Civil Engineering Association Software Software Product Autodesk Products Autodesk Robot 2020 structural analysis professional
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1405
04-12-2019, 09:38 PM
Autodesk Robot 2020 structural analysis Β professional
[Image: 95509075490728979473.jpg]
Robot Structural Analysis Professional software features and facilities Autodesk:
-There is a range of linear and nonlinear structural analysis tools and behaviors
-Dynamic analysis of complex structures
-Check and simulate the pressures and normal loads such as earthquakes
-establishing two-way communication with Autodesk Revit software
-The integrated design of concrete and steel with more than 40 international codes for steel and concrete For more than 30
-Having direct analysis method (Direct Analysis Method or abbreviated DAM)
-Ability to simulate wind tunnel and created the wind load
[Image: homepage.png]
[-] The following 19 users Like rami1976's post:19 users Like rami1976's post
  β€’ Nita1391, jokerβ„’, kowheng, amindoxiti, caifan, zrilek, lisine, oanm2000, Dell_Brett, mgdario, kirankumarklk, cace-01, blaze, bridgeengineer, mohamz, pousin, golpesar, vinnunsam, bearhunter
 ALMF
User ID: 1069
Threads: 4
Likes: 493 in 61 posts
Given Likes: 39
04-21-2019, 03:55 PM (This post was last modified: 04-21-2019, 09:31 PM by rami1976. Edit Reason: Updated )
Offline help Β for Autodesk Robot Structural Analysis Professional 2020 (568 Mb)
Regards, ALMF
[-] The following 12 users Like ALMF's post:12 users Like ALMF's post
  β€’ Dell_Brett, jcbv, rami1976, promo8, zrilek, cace-01, bridgeengineer, mohamz, oanm2000, malc, vinnunsam, bearhunter
Threads: 1,118
04-26-2019, 03:43 AM (This post was last modified: 04-26-2019, 09:03 AM by rami1976. Edit Reason: Updated )
Robot Structural Analysis Professional 2020.0.1 HotFix 64-Bit (51 Mb)
[-] The following 14 users Like BennyP's post:14 users Like BennyP's post
  β€’ zrilek, lisine, rami1976, Dell_Brett, promo8, caifan, malc, Ekkaia, oanm2000, mohamz, cace-01, bluefish80, KINIMOLEBA, vinnunsam
  Autodesk Robot 2026 rami1976 0 3,482 05-27-2025, 09:10 PM
  Autodesk Universal Patch 2020-2024 All Products Dell_Brett 2 15,279 10-04-2023, 07:10 AM
  Autodesk Robot Structural Analysis Professional 2024 (x64) Multilanguage TAFATNEB 1 12,732 04-16-2023, 09:52 AM
  Autodesk Inventor Professional 2020 BennyP 2 7,850 12-03-2021, 05:56 AM
Last Post: TheMachinist
  Autodesk Robot Structural analysis Professional 2021 rami1976 4 10,495 04-18-2020, 11:52 PM
Last Post: rigid_joint
  Autodesk Infrastructure Design Suite Ultimate 2020 giovas 0 5,157 08-04-2019, 04:50 PM
Last Post: giovas
  Autodesk 3DS Max 2020 BennyP 4 8,645 06-12-2019, 07:26 PM
