Civil Engineering Association eBooks Journals, Papers and Presentations Large Deflection Inelastic Analysis of Space Trusses Using Generalized Displacement
 rendel_©
Philippine
User ID: 1138
Threads: 122
Likes: 2,115 in 214 posts
Given Likes: 2687
10-29-2009, 07:04 AM (This post was last modified: 10-29-2009, 07:51 PM by Dell_Brett.)
Large Deflection Inelastic Analysis of Space Trusses Using Generalized Displacement Control Method
[Image: bsk5huuxhofj10y8q8k.jpeg]
This paper presents the large deflection inelastic analysis of space truss structures including both geometric and material nonlinearities. The geometric nonlinearity is considered based on an updated Lagrangian formulation, while the material nonlinearity is accounted for by tracing a complete stress-strain relationship in the elastoplastic range. The nonlinear equilibrium equations are solved using an incremental-iterative scheme based on the generalized displacement control method. This algorithm can accurately trace the equilibrium path of nonlinear problems with multiple limit points and snap-back points. A computer program is developed to predict the inelastic post-buckling behavior of space trusses. Numerical results obtained from the developed program are compared with those reported in the literature to demonstrate the accuracy of the proposed procedure.
Download Links:
Password:
NOTICE:
The downloaded file must be renamed to:
Large-Deflection-Inelastic-Analysis-of-Space-Trusses-Using-Generalized-Displacement-Control-Method.pdf
(add(complete) the .pdf suffix)
(post edited)
[-] The following 10 users Like rendel_©'s post:10 users Like rendel_©'s post
  • vvvv, vvvv, kowheng, kowheng, cmorpar, cmorpar, subin91, subin91, zrilek, u4406014
  Response and Analysis of a Large Diameter Drilled Shaft Subjected to Lateral Loading mybest 1 6,046 10-21-2014, 08:57 AM
Last Post: Munykong
  Seismic Response Analysis of Large Liquid Storage Tank Considering Fluid-Structure In mybest 0 4,486 06-19-2013, 10:56 AM
Last Post: mybest
  Multivariate geostatistical approach to space-time data analysis arshiakh 0 3,823 04-08-2013, 05:34 PM
Last Post: arshiakh
  Global buckling analysis of plane and space thin-walled frames in the context of GBT yanburak 2 5,655 04-05-2012, 03:51 PM
Last Post: ssobhan
  Finite-Element Analysis of a Composite Frame under Large Lateral Cyclic Loading jamildear4u 0 3,479 02-17-2012, 04:41 AM
Last Post: jamildear4u
  Advanced inelastic static (pushover) analysis for earthquake applications cve_jule 0 4,386 09-02-2011, 12:16 PM
Last Post: cve_jule
  ASCE 100(7), 1974 - OTANI - Inelastic analysis of RC frame structures Fem.Ing 0 4,527 08-19-2011, 04:30 PM
Last Post: Fem.Ing
