Civil Engineering Association Software Software Product Bentley Products STAAD Foundation Advanced CONNECT Edition 08.04.00.21
 kirankumarklk
User ID: 29935
Threads: 76
Likes: 960 in 135 posts
Given Likes: 280
06-20-2018, 07:35 AM
[Image: 67656127299466327960.jpg]
A part of the STAAD family of products, STAAD Foundation Advanced can import and update the geometry, loads, and reactions from a STAAD.Pro model after which it will design the foundation type that we want at those supports. If the type happens to be a pilecap, it can determine a number of pile arrangements and design the pilecap for the arrangment that we choose. Data can also be brought from spreadsheets (e.g., such as that in Microsoft Office Excel®) into STAAD Foundation Advanced.
For mat foundation designs, STAAD Foundation Advanced creates a finite element model of the mat slab on grade. Soil is treated as spring supports whose stiffness is determined based on the size of the elements of the FE mesh. The model is then analyzed using STAAD.Pro, and, design of the slab is performed by aggregating the results across elements that are clustered into design strips.
In addition to the benefits that interoperability with STAAD.Pro provides, the program also functions in a standalone mode.
[Image: tips.png]
[align=left][Image: homepage.png]
[-] The following 19 users Like kirankumarklk's post:19 users Like kirankumarklk's post
  • rami1976, cace-01, RajaK, PinkPant, Andrew seah, malc, oanm2000, er.shyams, promo8, karthikeyans3d, Dell_Brett, monter, araza023, blaze, zego2000, kardels, zrilek, narendra, spat
 er.shyams
Member
United Kingdom
User ID: 36991
Threads: 45
Likes: 966 in 83 posts
Given Likes: 783
06-27-2018, 08:46 AM
Mirror links.
Instruction: After installation Replace original dlls with the patched dlls in the patched folder
[-] The following 10 users Like er.shyams's post:10 users Like er.shyams's post
  • blaze, rami1976, pedzaquino, caifan, PinkPant, Dell_Brett, oanm2000, cace-01, lasalleguy, tamboon
  Bentley STAAD.Pro Advanced 2024 poolmand 0 5,494 09-15-2024, 06:01 AM
  STAAD.Pro CONNECT Edition Update 3 (21.03.00.146) RajaK 7 12,774 07-27-2024, 03:40 AM
  Bentley MicroStation CONNECT Edition 2023 poolmand 2 6,238 10-08-2023, 12:24 PM
  Bentley STAAD.Pro CONNECT V23 poolmand 0 6,205 10-02-2023, 09:01 AM
  Bentley STAAD.Pro CONNECT Edition V22 kirankumarklk 12 22,688 07-05-2023, 07:52 AM
Last Post: Arigato
  Bentley.RCDC.Connect.Edition.11.02.00.200 kirankumarklk 0 4,931 04-02-2022, 11:14 AM
Last Post: kirankumarklk
  RCDC FE Connect Edition V4 Update 1 RajaK 1 6,914 03-28-2022, 06:28 AM
