Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem ETABS - seismic weight
 juice
User ID: 108
Threads: 7
Likes: 362 in 68 posts
Given Likes: 176
02-04-2009, 11:28 PM
Here's another tip to newbie ETABS user; always make a rough estimate of your seismic weight and compare this to what ETABS is giving you. :idea:
[-] The following 5 users Like juice's post:5 users Like juice's post
  • Yasir, Yasir, ruaumoko, ruaumoko, blackjack
 aslam
Abu Dhabi
User ID: 64
Threads: 284
Likes: 7,707 in 755 posts
Given Likes: 2168
02-05-2009, 01:20 PM
Mass source :
Full dead load
some percentage of live load as per code.
[-] The following 1 user Likes aslam's post:1 user Likes aslam's post
  • levanduy
 juice
User ID: 108
Threads: 7
Given Likes: 176
02-05-2009, 11:36 PM
(02-05-2009, 01:20 PM)aslam Wrote: Mass source :
Full dead load
hi aslam, try to make an estimate of your seismic weight outside of ETABS' results for you to get a good feel on what ETABS had outputted.
 juice
User ID: 108
Threads: 7
Given Likes: 176
02-14-2009, 10:01 PM
ETABS newbies: check your definition of seismic mass source; it may be doubling your self-weight. :D
 robertsas
Indonesia
User ID: 655
Threads: 155
Likes: 5,665 in 416 posts
Given Likes: 3149
02-27-2009, 03:12 PM (This post was last modified: 02-27-2009, 03:24 PM by robertsas.)
My Opinion :
Separated your DEAD LOAD become Self Weight Dead Load and Super Imposed Dead Load.
The Dead Load for mass source is Super Imposed Dead Load (exclude Self Weight Dead Load).
I think double value of self weight because you do not separate the DEAD LOAD for calculate the mass source.
Please correct me if I wrong..
robertsasmita
[-] The following 1 user Likes robertsas's post:1 user Likes robertsas's post
  • levanduy
 Elijah
User ID: 126
Threads: 16
Likes: 299 in 34 posts
Given Likes: 18
02-27-2009, 05:29 PM
Look at http://www.youtube.com/watch?v=JRvoU-35SL8
[-] The following 1 user Likes Elijah's post:1 user Likes Elijah's post
  • levanduy
 juice
User ID: 108
Threads: 7
Given Likes: 176
02-28-2009, 12:34 AM
if you intend to use the third option for mass source definition, you have to separate self weight from your superimposed dead load. and define your mass source as superimposed dead load, part of live load. any mass defined in the model will also be included internally by ETABS aside from the building self weight.
regards,
juice
[-] The following 3 users Like juice's post:3 users Like juice's post
  • Yasir, Yasir, levanduy
 robertsas
Indonesia
User ID: 655
Threads: 155
Given Likes: 3149
02-28-2009, 12:44 AM (This post was last modified: 02-28-2009, 12:50 AM by robertsas.)
yes..
any other opinion from other member ?
regards,
robertsasmita
 piscesa
User ID: 375
Likes: 21 in 4 posts
Given Likes: 13
05-12-2009, 03:45 PM (This post was last modified: 05-12-2009, 03:47 PM by piscesa.)
Yups... that's right any additional dead load besides the selfweight needs to be separated to prevent double calculating of selfweight in mass source. Additional dead load which known as superimposed load should be added when third option of mass source is used with load factor 1 and life load should be added with load factor according to the spesific code (Usually 0.3).
CMIIW,
regards
 iceman84
User ID: 1829
Threads: 26
Likes: 419 in 154 posts
Given Likes: 402
#10
05-18-2009, 07:34 AM
I usually use the second option (from loads). All the coeficients are those given in the seismic codes (1 for dead loads and permanent loads and 0.4/0.3 for live loads). The third option can also be used (in this case only the dead load is 0, the rest of the loads have the same coeficients).
Pages (2): 1 2 Next »
