Civil Engineering Association eBooks Structural Books Analysis & Design Structural Engineering Reference Manual
 amadoo02
Egypt
User ID: 1374
Threads: 5
Likes: 235 in 40 posts
Given Likes: 48
10-20-2012, 06:49 AM (This post was last modified: 10-20-2012, 08:46 AM by lisine.)
Structural Engineering Reference Manual - 4th Edition
Author: Alan Williams | Size: 27.1 | Format: PDF | Quality: Scanner | Publisher: Professional Publications, Inc. | Year: April 21, 2008 | pages: 344 | ISBN: 1591261198, 978-1591261193
[Image: 42887844337339370082.jpg]
The Structural Engineering Reference Manual is the most comprehensive reference and study guide available for engineers preparing for the NCEES Structural I and Structural II exams and the California state structural exam. The structural PE exams require a thorough familiarity with relevant codes, and the 4th edition of the Structural Engineering Reference Manual has been updated to the latest exam code specifications.
The most trusted reference for the Structural I and II exams
Updated to the new structural design standards 2005 edition of AISC 2005 edition of NDS 2005 editions of ACI 318 and ACI 530/ASCE 5/TMS 402 2004 editions of AASHTO 2005 edition of ASCE 7 2006 edition of IBC A complete introduction to the exam format and content Nearly 40 practice problems with solutions Numberous tables, charts, and figures at your fingertips An easy-to-use index for quick reference
[-] The following 50 users Like amadoo02's post:50 users Like amadoo02's post
  • kowheng, Dell_Brett, david-smith, slowet, lisine, blaze, shadabg, lednar_ved, gulilero, oanm2000, maad59, ruaumoko, usman, malc, amirdana, mahyarov, zrilek, cace-01, k2kyaw, emmi, eng donny, we_mbm, pmg814, Trishu999, cordoba123, cristi, uncblue, sodapas, zego2000, mgdario, ykhackhack, monter, Ernest0, frank1972, Nilupa, dwrred, pram, xdesi, bigone, simanta, XXXX123, febo1412, KhaLed-S.E, ibg0203, shaker, vvvv, K.Lee, tuanpecc1, mohamz, noel
 bogdanobi
Romania
User ID: 31917
Threads: 8
Likes: 222 in 22 posts
Given Likes: 133
08-01-2013, 06:43 PM
[-] The following 25 users Like bogdanobi's post:25 users Like bogdanobi's post
  • Jackass, Dell_Brett, vardan, simanta, shadabg, draluka, learner20, hzaheer, knrsa, k2kyaw, zego2000, bigone, maijuji, Hengki, ibg0203, shaker, ting tsai huang, carolinandra, narendra, tang1942, Ivan_1980, melekeen, cowboy, ykhackhack, techno
 bigone
User ID: 4505
Threads: 92
Likes: 5,722 in 517 posts
Given Likes: 7145
12-01-2013, 12:21 PM
Structural Engineering Reference Manual by Alan Williams-4th Ed-2008- 1591261198_ACI AISC ASCE7.pdf
[-] The following 10 users Like bigone's post:10 users Like bigone's post
  • subin91, Dell_Brett, Andrew seah, aninos, rendel_©, miquan, simanta, deltalead, ykhackhack, levanduy
 bigone
User ID: 4505
Threads: 92
Given Likes: 7145
02-12-2015, 07:29 PM
[-] The following 18 users Like bigone's post:18 users Like bigone's post
  • promo8, ykhackhack, malc, Dell_Brett, dizz, PinkPant, vvvv, oanm2000, bridgeengineer, GMianG, draluka, simanta, dinu69in, pedronick, xdesi, uncblue, jcbv, blaze
 cace-01
User ID: 15651
Threads: 440
Likes: 10,522 in 867 posts
Given Likes: 7468
07-14-2015, 08:35 AM
Structural Engineering Reference Manual (8th Edition)
Author: Alan Williams PhD SE FICE C Eng | Size: 13 MB | Format: PDF | Quality: Unspecified |
Publisher: Professional Publications | Year: 2015 | pages: 512 | ISBN: 1591264960, 9781591264965
[Image: 62525706222974738778.jpg]
Comprehensive Coverage for the 16-Hour Structural Engineering Exam
The Structural Engineering Reference Manual prepares you for the NCEES 16-hour Structural Engineering (SE) exam. It provides a comprehensive review of structural analysis and design methods related to vertical and lateral forces. All exam topics are covered, and exam-adopted codes and standards are frequently referenced. You will learn how to apply concepts by reviewing the 244 example problems, and you will strengthen your problem-solving skills by working the 44 end-of-chapter practice problems. Each problem’s complete solution lets you check your own solving approach.
Access to supportive information is just as important as knowledge and problem-solving efficiency. The Structural Engineering Reference Manual’s thorough index easily directs you to the codes and concepts you will need during the exam. Cross references to more than 700 equations, 60 tables, 190 figures, 8 appendices, and relevant codes will point you to additional support material when you need it.
