Civil Engineering Association eBooks Codes, Manual & Handbook Non-English written codes USA - AISC 360-10 for Steel Construction - Spanish version.
 anfaga
structural engineer
User ID: 12412
Threads: 39
Likes: 606 in 50 posts
Given Likes: 279
12-16-2015, 02:54 PM
USA - ANSI/AISC 360-10 for Steel Construction - Spanish version.
Author(s)/Editor(s): Asociación Latinoamericana del Acero (Alacero) | Size: 12,4 MB | Format: PDF | Quality: Original preprint |
Publisher:
Asociación Latinoamericana del Acero (Alacero), Chile. | Year: 2010 | pages: 318 | ISBN: 9789568181123
[Image: 66017108228918624119.jpg]
Based on the publication "Specification for Structural Steel Buildings" (American National Standard ANSI / AISC 360-10) published by the American Institute of Steel Construction (AISC).
This specification establishes criteria for the design, fabrication and installation of structural steel buildings and other structures where other structures are defined as those structures designed, manufactured and assembled in a similar way to the building, thus indicating that its resistant elements vertical and lateral loads are similar to those resistant building systems.
If this specification refers to the applicable building code, and the code does not exist, loads, load combinations, system limitations, and general design requirements are set out in ASCE / SEI 7.
When these conditions are not covered by this specification, allowing the design is made based on tests or analyzes, provided they are approved by the competent authority.
The use of alternative methods of analysis and design, to the extent that such methods are accepted by the competent authority are allowed.
Seismic Applications: The code Seismic Provisions for Structural Steel Buildings (ANSI-AISC 341) should be applied in the design of earthquake resistant systems structural steel or structural steel acting in combination with concrete, unless specifically exempted by the applicable building code. The provisions of Annex 1 of this specification should not be applied to the seismic design of buildings or other structures.
Nuclear Applications: In addition to the provisions of this specification, the design, manufacture and assembly of nuclear structures must meet the requirements of Safety-related Specification for Steel Structures for Nuclear Facilities (AISC ANSI-N690).
The design is made in accordance with the provisions of the design method based on factors Load and Resistance (LRFD) or any method based Design Allowable Resistance (ASD).
Post Edited by moderator - removed dashes in ISBN number
[-] The following 8 users Like anfaga's post:8 users Like anfaga's post
  • oanm2000, hernansgz, Dell_Brett, PinkPant, dovsky, ruaumoko, bridgeengineer, malc
 febo927
User ID: 23688
Threads: 105
Likes: 4,179 in 339 posts
Given Likes: 1279
02-01-2019, 11:39 AM
Here it is
[-] The following 4 users Like febo927's post:4 users Like febo927's post
  • Dell_Brett, dovsky, onest30, oanm2000
  Código de soldadura estructural—Acero AWS D1.1/D1.1M:2020 Spanish malc 0 4,591 01-23-2021, 03:39 AM
Last Post: malc
  USA - ACI 318 S 19 for Structural Concrete - Spanish version. jonygut 0 4,887 09-11-2020, 03:05 AM
Last Post: jonygut
  USA - ACI 318 S 05 for Structural Concrete- Spanish version. anfaga 1 5,989 02-01-2019, 11:48 AM
Last Post: febo927
  Mexico City Building Codes (in Spanish) raulraulza 1 5,834 09-08-2011, 02:56 AM
Last Post: bogserman
  Nicaragua National Building Regulations (Spanish) nickycruz 0 4,532 07-06-2011, 07:46 PM
Last Post: nickycruz
