Civil Engineering Association eBooks Structural Books Steel Unified Design of Steel Structures
 toa011
User ID: 9336
Threads: 131
Likes: 6,122 in 224 posts
Given Likes: 3356
08-08-2012, 03:02 PM
Unified Design of Steel Structures, 1st ed
Author: Louis F. Geschwindner | Size: 28 MB | Format: PDF | Quality: Unspecified | Publisher: Wiley | Year: 2007 | pages: 460 | ISBN: 0471475580
[Image: 38708518492381214564.jpg]
Study the design of steel building structures per the 2005 unified specification, ANSI/AISC 360-05 Specification for Structural Steel Buildings with this key resource. Author Louis F. Geschwindner first builds the foundation for steel design and then explores the various member types in more detail. He provides guidance for those new to the field as well as an excellent review for practicing engineers looking to learn the provisions of the unified specification and to convert their practice from the old specifications to the new one.
[-] The following 36 users Like toa011's post:36 users Like toa011's post
  β€’ cace-01, dwrred, miquan, hugoreynal, blaze, lamkin, odiclas, Veggeta, aslam, jokerβ„’, junaid, coxxxyboy, kowheng, subin91, terrorruban, w64bit, vvvv, slowet, warbeast, oanm2000, Quantumm, Ernest0, kmmh76, carolinandra, Dell_Brett, 88FeNIX, parhyang, yanburak, peixoto, dinu69in, monter, simanta, ranasanga, ssobhan, bigone, K.Lee
 junaid
User ID: 402
Threads: 197
Likes: 8,170 in 732 posts
Given Likes: 983
08-08-2012, 06:45 PM
[-] The following 29 users Like junaid's post:29 users Like junaid's post
  β€’ 3fan, david-smith, hignacio43, lednar_ved, sodapas, kowheng, gulilero, subin91, terrorruban, malc, marion33, Jackass, huan_maivn, w64bit, oanm2000, isurya, Quantumm, carolinandra, Dell_Brett, simanta, mgdario, chenamoy, knrsa, ruaumoko, cristi, peixoto, wanwin, 88FeNIX, bigone
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
07-12-2014, 09:59 AM
Mirrors; 1st ed.
[-] The following 16 users Like ssobhan's post:16 users Like ssobhan's post
  β€’ stigtg, PinkPant, malc, jcbv, bridgeengineer, oanm2000, cace-01, chairatpk, seriousboy, Dell_Brett, eliseo.as, gulilero, ting tsai huang, draluka, avge, bigone
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
11-13-2014, 10:21 AM
Unified Design of Steel Structures by Louis F. Geschwindner_1st Ed-0471475580
[-] The following 13 users Like bigone's post:13 users Like bigone's post
  β€’ amindoxiti, bridgeengineer, jcbv, PinkPant, stigtg, oanm2000, melekeen, ykhackhack, ibg0203, psk62, Dell_Brett, ebzr, simanta
 bigone
User ID: 4505
Threads: 85
Given Likes: 7145
07-27-2017, 07:52 PM (This post was last modified: 07-27-2017, 07:55 PM by bigone.)
