Civil Engineering Association Software Software Product Bentley Products Bentley STAAD.Pro CONNECT Edition V22
 kirankumarklk
User ID: 29935
Threads: 68
Likes: 960 in 135 posts
Given Likes: 280
01-17-2019, 09:04 AM (This post was last modified: 08-10-2021, 06:07 AM by Administrator.)
Bentley STAAD.Pro CONNECT Edition V22 (22.00.00.015)
[Image: 66190206607491934965.jpg]
Including Foundation Advanced (09.00.00.009), RCDC (08.00.00.16), Building Planner (15.00.00.08)
3D Structural Analysis and Design Software
Perform comprehensive analysis and design for any size or type of structure faster than ever before using the new STAAD.Pro CONNECT Edition. Simplify your BIM workflow by using a physical model in STAAD.Pro that is automatically converted into the analytical model for your structural analysis. Share synchronized models with confidence for multi-discipline team collaboration and, most importantly, deliver safe, cost-effective designs.
Because every firm has different needs, there are three flexible STAAD.Pro options:
STAAD.Pro – The most basic STAAD option including FEM analysis and physical modeling
STAAD.Pro Advanced – Adds faster, more advanced and complex analysis
Structural Enterprise – The most popular structural applications in a single a cost-effective license
Confidently design steel, concrete, timber, aluminum, and cold-formed steel structures anywhere in the world using over 90 included international design codes, regardless of which STAAD option you choose.
Automatically convert your physical model into an analytical model to streamline your workflow.
Improve multi-discipline team collaboration through broad interoperability with Bentley desktop and cloud and mobile applications like AECOsim Building Designer, AutoPIPE, Revit, and Tekla.
Optimize concrete and steel BIM workflows with the full integration of physical members and surfaces.
Run many design alternatives in parallel with STAAD’s cloud services and view the results in clear, graphical side-by-side comparisons.
Design for high-seismic regions or everyday conditions, using Finite Element analysis.
View and edit models of any size from mobile devices
[Image: tips.png]
Unrar and install the app. Apply patch.
Thanks to lavteam
[Image: homepage.png]
[-] The following 32 users Like kirankumarklk's post:32 users Like kirankumarklk's post
  β€’ Dell_Brett, malee, munycamsec, PinkPant, pedzaquino, oanm2000, jokerβ„’, chenamoy, promo8, ranger, usman, emmi, zego2000, cace-01, er.shyams, malc, jfjdm, taifur, zrilek, prabal_16, blaze, an_dru18, narendra, deltalead, lasalleguy, Rodmo376, tolesa54, floatfree, caifan, Wijono, fretts08, spat
 eqwang
User ID: 1552
Likes: 7 in 4 posts
Given Likes: 3
01-02-2020, 08:03 PM
The three download links above do not work. Could someone post mirror sites? Thank you very much in advance!
[-] The following 3 users Like eqwang's post:3 users Like eqwang's post
  β€’ hatkam, mohamz, mowafi3m
 er.shyams
Member
United Kingdom
User ID: 36991
Threads: 45
Likes: 966 in 83 posts
Given Likes: 783
01-07-2020, 09:37 AM
The links shared in original post work perfectly fine and thanks to the uploader. on request created mirror links.
[Image: comments.png]
These are Mirror of the original post #1
Thanks are due to the original uploader
[-] The following 16 users Like er.shyams's post:16 users Like er.shyams's post
  β€’ highcivil, hatkam, Andrew seah, oanm2000, Dell_Brett, mohamz, eqwang, tolesa54, dshiva, promo8, chenamoy, eszb, alcalan57, Wijono, mowafi3m, jacky899
 shanta
User ID: 24696
Threads: 30
Likes: 20 in 13 posts
Given Likes: 475
03-28-2020, 10:54 PM (This post was last modified: 03-29-2020, 11:39 AM by Dell_Brett. Edit Reason: N/A )
Can you please reconfigure the 'Patch' file and re upload? The 'Patch' file included in the uploaded items is not working for me. Every time I am trying to use the patch file , it appears as virus and potential threat to the system and gets auto removed by the system. I have tried disabling the windows firewall and disconnecting from one drive but NO LUCK so far.
Thanks for your help in advance.
Moderator note:
Most, if not all, cracking programs directly affect registry keys and alter program structures to be "released" when native operating system programs.
This procedure is exactly the same that viruses, Trojans, etc. adopt for their attacks.
Because of this, cracking programs are often interpreted as viruses by antivirus programs.
They may or may not be! They may be a false positive or contain, in fact, a harmful parasite!
The suggestion is to always test yourself on a virtual machine, or, at least, proceed to a complete scan of a good anti-virus after cracking.
And always worth: USE AT YOUR OWN RISK!
(There is only one way to not take any risks: If the program is important to you, BUY THE ORIGINAL VERSION!)
[-] The following 1 user Likes shanta's post:1 user Likes shanta's post
  β€’ promo8
 structural
Singapore
User ID: 7169
Threads: 2
Likes: 28 in 9 posts
Given Likes: 45
08-16-2020, 03:54 PM
Hi, i followed the instruction for the medicine after installation. However, I am still getting an expire license. Is there any additional step that I should follow for successful installation? thank you!