Topics covered
Bridges
Foundations and Retaining Structures
Lateral Forces (Wind and Seismic)
Prestressed Concrete
Reinforced Concrete
Reinforced Masonry
Structural Steel
Timber
Referenced Codes and Standards
AASHTO LRFD Bridge Design Specifications (AASHTO)
Building Code Requirements and Specification for Masonry Structures (TMS 402/602)
Building Code Requirements for Structural Concrete (ACI 318)
International Building Code (IBC)
Minimum Design Loads for Buildings and Other Structures (ASCE 7)
National Design Specification for Wood Construction ASD/LRFD and National Design Specification Supplement, Design Values for Wood Construction (NDS)
North American Specification for the Design of Cold-Formed Steel Structural Members (AISI)
PCI Design Handbook: Precast and Prestressed Concrete (PCI)
Seismic Design Manual (AISC 327)
Special Design Provisions for Wind and Seismic with Commentary (SDPWS)
Steel Construction Manual (AISC 325)
Thanks to Original Uploader
[-] The following 45 users Like cace-01's post:45 users Like cace-01's post
  • concreteok, PinkPant, Dell_Brett, vvvv, usman, gianniorlati, emmi, mig21, ssobhan, viet2010, ASEC, dizz, civilphongvan, oanm2000, shaker, Ultra Zone, zrilek, junaid, vardan, lisine, slowet, Jackass, miquan, learner20, uncblue, goober, Veggeta, inge911, mgdario, K.Lee, malc, bridgeengineer, carolinandra, ibg0203, bigone, eliseo.as, xdesi, RyanRS, gulilero, eng donny, psk62, manzoor_quadri, oram, ruaumoko, kowheng
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 51
Likes: 4,964 in 638 posts
Given Likes: 3501
08-03-2015, 03:55 AM
concrete solution advocate
[-] The following 23 users Like concreteok's post:23 users Like concreteok's post
  • learner20, eng donny, PinkPant, oanm2000, ykhackhack, bridgeengineer, melekeen, techno, Dell_Brett, psk62, nibbi, ruaumoko, chairatpk, civilgen, GMianG, manzoor_quadri, blaze, rezart, rendel_©, harsono, rfireman, zego2000, pedzaquino
 eng donny
Indonesia
User ID: 765
Threads: 14
Likes: 1,976 in 236 posts
Given Likes: 905
08-03-2015, 05:29 AM
MIRROR LINK :
[-] The following 14 users Like eng donny's post:14 users Like eng donny's post
  • PinkPant, simanta, oanm2000, ykhackhack, ting tsai huang, gulilero, Dell_Brett, mkat2003, dinu69in, cristi, sodapas, nickycruz, erthqkengnr™, bridgeengineer
 rami1976
User ID: 34597
Threads: 341
Likes: 9,524 in 1,138 posts
Given Likes: 1388
03-13-2016, 10:28 PM
[-] The following 21 users Like rami1976's post:21 users Like rami1976's post
  • simanta, Dell_Brett, odiclas, ali akbar, oanm2000, milova, slowet, K.Lee, pedzaquino, visu, knrsa, monter, amareen2000, deltalead, nickycruz, lasalleguy, konstobo, raymelito, kowheng, babakfeyzi, chandra1234567
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 51
Given Likes: 3501
03-25-2020, 04:38 AM
[Image: 75654758715700417089.png]
  • Author(s): Alan Williams PhD SE FICE C Eng
  • Published By: Professional Publications
  • Published Year: Dec 2017
  • Size: 150 MB
  • Quality: Original Preprint
[-] The following 39 users Like concreteok's post:39 users Like concreteok's post
  • RajaK, civilfafa, zrilek, chandra1234567, tuanpecc1, babakfeyzi, blaze, temp1366, lisine, Dell_Brett, Aviator, mahyarov, tomtumx, shaker, usman, ibg0203, carolinandra, PinkPant, jcoronellr, oanm2000, gulilero, promo8, kowheng, malc, ajmf77, cace-01, rami1976, pedzaquino, Williams, raymelito, mohamz, Wijono, monter, simanta, levanduy, cristi, emmi, xdesi, lasalleguy
 temp1366
Senior Member
User ID: 85519
Threads: 80
Likes: 1,544 in 165 posts
Given Likes: 741
#10
12-21-2020, 09:49 AM (This post was last modified: 12-21-2020, 09:50 AM by temp1366.)
  • Size: 75 MB
[-] The following 22 users Like temp1366's post:22 users Like temp1366's post
  • CAMSECT, sodapas, Aviator, Andrew seah, emmi, subin91, blaze, eng donny, hatkam, shanta, tuanpecc1, milova, caifan, Dell_Brett, oanm2000, jcbv, Wijono, zrilek, babakfeyzi, PinkPant, mgdario, mohamz
  Structural Depth Reference Manual for the Civil PE Exam, 3rd Ed. asim99 2 9,107 08-25-2017, 12:47 PM
Last Post: shaker
