Civil Engineering Association Software Software Product Bentley Products Bentley RM Bridge Advanced + V8i 08.11.28.02
 Williams
Nigeria
User ID: 24556
Threads: 15
Likes: 422 in 87 posts
Given Likes: 779
12-23-2016, 01:08 PM (This post was last modified: 12-23-2016, 01:29 PM by Williams.)
Perform bridge design, analysis, and construction simulation to determine resiliency during seismic and natural events and analyze rolling stock. You can streamline massive analytical tasks and save time on complex engineering issues by taking a more integrated approach in the design and construction of your bridge systems.
Automate your complex design and engineering challenges with powerful specialized options:
   RM Bridge Advanced
   Fully integrate your modeling, analysis, and design for smooth project delivery.
Add-on modules for specialized activities such as advanced earthquake analysis, rolling stock analysis, erection control, simulation of wind-tunnel tests, wind buffeting, and others, include:
   RM Bridge Advanced Non-linear
   Provides advanced features for dealing with non-linearity of the structural behavior.
   RM Bridge Advanced Dynamic
   Perform special tasks in earthquake engineering and high-speed rail design with a non-linear time history algorithm.
   RM Bridge Advanced Construction
   Consider the influence of special money-saving construction techniques and provide exact data on deformation states throughout the erection process and camber requirements.
   RM Bridge Advanced Cable
   Calculate the non-linear effects of cable sagging on cable-stayed and suspension bridges.
   RM Bridge Advanced Wind
   Simulate wind tunnel tests and perform sophisticated wind buffeting analysis, as well as design code checks.
   RM Bridge Cast (stand-alone)
   Achieve maximum precision control for the casting process for precast segmental construction, especially on curved structures.
[Image: tips.png]
The Readme.txt file
RM Bridge CONNECT Edition_10.02.00.12
RM Bridge CONNECT Edition v10.01.00.02 fixes various issues and adds new functionalities such as:
   One step graphically supported pier definition
   RM Bridge Cast incorporated in RM Bridge Advanced
   RM Bridge View new functions
       Graphical presentation of the design check results
       3D Live Load Visualization
       2D Diagrams
       Tables
   Bentley OpenRoads and Open Bridge Modeler import functions
   Improved Steel design codes for Canadian Code HDBCS, American Code LRFD 7th edition and Indian Code IRC
   Improved Pushover Design
   Improved Response spectrum with selective Eigen-Mode superposition
The installation system was changed from side by side installation to generational updates:
   Any existing version of the same product generation (e.g. RM Bridge CONNECT Edition v10.00.00.02) will be replaced by the new product update.
   Installations of products from older generations like e.g. RM Bridge Advanced+ V8i v08.11.28.02 will stay untouched.
   This allows to publish updates and fixes easily and to reduce maintenance time.
It is part of the new Bentley CONNECT Edition branded generation of products and supports the Bentley CONNECT features like online services and project support capabilities.
Bentley RM Bridge View V8i.08.11.28.02
RM Bridge View is a new post-processing structure and results viewer module based on the MicroStation V8i Power Platform.
It is an optional Add-On for the RM Bridge Advanced product.
Please install it only, if you want to use the RM Bridge Advanced product and have a license for it!
The standalone application allows:
   Graphical display of structure and its beam results (colored surface, diagrams and deflected structure).
   Independent DGN post processing database which can be shared without RM database.
   Browsing of results during RM calculation.
   Usage of up to 8 views in parallel.
Typically you will access RMView in the RM Bridge Advanced main navigation tree. The external tool RM Bridge View will be started and the model and the results will be displayed.
RM Bridge View is licensed via the SELECT license. It's a child of the RM Bridge Advanced product. You will get automatically as many licenses of RM Bridge View as you own RM Bridge Advanced licenses. It has an own product id and usage logging.
[Image: tips.png]
RM View requires Prerequisites for Bentley Desktop Applications v08.11.09 to install and work and is not included.
[-] The following 9 users Like Williams's post:9 users Like Williams's post
  • araza023, abdulazizk, oanm2000, mgdario, Dell_Brett, RyanRS, jfjdm, bridgeengineer, pan5
12-26-2016, 10:44 AM
RM Bridge View V8i SS1 08.11.30.04
[Image: 22324256339042008953.jpg]
[Image: 75744139979820161208.jpg]
Bentley Systems Incorporated, the leading company dedicated to providing comprehensive software solutions for sustaining infrastructure, has released the V8i (SELECT Series 1) 08.11.30.04 version of RM Bridge View, is a new post-processing structure and results viewer module based on the MicroStation V8i Power Platform.
- Graphical display of structure and its beam results (colored surface, diagrams and deflected structure).
- Independent DGN post processing database which can be shared without RM database.
- Browsing of results during RM calculation.
- Usage of up to 8 views in parallel
[Image: comments.png]
Product: RM Bridge View
Version: V8i (SELECTSeries 1) 08.11.30.04
Supported Architectures: 64bit
Language: english
Supported Operating Systems: Windows 7even / 8 / 10
  • oanm2000, Dell_Brett, Williams, mgdario, bridgeengineer, pan5, macrem99
  Bentley STAAD.Pro Advanced 2024 poolmand 0 5,635 09-15-2024, 06:01 AM
  Bentley LEAP Bridge V8i SS7 14.00.00.19 rami1976 0 5,536 03-24-2016, 05:10 AM
  Bentley Multiframe Advanced V8i SS3 17.00.04.08 x86+x64 build odiclas 1 10,185 02-15-2016, 06:27 AM
  Bentley Staad Foundation Advanced CONNECT Edition RajaK 1 7,926 01-16-2016, 10:51 AM
Last Post: Dell_Brett
  Bentley LEAP Bridge Steel V8i SS2 01.02.00.01 PinkPant 0 5,484 08-19-2015, 10:06 AM
Last Post: PinkPant
  Bentley LEAP Bridge Suite v8i (SELECT series 1) 09.00.03.02 (Trial) BennyP 0 7,099 07-28-2010, 03:01 PM
