1803 or higher)
CPU:
Basic:2.5–2.9 GHz processor
Recommended:3+ GHz processor
Multiple processors:Supported by the application
RAM:
Basic: 8 GB / Recommended: 16 GB
Display Resolution:
Conventional Displays:1920 x 1080 with True Color
High Resolution & 4K Displays:Resolutions up to 3840 x 2160 supported on Windows 10, 64-bit systems (with capable display card)
Disk space:6.0 GB
[-] The following 12 users Like babakfeyzi's post:12 users Like babakfeyzi's post
  • RajaK, zrilek, ersin, oanm2000, rami1976, Dell_Brett, erbalaji, chenamoy, i_kabir, pcworks200, monter, jacky899
 giovas
User ID: 8386
Threads: 17
Likes: 179 in 20 posts
Given Likes: 210
03-26-2020, 11:18 PM
Mirror:
[-] The following 12 users Like giovas's post:12 users Like giovas's post
  • Dell_Brett, mgdario, erbalaji, zrilek, pcworks200, jcbv, lisine, oanm2000, bao2004, caifan, jacky899, oreslaw
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1390
03-27-2020, 02:47 AM
Autocad 2021 patched file
[Image: tips.png]
unrar , replace the original file with the supplied one
[-] The following 21 users Like rami1976's post:21 users Like rami1976's post
  • Dell_Brett, joker™, Williams, temp1366, dovsky, mgdario, subin91, erbalaji, betinnn, chenamoy, i_kabir, zrilek, monter, pcworks200, oanm2000, spanac, melekeen, highcivil, gianniorlati, jacky899, oreslaw
 rami1976
User ID: 34597
Threads: 355
Given Likes: 1390
04-17-2020, 12:21 AM (This post was last modified: 04-17-2020, 12:24 AM by rami1976. Edit Reason: N/A )
Working  and tested method  to activate autocad 2021 :
-Download the trial version from autodesk
-unpack the downloaded file to a destination forder of your choice (default folder is c:\autodesk\AutoCAD_2021_English_Win_64bit_dlm\ ) then cancel the installation.
- go to the unpacked folder
-replace the original  setup.inf in  with the supplied one to disable autocad genuine services (C:\Autodesk\AutoCAD_2021_English_Win_64bit_dlm):
Replace Autodesk Licensing 10 with Autodesk Licensing 9 from the link  below (normally found in C:\Autodesk\AutoCAD_2021_English_Win_64bit_dlm\x86\AdskLicensing).
- install autocad 2021 and use xforce keygen 2020 to activate it.
tested and works perfectly
use standard forum password
[-] The following 22 users Like rami1976's post:22 users Like rami1976's post
  • jcbv, cace-01, lisine, zrilek, Dell_Brett, Batman07, Williams, RajaK, melekeen, PinkPant, babakfeyzi, erbalaji, rigid_joint, oanm2000, er.shyams, bao2004, monter, cristi, Umer.Aleem, highcivil, TurboXUser, jacky899
 rami1976
User ID: 34597
Threads: 355
Given Likes: 1390
04-27-2020, 09:43 AM
Offline Help for autocad 2021
[-] The following 9 users Like rami1976's post:9 users Like rami1976's post
  • oanm2000, zrilek, Dell_Brett, mowafi3m, monter, lisine, highcivil, gianniorlati, Tumbero
  AutoRebar for Autodesk AutoCAD poolmand 1 12,516 08-18-2025, 09:58 AM
  Autodesk AutoCAD Civil 3D 2025 poolmand 2 6,024 12-02-2024, 01:09 PM
  Autodesk AutoCAD Plant 3D 2022 (x64) Pre-Cracked BennyP 1 10,654 10-27-2023, 04:10 PM
Last Post: Dalvisahi014
  Autodesk AutoCAD 2022 (x64) BennyP 5 13,853 03-29-2022, 11:33 AM
Last Post: Arigato
  Autodesk AutoCAD Civil 3D 2022 poolmand 2 11,719 03-13-2022, 03:04 PM
Last Post: pilitro
  Autodesk AutoCAD Raster Design 2019 BennyP 5 10,956 09-22-2021, 09:07 AM
  Autodesk Autocad 2016 (x64 + x32) Trial BennyP 3 11,638 05-22-2021, 05:55 AM
Last Post: kirankumarklk
