Civil Engineering Association Software Software Product Autodesk Products Autodesk Civil 3D 2019 English
 rami1976
User ID: 34597
Threads: 341
Likes: 9,523 in 1,137 posts
Given Likes: 1387
04-13-2018, 10:16 PM (This post was last modified: 04-16-2018, 01:28 AM by Dell_Brett. Edit Reason: Only separate links for better understanding )
[Image: 53095546395079936784.jpg]
Autodesk Civil 3D software supports BIM (Building Information Modeling) for enhanced civil engineering design and construction documentation. Check our competitive price and contact us for volume discount.
Autodesk Civil 3D 2019 Design better civil infrastructure ,
Civil design
Perform faster design iterations and streamline time-consuming tasks.
Drafting and documentation
Connect design to documentation to help boost productivity and deliver higher quality.
Visualization and analysis
Use visualization, simulation, and water analysis tools integrated with the design process to improve project delivery and decision making.
Collaboration
Collaboration features help you overcome team coordination and workflow challenges within civil infrastructure projects.
What’s new:
Relative feature lines
Obtain elevation feature lines from a surface or relative to a surface, so feature lines update with changes to the surface.
Dynamic offset profiles
Create dynamic offset profiles using a default cross slope. Modify them by editing the profile properties.
Connected alignments
Create a new dynamically linked alignment and profile that transitions between 2 intersecting alignments and their profiles.
Pipe sizing and analysis
Resize pipes and reset inverts, and compute the energy and hydraulic grade lines per HEC-22 2009 standards.
and more...
[-] The following 9 users Like rami1976's post:9 users Like rami1976's post
  • joker™, zrilek, oanm2000, Dell_Brett, cace-01, snakes, febo927, karroumk, kourepai
Threads: 1,128
04-14-2018, 04:34 AM
[Image: 32231147561982001074.jpg]
[Image: 51627520772550659122.jpg]
[Image: 09866284580870913074.jpg]
  • PinkPant, oanm2000, Dell_Brett, cace-01, febo927
 rami1976
User ID: 34597
Threads: 341
Given Likes: 1387
05-22-2018, 12:34 PM (This post was last modified: 05-22-2018, 12:39 PM by rami1976.)
Storm and Sanitary Analysis (ADD on)
[Image: homepage.png]
  • febo927, oanm2000, monter, cheosmith, zrilek, Dell_Brett, ashcivilea, cace-01, karroumk
 rami1976
User ID: 34597
Threads: 341
Given Likes: 1387
05-22-2018, 01:56 PM
Infrastructure Parts Editor for Civil3D
[-] The following 8 users Like rami1976's post:8 users Like rami1976's post
  • febo927, oanm2000, cheosmith, zrilek, Dell_Brett, ashcivilea, monter, karroumk
 rami1976
User ID: 34597
Threads: 341
Given Likes: 1387
09-07-2018, 08:28 PM (This post was last modified: 09-07-2018, 08:32 PM by rami1976.)
Autodesk® Civil 3D® 2019.1 Update
Autodesk® MicroDrainage Utility 2019
  • zrilek, oanm2000, cace-01, Dell_Brett, karroumk, kourepai
Users browsing this thread: 7 Guest(s)
  Autodesk AutoCAD Civil 3D 2025 poolmand 2 5,570 12-02-2024, 01:09 PM
  Civil Survey Applications ( ex . Solutions ) Civil Site Design v24.0 for Autodesk Civ poolmand 1 4,950 05-06-2023, 02:32 PM
Last Post: Mobadi
  Autodesk AutoCAD Civil 3D 2022 poolmand 2 11,445 03-13-2022, 03:04 PM
Last Post: pilitro
  Autodesk AutoCAD Raster Design 2019 BennyP 5 10,482 09-22-2021, 09:07 AM
  Autodesk Autocad Civil 3D 2021 babakfeyzi 8 13,191 05-19-2021, 08:59 AM
Last Post: Vatsalbu89
  Autodesk x64 2019 Products Network License BennyP 1 6,249 09-24-2020, 06:37 AM
  Autodesk Civil 3D 2020 Nita1391 1 7,391 04-22-2019, 07:54 PM
