Civil Engineering Association eBooks Structural Books Concrete Experiment and Calculation of Reinforced Concrete at Elevated Temperatures
 hich
User ID: 3732
Threads: 94
Likes: 5,003 in 418 posts
Given Likes: 101
06-04-2011, 09:56 PM
Author: Zhenhai Guo | Size: 27 MB | Format: PDF | Publisher: Butterworth-Heinemann | Year: June 2011 | pages: 336 | ISBN: 9780123869623
[Image: 08908419122741507316.jpg]
Concrete as a construction material goes through both physical and chemical changes under extreme elevated temperatures. As one of the most widely used building materials, it is important that both engineers and architects are able to understand and predict its behavior in under extreme heat conditions. Brief and readable, this book provides the tools and techniques to properly analysis the effects of high temperature of reinforced concrete which will lead to more stable, safer structures.
Based on years of the author's research, Reinforced Concrete at Elevated Temperatures four part treatment starts with an unambiguous and thorough exposition of the mechanical behaviors of materials at elevated temperature followed by a discussion of Temperature field of member sections, Mechanical behaviors of members and structures at elevated temperature, ending with Theoretical analysis and practical calculation methods. The book provides unique insight into:
* Coupling thermal-mechanical constitutive relation of concrete
* Exceptional analyses of beams and columns of rectangular section with three surfaces and two adjacent surfaces exposing to high temperature
* Measurement and analysis of redistribution of internal forces of statically indeterminate structure during heating-loading process
* Finite element analysis and calculation charts for two-dimensional temperature field of structural members
* Finite element analysis and simplified calculation method for reinforced concrete structure at elevated temperature
With this book, engineers and architects can effectively analyze the effect of high temperature on concrete and materials which will lead to better designs of fire resistant and damage evaluation and treatment after fire.
* Tools and techniques for analyzing the effects of high temperature on concrete and reinforcement materials.
* Measurement and analysis of redistribution of internal forces of statically indeterminate structure during the heating-loading process.
* Finite element analysis and calculation charts for two-dimensional temperature field of structural members.
* Finite element analysis and simplified calculation method for reinforced concrete structure at elevated temperature.
Table of Contents
Part One - Mechanical behaviors of materials at elevated temperature
Chapter 1 Strength of concrete at elevated temperature
Chapter 2 Deformation of concrete at elevated temperature
Chapter 3 Temperature - stress paths and coupling constitutive relation of concrete
Chapter 4 Mechanical behavior and constitutive relation of reinforcement at elevated temperature
Part Two - Temperature field of member section
Chapter 5 Temperature - time curve of fire and equation of heat conduction
Chapter 6 Theoretical analysis of temperature field
Chapter 7 Charts for temperature field on cross-section
Part Three - Mechanical behaviors of members and structures at elevated temperature
Chapter 8 Behaviors of flexural members at elevated temperature
Chapter 9 Behaviors of compressive members at elevated temperature
Chapter 10 Behaviors of statically indeterminate structures at elevated temperature
Part Four - Theoretical analysis and practical calculation method
Chapter 11 General mechanical characteristics of non-homogeneous section
Chapter 12 Finite element analysis of loading process for the structures
Chapter 13 Practical calculation methods for ultimate strengths of member and structure at elevated temperature
Chapter 14 Fire resistance analysis and damage grade evaluation of structure
Mirror:
[-] The following 44 users Like hich's post:44 users Like hich's post
  â€¢ ISTRAKTURA, nigema, Umer.Aleem, kowheng, Adam Smith, henrycv, chenamoy, waterman57, knrsa, Jackass, vardan, jcbv, concreteok, lamkin, ibg0203, Galileo, warbeast, oanm2000, Clouseau, ziggywas1, vvvv, seriousboy, zrilek, salahcivil, civilphongvan, momo2010, Dell_Brett, kmmh76, blaze, highcivil, faros3000, malc, mahfuzbangla, yutt, toa011, robertsas, Quantumm, thebeatles, Nilupa, amadoo02, paulocs, Grunf, jacs127, tuanpecc1
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,035 in 2,188 posts
Given Likes: 42494
06-17-2011, 04:54 PM
[-] The following 12 users Like Dell_Brett's post:12 users Like Dell_Brett's post
  â€¢ kowheng, highcivil, gatob, concreteok, mahfuzbangla, sodapas, robertsas, Quantumm, thebeatles, Nilupa, amadoo02, Grunf
 ska51
User ID: 11535
Threads: 382
Likes: 9,406 in 1,251 posts
Given Likes: 4017
06-18-2011, 05:42 PM
Mirrors (Size: 15.35 MB):
"Downstream is Weaker"
[-] The following 5 users Like ska51's post:5 users Like ska51's post
  â€¢ kowheng, Dell_Brett, Nilupa, draluka, ting tsai huang
 Flexi
User ID: 300
Likes: 5,440 in 422 posts
Given Likes: 110
06-18-2011, 06:27 PM
other link:
regards
Flexi
[-] The following 5 users Like Flexi's post:5 users Like Flexi's post
  â€¢ Dell_Brett, ruaumoko, thebeatles, Nilupa, lisine
Threads: 274
Likes: 12,075 in 1,233 posts
06-10-2012, 03:57 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 6 users Like pezhmankhan's post:6 users Like pezhmankhan's post
  â€¢ gulilero, gulilero, zrilek, Jackass, Dell_Brett, Nilupa
Threads: 154
12-12-2012, 11:36 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
PDF : 15.4 mb
[-] The following 3 users Like shadabg's post:3 users Like shadabg's post
  â€¢ Dell_Brett, mgdario, Nilupa
 mary
User ID: 31558
Threads: 37
Likes: 341 in 77 posts
Given Likes: 692
02-05-2013, 08:58 PM
PDF : 15.4 mb
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 4 users Like mary's post:4 users Like mary's post
  â€¢ Dell_Brett, ting tsai huang, isurya, Nilupa
 febo927
User ID: 23688
Threads: 105
Likes: 4,179 in 339 posts
Given Likes: 1279
07-17-2018, 01:48 PM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 12 users Like febo927's post:12 users Like febo927's post
  â€¢ tuanpecc1, emmi, caifan, PinkPant, rendel_©, Andrew seah, Umer.Aleem, milova, malc, oanm2000, axcel, Dell_Brett
 axcel
Bolivia
User ID: 11627
Threads: 15
Likes: 1,546 in 203 posts
Given Likes: 405
07-20-2018, 03:53 AM
[-] The following 5 users Like axcel's post:5 users Like axcel's post
  â€¢ PinkPant, oanm2000, Dell_Brett, cristi, moh_towhid
  Ciria - Guide to the Reinforced Construction of Reinforced Concrete in the Arabian Pe Jackass 1 4,002 02-23-2019, 11:34 AM
Last Post: Icivilea
  High-Strength Self-Consolidating Concrete Girders Subjected To Elevated Compressive F mahyarov 0 1,532 11-10-2012, 02:10 PM
Last Post: mahyarov
