Civil Engineering Association Software Software Product Bentley Products STAAD Foundation Advanced CONNECT Edition 08.03.00.20
Threads: 1,118
02-11-2018, 05:31 PM
[Image: 10382050612026800775.jpg]
[Image: 18463344154236270654.jpg]
[Image: 06263590051088988588.jpg]
[Image: 53732985925567599386.jpg]
A part of the STAAD family of products, STAAD Foundation Advanced can import and update the geometry, loads, and reactions from a STAAD.Pro model after which it will design the foundation type that we want at those supports. If the type happens to be a pilecap, it can determine a number of pile arrangements and design the pilecap for the arrangment that we choose. Data can also be brought from spreadsheets (e.g., such as that in Microsoft Office Excelยฎ) into STAAD Foundation Advanced.
For mat foundation designs, STAAD Foundation Advanced creates a finite element model of the mat slab on grade. Soil is treated as spring supports whose stiffness is determined based on the size of the elements of the FE mesh. The model is then analyzed using STAAD.Pro, and, design of the slab is performed by aggregating the results across elements that are clustered into design strips.
In addition to the benefits that interoperability with STAAD.Pro provides, the program also functions in a standalone mode.
[Image: homepage.png]
๐Ÿ‘‰ CLICK HERE ๐Ÿ‘ˆ
[-] The following 29 users Like BennyP's post:29 users Like BennyP's post
  โ€ข zrilek, promo8, rezart, rami1976, ASEC, emmi, usman, maad59, PinkPant, kardels, blaze, cace-01, Andrew seah, jokerโ„ข, versiondemo, monter, abucasim, oanm2000, Dell_Brett, zbizafar, karthikeyans3d, ranger, piyush86, er.shyams, zego2000, febo927, mecheil.edwar, psppsp, spat
  Bentley STAAD.Pro Advanced 2024 poolmand 0 5,687 09-15-2024, 06:01 AM
  STAAD.Pro CONNECT Edition Update 3 (21.03.00.146) RajaK 7 13,262 07-27-2024, 03:40 AM
  Bentley MicroStation CONNECT Edition 2023 poolmand 2 6,478 10-08-2023, 12:24 PM
  Bentley STAAD.Pro CONNECT V23 poolmand 0 6,356 10-02-2023, 09:01 AM
  Bentley STAAD.Pro CONNECT Edition V22 kirankumarklk 12 23,031 07-05-2023, 07:52 AM
Last Post: Arigato
  Bentley.RCDC.Connect.Edition.11.02.00.200 kirankumarklk 0 5,024 04-02-2022, 11:14 AM
Last Post: kirankumarklk
  RCDC FE Connect Edition V4 Update 1 RajaK 1 7,026 03-28-2022, 06:28 AM
