Civil Engineering Association Software Software Product Autodesk Products Autodesk Robot Structural analysis Professional 2021
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1390
04-10-2020, 10:28 PM
[Image: 37694756323642143956.jpg]
[Image: 70419443643833812425.png]
Another advanced software development by Autodesk, which is actually part of the company's Simulation softwareΒ  series called Autodesk Simulation , is the Autodesk Robot Structural Analysis Professional program, which is used for advanced building analysis. The program communicates with the Autodesk Revit software collection and calculates structural models and professional structures in three dimensions.
And
Autodesk Robot Structural Analysis Professional Software Features and Features:
- Existence of a wide range of tools for analyzing and examining the linear and nonlinear structures of the structure
- Dynamic analysis of various types of complex structures
- Investigation and simulation of various types of pressures and natural loads such as earthquakes
- Make two-way communication with Autodesk Revit software
- Has a one-piece design for concrete and steel with more than 40 international codes for steel and more than 30 codes for concrete
- Having a direct analysis method (Direct Analysis Method or DAM)
- Ability to simulate wind tunnel and check the amount of wind created load
[Image: tips.png]
install
follow the instructions as stated in install.txt in the crack folder
[Image: comments.png]
Modified 2020 Xforce Keygen
[-] The following 12 users Like rami1976's post:12 users Like rami1976's post
  β€’ pedzaquino, zrilek, jcbv, dizz, Dell_Brett, promo8, oanm2000, lisine, mohamz, mgdario, RedHorse, deltalead
 rigid_joint
Senior Member
Jamaica
User ID: 6110
Threads: 13
Likes: 333 in 122 posts
Given Likes: 244
04-18-2020, 03:04 PM
I followed the instructions.
I tried it a few times and always after inserting the serial key I get the error (800c0005).
Then it returns me again to the serial key step. I insert the key again and the I get the error again.
And so on. Am I missing something?
  β€’
 cheosmith
Jamaica
User ID: 174720
Threads: 2
Likes: 44 in 23 posts
Given Likes: 499
04-18-2020, 03:34 PM
Did you follow the instruction by unchecking "AutoDesk Geniune Service" while you are installing? Look carefully in the folder you get with the X-force Gen crack you see a png image named UNTICK, that picture show you the options you should untick/uncheck while installing.
I do that for all the 2021 versions of AutoDesk softwares and they are working quite fine.
  β€’
 rigid_joint
Senior Member
Jamaica
User ID: 6110
Threads: 13
Given Likes: 244
04-18-2020, 06:00 PM
I saw the untick picture but the installation menu has not that choice. I downloaded the installation file from the above provided link from Autodesk. I have tried the installation over 3 times and it's always the same problem.
  β€’
 rigid_joint
Senior Member
Jamaica
User ID: 6110
Threads: 13
Given Likes: 244
04-18-2020, 11:52 PM
After a lot of effort I managed to run RSAP2021.
The steps that I followed were these:
1. Installed RSAP2021
2. Went to the directory C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing and run the uninstall.exe file.
3. Installed the AdskLicensing-installer.exe file that comes with the RSAP2020 to install Autodesk Licensing Service 9 version.
4. Followed the usual process with the xforce tool.
5. Uninstalled Autodesk Genuine Check.
So far it seems to work ok.
[-] The following 8 users Like rigid_joint's post:8 users Like rigid_joint's post
  β€’ oanm2000, rami1976, monter, caifan, TurboXUser, fashion, RedHorse, deltalead
  Autodesk Robot 2026 rami1976 0 3,412 05-27-2025, 09:10 PM
  Autodesk Robot Structural Analysis Professional 2024 (x64) Multilanguage TAFATNEB 1 12,650 04-16-2023, 09:52 AM
  Autodesk Inventor Professional 2020 BennyP 2 7,792 12-03-2021, 05:56 AM
Last Post: TheMachinist
  Autodesk Autocad Civil 3D 2021 babakfeyzi 8 13,747 05-19-2021, 08:59 AM
Last Post: Vatsalbu89
  Autodesk Revit LT 2021.1 (x64) Multilanguage BennyP 1 5,234 02-22-2021, 03:40 PM
  Autodesk 2021 Products Keygen + License Server pezhmankhan 1 9,207 09-14-2020, 06:19 PM
  Autodesk 2021 product keys rami1976 1 7,173 06-10-2020, 10:04 PM
