Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Books and Codes Request [REQUEST] Old AASHTO design examples
[Request] Old AASHTO design examples
 RICARDI
User ID: 6997
Threads: 47
Likes: 180 in 37 posts
Given Likes: 195
09-15-2019, 12:00 AM
I found this list of design examples in internet. Does any one has it?
The post that I sow it is:
but i found that it comes from an other forum
1. American Iron and Steel Institute. 1997. Four Design Examples of Steel Highway Bridges, New York
The below documents consist of a comprehensive steel girder bridge design example, with instructional commentary based on the AASHTO LRFD Bridge Design Specifications (Second Edition, 1998, including interims for 1999 through 2002).
Download PDF files:
2. Steel Superstructure SI.pdf
3. Steel Superstructure.pdf
The below documents consist of a comprehensive design example of a prestressed concrete girder bridge. The superstructure consists of two simple spans made continuous for live loads. The substructure consists of integral end abutments and a multi-column intermediate bent. The document also includes instructional commentary based on the AASHTO-LRFD Bridge Design Specifications (Second Edition, 1998, including interims for 1999 through 2002).
Download PDF files:
4. Concrete Design Example - US units
5. Concrete Example - SI.pdf
Below are design examples for Horizontally Curved I-Girders and Box-Girders, current to the 2005 LRFD Interims.
Download PDF files:
6. Horizontally Curved Box Girder Example
7. Horizontally Curved Box Girder Example: mathcad
8. Horizontally Curved I-Girder example
9. Horizontally Curved I-Girder Example: mathcad
Below are design examples for State Route 45 (Old Hickory Blvd.)/I-65, Davidson County. This is a 2-span welded girder design on a tangent alignment.
10. Design Build Total
Below are design examples for I-55/Mallory Avenue, Shelby County. this a 3-span horizontally curved welded plate girder design, current to 2005 Interims.
11. I55_LRFD.PDF
12. LAYOUT.pdf
Below are additional design examples:
13. index.pdf
14. LRFD slab transverse reinforcement.pdf
15. LRFD slab negative moment.pdf
16. LRFD pre-stressed beam.pdf
17. LRFD bent 7 Spread Footing.pdf
18. LRFD bent 6 pile footing.pdf)
18. LRFD bent 5 cap beam.pdf
19. LRFD bent 4 column sqare with cutout.pdf
20. LRFD bent 4 column rectangular.pdf
21. LRFD bent 4 column rectangular with round ends.pdf
22. RFD bent 2 other.pdf
  [REQUEST] Wind Design Manual Based on the 2018 IBC and ASCE/SEI 7-16 Examples for Win sabooryan 1 1,966 09-08-2020, 02:28 PM
Last Post: jonygut
  [REQUEST] Design of Composite Steel and Concrete Structures with Worked Examples to Eurocode 4 jmksq 0 1,438 03-04-2017, 03:07 PM
Last Post: jmksq
  [REQUEST] ACI SP 273 Further examples for design of structural concrete with strut & tie models aslam 0 1,475 01-31-2017, 03:21 AM
Last Post: aslam