[-] The following 14 users Like bigone's post:14 users Like bigone's post
  β€’ caifan, Ivan_1980, Nita1391, gulilero, highcivil, K.Lee, zrilek, PinkPant, jcbv, oanm2000, cace-01, zego2000, Dell_Brett, milova
 sabooryan
Senior Member
User ID: 163767
Threads: 77
Likes: 1,962 in 167 posts
Given Likes: 547
11-05-2018, 06:17 AM (This post was last modified: 11-05-2018, 09:37 AM by lisine. Edit Reason: Mod note )
Unified Design of Steel Structures 3rd edition
Author(s)/Editor(s): Geschwindner - liu - carter | Size: 55.4 MB | Format: PDF | Quality: Original preprint | Publisher: Wiley | Year: 2017 | pages: 626 | ISBN: 9781543207521
[Image: 89064871475417257182.jpg]
Unified Design of Steel Structures, 3rd edition, continues the unified LRFD and ASD approach to teaching structural steel design established in the first two editions. It addresses the design of steel structures for buildings as governed by the ANSI/AISC 360-16 Specification for Structural Steel Buildings, published by the American Institute of Steel Construction (AISC). It is intended primarily as a text for a first course in steel design for civil and architectural engineers. Such a course usually occurs in the third or fourth year of an engineering program. The book can also be used in a second, building-oriented course in steel design, depending on the coverage in the first course. In addition to its use as a textbook, it provides a good review for practicing engineers looking to learn the provisions of the latest specification or to convert their practice from any of the old specifications to the new specification. Users are expected to have a firm knowledge of statics and strength of materials and have easy access to the AISC Steel Construction Manual, 15th Edition. All examples that rely on LRFD and ASD provisions are fully presented, even if it means some duplication, so that regardless of approach being taught, there will be no need to refer to the other approach example. All homework problems that could be LRFD or ASD are presented both ways so that the instructor may choose the approach they want the student to follow. Subjects addressed include: principles of limit states design; load factors, resistance factors, and safety factors; tension member design; column or compression member design; beam or bending member design; plate girder design; design of beam-columns or members subjected to combined axial load and bending; bracing member design; composite member design; connection basics including bolts, welds, and connecting elements; design of shear connections, light bracing connections and direct bearing connections; design of moment connections; and basics of seismic design. Unified Design of Steel Structures, 3rd edition, also features multi-chapter problems and a new Integrated Design Project. Instructors can add a few, selected problems throughout the term, or include a full project, design of a four-story office building. Either way, all of the tools are here to help students learn how to apply the AISC Specification to the design of a structural steel building. Sample pages from the AISC Steel Construction Manual can be found throughout the book. Students can easily reference design aids and quickly learn how to use them. Keywords: steel design, beam design, column design, beam-column design, composite design, connection design, AISC
Mod note:
Link is premium only.
Always provide free alternative or next time your post will be deleted.
[-] The following 10 users Like sabooryan's post:10 users Like sabooryan's post
  β€’ munycamsec, pezhmankhan, tuanpecc1, pontiac, coxxxyboy, carolinandra, PinkPant, miquan, oanm2000, kowheng
 ziggywas1
User ID: 1224
Threads: 46
Likes: 1,478 in 124 posts
Given Likes: 637
11-05-2018, 08:35 AM (This post was last modified: 11-05-2018, 10:23 AM by lisine.)
3rd Edition
[-] The following 11 users Like ziggywas1's post:11 users Like ziggywas1's post
  β€’ avge, tuanpecc1, pontiac, cace-01, zrilek, Dell_Brett, munycamsec, PinkPant, sabooryan, miquan, oanm2000
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4631
11-05-2018, 09:44 AM (This post was last modified: 11-05-2018, 10:22 AM by lisine.)
More alternatives of 3rd Ed. (Mirror of previous post).
[-] The following 27 users Like lisine's post:27 users Like lisine's post
  β€’ tuanpecc1, pontiac, cace-01, blaze, Andrew seah, gulilero, promo8, subin91, carolinandra, jcbv, zrilek, Dell_Brett, munycamsec, caifan, moh_towhid, PinkPant, shaker, temp1366, ascetic19, rami1976, sabooryan, miquan, febo927, oanm2000, kamehameha, kowheng, monter
  Steel Structures Design; For Lateral and Vertical Forces carolinandra 3 4,659 01-07-2022, 02:44 AM
Last Post: Veggeta
  Ductile Design of Steel Structures 2nd lamkin 8 8,012 09-06-2021, 04:15 AM
  Ultimate Limit State Design of Steel-Plated Structures apocalipse 2 3,230 11-19-2020, 03:16 PM
Last Post: Kurucz
  ECCS - European Recommendations for the Design of Simple Joints in Steel Structures agelos100 0 1,962 05-14-2020, 09:19 AM
Last Post: agelos100
  Advanced Steel Design of Structures carolinandra 1 2,600 01-08-2020, 08:58 AM
Last Post: kirankumarklk
  Design of Joints in Steel and Composite Structures amindoxiti 3 3,928 12-17-2019, 06:53 AM
  Fatigue Design of Steel and Composite Structures: Eurocode 3: Design of Steel Structu asim99 3 3,986 04-30-2019, 01:29 PM
Last Post: carolinandra