  β€’
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
08-10-2021, 05:21 AM
Bentley STAAD.Pro CONNECT Edition v22 Update 7 Build 22.07.00.160 x64
I am pleased to announce a new incremental release of STAAD.Pro CONNECT Edition V22.
As part of our commitment to you to deliver new builds more frequently, we are making available this version which adds great new functionality to improve efficiency for engineers around the world and has resolved numerous issues that have been reported and thus highly recommend that you look to adopt this version and improve your working experience.
The principal developments and enhancements that are delivered in this new version of STAAD.Pro are:
Multiple analysis
The physical model now allows you the ability to define collections of load cases with their own analysis methods which can be quickly activated/deactivated and sequences redefined for rapid prototyping during the development phase.
Tapered members
A popular feature in STAAD.Pro used in the metal building industry is the use of members that have a tapering web. The ability to define and utilise this in a physical model has been added to allow for this enhanced profile property
Improved Structure Wizard (*)
Being able to parametrically define physical models added in the last release has been enhanced with an improved Editor for user defined templates and new templates. The introduction of folders for organising templates, the support of trigonometric functions such as sine and cos to assist in defining more complex geometry along with the improved editing controls for user defined templates.
ASCE 7 – 2016 combination generation
STAAD has had the ability for generating load combinations based on the specified load case categories. These are delivered with the installation as a number standard rule sets, but can be modified and supplemented with user defined rule sets. With STAAD.Pro V22 Update 7 an additional rule set has been added to assist those designing models to that need to account for load combinations as defined in the ASCE-7 2016 publication.
Extended support for Plate offsets
In the last release of STAAD.Pro, the analysis of finite element models was extended with the support of using offsets assigned on plate elements when used with a standard elastic analysis. In this release, this support has been extended to include p-delta analysis, direct analysis and dynamic analyses that use eigen solutions such as response spectrum and time history.
Indian Seismic Irregularity Checks
When working with models that have rigid floor diaphragms, STAAD.Pro has provided a method for checking the model for irregularities as defined in a number of design codes. The checks for torsion irregularity to IS 1893 (Part 1):2016 which has been implemented in STAAD.Pro has been updated with Amendment 2. This amendment has now been incorporated in STAAD.Pro along with an update in the format of the check results to assist designers with making suitable judgements as to the actions to take based on the results of the checks.
Chinese Steel Design Workflow
New Inbuilt Workflow
STAAD.Pro has worked closely with designers in China to develop a solution to meet the needs of Chinese engineers who design steel structures to the GB 50017. This was previously offered as a standalone application providing design routines to help optimize structural members of models created separately in STAAD.Pro.
With STAAD.Pro CE V22 Update 7 this design capability has been simplified by merging it into the main application so provides a more convenient work process and ultimately making a more productive solution avoiding having to jump between different applications.
Chinese Response Spectrum Loading
To complement the introduction of the Chinese Steel Design Workflow, the range of response spectrum loading methods offered has been increased with the introduction of the Chinese method defined in the GB 50011-2010 specification.
General
Extended collection of verifications
To help provide greater clarity on the quality assurance carried out each time the program is released, more verification examples and models are added into the installation providing engineers to not only satisfy themselves on the approaches taken, but the validity of the results in the various analysis methods and design codes that are supported by STAAD.Pro.
Additional Modules
RCDC (**)
The Advanced Concrete Design application, RCDC, has been updated to v11.0 which includes: -
Addition of Australian code – AS 3600:2018,
Note: Design of Pile-cap is available in this code as a technical preview feature.
Addition of Belgium Annex for BS EN Code.
NBN EN 1992-1-1 (ANB: 2010) (Belgium annex) added for design in all modules including water-tank structures.
Addition of BS EN Base / Custom Code for all modules.
Create a 'Custom' annex to suit local design standards.
Design of Tank Structures for Base Eurocode code, Singapore Annex and Malaysian Annex
Design of tank structures for the base Eurocode (BS EN 02-1-1-2004) including Singapore annex (SS NA) and Malaysian Annex (MS NA)
Earthquake/ Wind Load (ASCE) for design using ACI code
Joint check for Ductile column design using Euro Code
Footing Module - Effect of Ground Water Table in soil pressure check and sizing for all types of footing
For more details on these and other issues that have been addressed in this build Refer to the RCDC Release Notes.
STAAD Foundation Advanced (***)
The concrete foundation application included in the STAAD.Pro installation, STAAD Foundation Advanced (SFA) has been updated to v9.6 which includes: -
General mode and Toolkit mode
Design of isolated footings to the 2019 edition of Canadian A23.3
General mode
Design of mat foundations to the 2019 edition of Canadian A23.3
For more details on these and other issues that have been addressed in this build Refer to the SFA Release Notes.
[Image: tips.png]
1- Install "Setup_StaadProx64_22.07.00.160.exe"
2- Stop all "Bentley CONNECTION" in system try.
