Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS D1.1/D1.1M: Structural Welding Code - Steel.
 anfaga
structural engineer
User ID: 12412
Threads: 39
Likes: 606 in 50 posts
Given Likes: 279
12-02-2015, 01:19 AM
AWS D1.1/D1.1M: 2015 Structural Welding Code - Steel
Author(s)/Editor(s): American Welding Society (AWS) D1 Committee on Structural Welding | Size: 7,32 MB | Format: PDF | Quality: Unspecified | Publisher: American Welding Society. | Year: 2015 | pages: 646 | ISBN: 978-0-87171-864-8
[Image: 68850967096040510361.jpg]
This code contains the requirements for fabricating and erecting welded steel structures. When this code is stipulated in contract documents, conformance with all provisions of the code shall be required, except for those provisions that the Engineer (see 1.4.1) or contract documents specifically modifies or exempts.
The code was specifically developed for welded steel structures that utilize carbon or low alloy steels that are 1/8 in [3 mm] or thicker with a minimum specified yield strength of 100 ksi [690 MPa] or less. The code may be suitable to govern structural fabrications outside the scope of the intended purpose. However, the Engineer should evaluate such suitability, and based upon such evaluations, incorporate into contract documents any necessary changes to code requirements to address the specific requirements of the application that is outside the scope of the code. The Structural Welding Committee encourages the Engineer to consider the applicability of other AWS D1 codes for applications involving aluminum (AWS D1.2), sheet steel equal to or less than 3/16 in [5 mm] thick (AWS D1.3), reinforcing steel (AWS D1.4), and stainless steel (AWS D1.6), strengthening and repair of existing structures (AWS D1.7), seismic supplement (AWS D1.8), and titanium (AWS D1.9). The AASHTO/AWS D1.5 Bridge Welding Code was specifically developed for welding highway bridge components and is recommended for those applications.
[-] The following 29 users Like anfaga's post:29 users Like anfaga's post
  • Hengki, faros3000, shaker, psk62, Umer.Aleem, pezhmankhan, ting tsai huang, malc, er.shyams, subin91, sabooryan, blaze, RyanRS, avge, PinkPant, jcbv, ascetic19, spiderthan, simanta, agelos100, Jackass, oanm2000, f_slikken, dovsky, Dell_Brett, bridgeengineer, stldtlr, tuanpecc1, kowheng
 rami1976
User ID: 34597
Threads: 341
Likes: 9,523 in 1,137 posts
Given Likes: 1387
12-02-2015, 04:55 PM
  • Size: 6.9 MB
  • Quality: Original preprint
This post has been made by CivilEA Post-Generator V2.3.1[/align]
[-] The following 11 users Like rami1976's post:11 users Like rami1976's post
  • oanm2000, Dell_Brett, slowet, temp1366, julioreptil, pram, blackjack, usman, Aviator, stldtlr, kowheng
 malc
User ID: 30599
Threads: 66
Likes: 1,520 in 155 posts
Given Likes: 15191
08-01-2018, 02:04 AM
Size: 6.89 MB | Format: PDF | Quality: Original preprint
[-] The following 12 users Like malc's post:12 users Like malc's post
  • jcbv, rendel_©, zrilek, PinkPant, febo927, oanm2000, promo8, tuanpecc1, Dell_Brett, faros3000, ascetic19, kowheng
 malc
User ID: 30599
Threads: 66
Given Likes: 15191
06-23-2020, 05:22 AM (This post was last modified: 06-24-2020, 02:28 PM by usman. Edit Reason: N/A )
AWS D1.1/D1.1M: 2020 Structural Welding Code - Steel
Author(s)/Editor(s): AWS | Size: 21.15 MB | Format: PDF | Quality: Original preprint | Publisher: AWS | Year: 2020 | pages: 664 | ISBN: 978- 1 -64322-087- 1 / 978- 1 -64322-088-8
[Image: 36044394517543250298.jpg]
This code covers the welding requirements for any type of welded structure made from the commonly used carbon andlow-alloy constructional steels. Clauses 1 through 1 1 constitute a body of rules for the regulation of elding in steel construction. There are eight normative and eleven informative annexes in this code. A Commentary of the code is included with the document.
