Civil Engineering Association eBooks Environmental Engineering Instrumentation Control And Automation For Wastewater Treatment Systems
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1405
04-26-2016, 08:01 AM (This post was last modified: 10-04-2019, 07:08 AM by lisine. Edit Reason: N/A )
Author(s)/Editor(s): J. F. Andrews ,R. Briggs ,S. H. Jenkins | Size: 9 MB | Format: PDF | Quality: Pdf | Publisher: Pergamon Press Ltd |  pages: 566
[Image: 27481171125375898928.jpg]
Application in the field of waste-water treatment has been slow mainly because of the  difficulty of determining which parameters should be selected for process control and  because the  instantaneous determination of the ideal parameters is still only in the early  stages of development.
This situation was realised during the IAWPR Workshop in Vienna in 1971 and the  idea for a Workshop on Instrumentation, Control and Automation for Waste-water Treatment Systems was born there.
The Development Division has the following special aims within the general role of DGWE:
(a ) to identify areas in which research and development in the water engineering field  are most urgently required;
(b ) to prepare, initiate and where appropriate, manage a government programme of  development in this field and to co-ordinate that programme with work being  carried out elsewhere;
(c ) to promulgate the results and fill gaps in existing knowledge;
(d ) to sponsor and manage large-scale development projects with national and international implications;
(e ) to liaise between pure researchers and field practitioners, serving as a catalyst and to  process and present the
[-] The following 8 users Like rami1976's post:8 users Like rami1976's post
  • Dell_Brett, amindoxiti, oanm2000, PinkPant, malc, Jackass, toa011, emmi
Threads: 57
10-04-2019, 05:37 AM
Size: 14.20 MB | Format: PDF
[-] The following 8 users Like kowheng's post:8 users Like kowheng's post
  • PinkPant, febo927, oanm2000, cace-01, Dell_Brett, gulilero, caleno, emmi
  Principles of Membrane Bioreactors for Wastewater Treatment cace-01 1 2,061 06-30-2015, 06:51 PM
  Nanocomposites in Wastewater Treatment cace-01 1 2,243 01-31-2015, 05:20 PM
Last Post: Veggeta
  BASIC Water and Wastewater Treatment cace-01 1 2,191 12-23-2014, 01:03 PM
  Wastewater Treatment: Biological and Chemical Processes, 3rd Edition Mohammad6299 0 1,890 02-19-2014, 07:15 AM
Last Post: Mohammad6299
  Ozone Reaction Kinetics for Water and Wastewater Systems ska51 1 2,519 04-05-2013, 08:36 AM
Last Post: arshiakh
  Wastewater Collection Systems Management:Sixth Edition (MOP 7) ska51 1 2,301 04-03-2013, 03:03 PM
Last Post: arshiakh
  Physical-Chemical Treatment of Water and Wastewater - by Arcadio P Sincero mowafi3m 3 3,244 03-26-2013, 06:01 AM
Last Post: arshiakh
