Civil Engineering Association eBooks Geotechnical Engineering Tunneling Bentonite handbook - Lubrication for pipe jacking
 gianniorlati
Senior Underground Works Engineer
Italy
User ID: 46169
Threads: 70
Likes: 1,673 in 128 posts
Given Likes: 429
11-17-2018, 08:05 AM (This post was last modified: 11-17-2018, 11:28 AM by lisine. Edit Reason: New Cover + some code correction )
Author(s): Praetorius Steffen, Schösser Britta, Sturge David | Size: 12 MB | Format: PDF | Quality: Original preprint | Publisher: Wiley - Ernst & Sohn | Year: 2017 | pages: 213 | ISBN: 978-3433-606520, 3433606528, 978-3433606537, 3433606536, 978-3433031377, 978-3433606551, 978-3433606544
[Image: 57226594595325906580.jpg]
Pipe jacking is a construction process for the no-dig laying of pipes. Successful pipe jacking demands low skin friction between the ground and the jacked pipe. This is achieved with bentonite lubrication. The bentonite slurry fed into the annular gap fulfils several purposes. It stabilises the annular gap by supporting the surrounding ground and reduces friction contact between ground and jacked pipe. The Bentonite Handbook deals comprehensibly with the relevant aspects of annular gap lubrication: starting with the ground conditions, which are of decisive importance for lubrication, through the rheological properties of the bentonite slurry to the technical components of lubrication technology and lubrication strategy. The use of standardised measuring apparatus is described as well as mixing equipment and the automatic lubrication system. Overview tables with calculations and suggested values for bentonite consumption quantities depending on the prevailing ground conditions and the pipe jacking parameters complete the recommendations. Read more...
Abstract: The book deals with almost all aspects of annular gap lubrication in pipe jacking - from ground conditions, through the properties of bentonite to the technical aspects. There is also a collection of calculations and suggested values for bentonite consumption quantities.
[-] The following 13 users Like gianniorlati's post:13 users Like gianniorlati's post
  • zrilek, blaze, oanm2000, levanduy, emmi, PinkPant, chenamoy, malc, Dell_Brett, munycamsec, tuanpecc1, kowheng, CAMSECT