The first edition of the Code for Fusion Welding and Gas Cutting in Building Construction was published by the American Welding Society in 1 928 and called Code 1 Part A. It was revised in 1 930 and 1 937 under the same title. It was revised again in 1 94 1 and given the designation D l .O. D l .O was revised again in 1 946, 1 963, 1 966, and 1 969. The 1 963 edition published an amended version in 1 965, and the 1 966 edition published an amended version in 1 967. The code was combined with D2.0, Specifications for Welding Highway and Railway Bridges, in 1 972, given the designation D l . 1 , and retitled AWS Structural Welding Code. D l . l was revised again in 1 975, 1 979, 1 980, 198 1 , 1 982, 1 983, 1 984, 1 985, 1 986, 1 988, 1 990, 1 992, 1 994, 1 996, 1 998, 2000, 2002, 2004, 2006, 2008 and 20 1 0. A second printing of D l . 1 :20 1 0 was published
in 201 1 . From 1 972 to 1 988, the D l.1 code covered the welding of both buildings and bridges.
Supersedes AWS Dl.1/Dl.1M:2015
[-] The following 27 users Like malc's post:27 users Like malc's post
  • subin91, temp1366, Dell_Brett, Aviator, babakfeyzi, CAMSECT, bridge, shaker, caifan, gulilero, tomtumx, kowheng, PinkPant, zrilek, carolinandra, tuanpecc1, faros3000, jcbv, blaze, Umer.Aleem, ascetic19, nhim4mat2006, fbx_rdnk, oyabun, Rapaig, jonygut, karthikeyans3d
 Veggeta
Guatemala
User ID: 114
Threads: 103
Likes: 4,273 in 520 posts
Given Likes: 402
06-23-2020, 06:02 PM
[-] The following 6 users Like Veggeta's post:6 users Like Veggeta's post
  • Dell_Brett, kowheng, PinkPant, zrilek, nhim4mat2006, Rapaig
 JUANCM
Member
User ID: 4958
Threads: 6
Likes: 343 in 44 posts
Given Likes: 23
07-01-2020, 03:53 PM
[-] The following 8 users Like JUANCM's post:8 users Like JUANCM's post
  • PinkPant, cheosmith, Dell_Brett, nhim4mat2006, oanm2000, oyabun, Rapaig, jonygut
09-02-2023, 11:41 AM (This post was last modified: 09-02-2023, 12:03 PM by Administrator. Edit Reason: N/A )
AWS D1.1/D1.1M-2020+Errata: Structural Welding Code—Steel
Includes all amendments and changes through Errata , March 2022
| Size: 21.51 MB| Format: PDF| Quality: Original preprint| Year: 24th Edition, 2020| pages: 680
  • babakfeyzi, jcbv, PinkPant, kowheng
  [CivilEA Exclusive] D10.4M-D10.4: GUIDE FOR WELDING AUSTENITIC STAINLESS STEEL PIPING AND TUBING poolmand 0 2,732 02-03-2025, 05:56 AM
  AWS D18.1/D18.1M: SPECIFICATION FOR WELDING OF AUSTENITIC STAINLESS STEEL TUBE AND P poolmand 0 2,513 01-22-2024, 09:43 AM
  AWS D9.1/D9.1M: SHEET METAL WELDING CODE poolmand 0 1,892 09-04-2023, 12:08 PM
  AWS D10.18M/D10.18: Guide for Welding Ferritic/Austenitic Duplex Stainless Steel Pipi poolmand 0 1,588 09-04-2023, 12:00 PM
  AWS D10.12M/D10.12: Guide for Welding Mild Steel Pipe poolmand 0 1,896 09-04-2023, 11:49 AM
  AWS D10.8: Recommended Practices for Welding of Chromium-Molybdenum Steel Piping and poolmand 0 1,712 09-04-2023, 11:40 AM
  AWS D8.10M: Specification for Automotive Weld Quality—Laser Beam Welding of Steel poolmand 0 1,620 09-03-2023, 06:50 AM