3- Uninstall "connection client" from Control Panel -- > Programs -- > Add or remove programs (یا Programs and Features)
4- From Crack Folder install "Setup_CONNECTIONClientx64_10.00.13.017.exe"
5- Be sure "Bentley CONNECTION Client" is stopped.
6- From Crack folder copy "Patch.exe" to install software folder (default is: C:\Program Files (x86)\Bentley\Engineering\STAAD Foundation Advanced) and run it as administrator.
7- Joy !
[-] The following 19 users Like poolmand's post:19 users Like poolmand's post
  β€’ RajaK, PinkPant, vvvv, Dell_Brett, chandra1234567, caifan, mohamz, coxxxyboy, malc, oanm2000, kirankumarklk, mecheil.edwar, taifur, mgdario, xdesi, karthikeyans3d, Umer.Aleem, jacky899, zrilek
 Arigato
Ireland
User ID: 740
Threads: 29
Likes: 893 in 88 posts
Given Likes: 277
11-12-2021, 03:52 AM (This post was last modified: 11-12-2021, 08:23 AM by Dell_Brett. Edit Reason: N/A )
Staad.Pro 22 Update 8
(v22.08.00.175, 11/04/2021. 3 Mb) - online setup only
  β€’
 RajaK
Structural Engineer
User ID: 172894
Threads: 8
Likes: 273 in 21 posts
Given Likes: 332
11-12-2021, 01:34 PM
STAAD.Pro CONNECT Edition V22 Update 8
[Image: 08655129269672979121.jpg]
Bentley STAAD.Pro is a leader in structural analysis and design software. Bentley STAAD.Pro is the choice of a professional to design any structure, including culverts, petrochemical plants, tunnels, bridges, apartment buildings and many other structures made of steel, concrete, timber, aluminum and cold-formed steel. Bentley STAAD.Pro certified according to the GOST R certification system.
[Image: tips.png]
1 Install STAAD.Pro CONNECT Edition V22 Update 8.
2 Uninstall the Bentley Connection Client 11.00.03.25.
3 Install the Setup_CONNECTIONClientx64_11.00.02.20 included in archive.
4 From patcher folder copy "Patch_CNN_CLI_(CL)_x64_11.00.02.20_REV0" file paste to C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicService.
5 Open the Patch with Run As Administrator.
6.Enjoy.
Password: 91EDD42D-9465FBE2-B9400140-226C33B8
[-] The following 16 users Like RajaK's post:16 users Like RajaK's post
  β€’ vvvv, Dell_Brett, babakfeyzi, rezart, Wijono, tomtumx, Rainbow, mohamz, zrilek, cace-01, spat, pedzaquino, PinkPant, nibbi, structural, oanm2000
 RajaK
Structural Engineer
User ID: 172894
Threads: 8
Given Likes: 332
02-13-2022, 06:44 AM
STAAD.Pro CONNECT Edition V22 Update 9Β  V22.09.00.115
[Image: 32782168842508223249.jpg]
STAAD.Pro CE is a comprehensive and integrated finite element analysis and design application that includes visualization
capabilities, a simple user interface, and a wide range of design codes. You can analyze any structure exposed to
Static, Dynamic, Wind, Earthquake, Thermal, and Moving loads. STAAD.Pro CE provides Structural Analysis and Design
for any type of project, including Buildings, Culverts, Plants, Bridges, Stadiums, and Marine Structures.
[Image: tips.png]
1 Install STAAD.Pro CONNECT Edition V22 Update 9.
6.Enjoy.
[-] The following 12 users Like RajaK's post:12 users Like RajaK's post
  β€’ civilfafa, Dell_Brett, zrilek, rezart, Administrator , cheosmith, tomtumx, oanm2000, cace-01, malc, Wijono, dinu69in
 Arigato
Ireland
User ID: 740
Threads: 29
Given Likes: 277
#10
04-13-2022, 11:20 PM
v22, update 10. setup file only
[-] The following 5 users Like Arigato's post:5 users Like Arigato's post
  β€’ zrilek, Dell_Brett, rami1976, Administrator , cace-01
Pages (2): 1 2 Next »
  Bentley STAAD.Pro Advanced 2024 poolmand 0 5,620 09-15-2024, 06:01 AM
  STAAD.Pro CONNECT Edition Update 3 (21.03.00.146) RajaK 7 13,084 07-27-2024, 03:40 AM
  Bentley MicroStation CONNECT Edition 2023 poolmand 2 6,404 10-08-2023, 12:24 PM
  Bentley STAAD.Pro CONNECT V23 poolmand 0 6,311 10-02-2023, 09:01 AM
  Bentley.RCDC.Connect.Edition.11.02.00.200 kirankumarklk 0 4,985 04-02-2022, 11:14 AM
Last Post: kirankumarklk
  RCDC FE Connect Edition V4 Update 1 RajaK 1 6,982 03-28-2022, 06:28 AM
  Bentley OpenRail Designer CONNECT Edition 2021 poolmand 1 4,330 02-26-2022, 09:13 AM
