Civil Engineering Association Software Software Product Autodesk Products Autodesk REVIT 2017 (x64)
Threads: 1,118
04-16-2016, 01:22 AM
[Image: 21093749122594722902.gif]
[Image: 40220607077281138002.gif]
[Image: 77646154600580883414.gif]
[Image: 58239447757067790105.gif]
Revit is a design and documentation platform that supports the design, drawings, and schedules required for building information modeling (BIM). BIM delivers information about project design, scope, quantities, and phases when you need it.
๐Ÿ‘‰ CLICK HERE ๐Ÿ‘ˆ
[-] The following 27 users Like BennyP's post:27 users Like BennyP's post
  โ€ข cace-01, iamnowtheone, RajaK, Dell_Brett, stosto6666, temp1366, oanm2000, PinkPant, bridgeengineer, kkding, zrilek, faros3000, gafi, Rodmo376, rami1976, blaze, TurboXUser, yutt, promo8, malc, bluefish80, raymelito, mowafi3m, tudao, Batman07, deltalead, kristoffer_89
Away  bridgeengineer
Poland
User ID: 93214
Threads: 47
Likes: 1,023 in 110 posts
Given Likes: 4769
04-16-2016, 03:24 PM (This post was last modified: 04-16-2016, 03:26 PM by bridgeengineer.)
here are links for Revit LT version
Sorry I can not post print screens because my system is 32bit win7
[-] The following 3 users Like bridgeengineer's post:3 users Like bridgeengineer's post
  โ€ข zrilek, pousin, mowafi3m
 temp1366
User ID: 85519
Threads: 80
Likes: 1,544 in 165 posts
Given Likes: 742
05-02-2016, 08:13 AM (This post was last modified: 05-02-2016, 08:25 AM by temp1366. Edit Reason: N/A )
Structural Analysis Toolkit 2017
The Structural Analysis Toolkit for Autodeskยฎ Revitยฎ software is a suite of tools that supports the Building Information Modeling (BIM) process and allows structural engineers to analyze structures from within the Revit environment.
Using this toolkit structural designers and engineers can optimize their workflows in the cloud and on the desktop by using the analytical model built in Revit to conduct cloud-based structural analysis with access to Autodesk 360 services and by extending the Revit model to Autodesk Robot Structural Analysis Professional software or supported third party analysis solutions. Once complete, analysis results can be easily stored and explored in the Revit environment.
The toolkit contains the following items:
  • Link with Autodeskยฎ Robotโ„ข Structural Analysis Professional
Use it to perform advanced analyses after transferring a Revit analytical model to Autodeskยฎ Robotโ„ข Structural Analysis Professional (Robot). It is a structural analysis and design software application. Use it to perform linear and nonlinear analyses of any structure type and shape and to design steel, concrete, and timber elements of a structure. Autodeskยฎ 360 Structural Analysis for Revit
  • Autodeskยฎ 360 Structural Analysis for Revit
Use it to perform a cloud-based structural analysis of a Revit analytical model. You can perform a static analysis and a gravity analysis. Explore results in the Revit project or on the Autodeskยฎ 360 S Analysis Professional structural Analysis website.
  • Structural Results Storage and Exploration tools
Use Results Manager to review, download, or remove results packages. Use Results Explorer to display result maps and diagrams on elements of an analytical model in Revit.
[Image: tips.png]
This app uses a custom installer (and not the standard App Store installer).
[-] The following 9 users Like temp1366's post:9 users Like temp1366's post
  โ€ข PinkPant, blaze, oanm2000, stosto6666, zrilek, Dell_Brett, cace-01, TurboXUser, mowafi3m
 temp1366
User ID: 85519
Threads: 80
Given Likes: 742
05-02-2016, 10:01 AM
Advance Steel 2017 Extension
With Advance Steel 2017 Extension, Autodeskยฎ Revitยฎ 2017 users can quickly connect their models to Advance Steel 2017 using the export, import and synchronize functionalities to transfer the model BIM data in LOD350 for Structural Steel. This interoperability helps users to more rapidly produce general arrangement drawings, fabrication drawings, BOMs, and NC files for steel structures.
Using synchronization of BIM data between applications users can update the modifications without having to reimport the entire structure. Synchronization also reduces the risk of potential errors by offering the possibility to track changes made on the same model in different applications.
Using Advance Steel 2017 Extension, the BIM data from the Revit model can be imported or exported also in other formats such as SDNF (Version 2.0 and Version 3.0), CIS2 and PSS.
[Image: homepage.png]
[-] The following 6 users Like temp1366's post:6 users Like temp1366's post
  โ€ข oanm2000, zrilek, Dell_Brett, cace-01, TurboXUser, mowafi3m
 temp1366
User ID: 85519
Threads: 80
Given Likes: 742
05-02-2016, 11:13 AM (This post was last modified: 05-02-2016, 12:02 PM by temp1366. Edit Reason: N/A )
Export to ETABS
Nasserโ€™s Tools are custom plug-ins created to enhance Autodesk Revitยฎ Integration with the Structural Analysis Software ETABS. This plug-in also has some other functions which structural engineers would find useful.
Here are some of the Toolโ€™s Features:
The following elements will be exported to ETABS (as a *.e2k file):
ยท ย  ย  ย  ย  Columns
ยท ย  ย  ย  ย  Braces
ยท ย  ย  ย  ย  Beams
ยท ย  ย  ย  ย  Walls
ยท ย  ย  ย  ย  Slabs
ยท ย  ย  ย  ย  Slab Openings
ยท ย  ย  ย  ย  Grids
ยท ย  ย  ย  ย  Levels
ยท ย  ย  ย  ย  Rigid Links
Note:
* If the Script does not recognize the Section Family, it will export it as a null element which can later be edited in ETABS.
* You have the option of rotating (about the Global Z Axis) your analytical model in Revit when exporting to ETABS (without changing your Revit model's geometry).
* The tool is a one way tool and cannot be used to reimport your ETABS model back into Revit.
* You have the option of exporting All Elements, Selected Elements or Selected Work sets.
[Image: tips.png]
This Tool has been revised to be compatible with Autodeskยฎ Revitยฎ 2013, 2014 2015, 2016 and 2017.
[-] The following 5 users Like temp1366's post:5 users Like temp1366's post
  โ€ข oanm2000, zrilek, Dell_Brett, cace-01, mowafi3m
 temp1366
User ID: 85519
Threads: 80
Given Likes: 742
05-02-2016, 12:59 PM
Reinforcement sketch
This addin allows you to create sketches for reinforcement. Thumbnails are generated as graphics files like png and placed in a separate folder with the project file.
When changes are made to the project you should run the command to update the schedule.
[Image: tips.png]
Compatible with Autodesk Revit Version: 2017, 2016, 2015
[-] The following 8 users Like temp1366's post:8 users Like temp1366's post
  โ€ข oanm2000, PinkPant, zrilek, Dell_Brett, cace-01, monter, TurboXUser, mowafi3m
 davidc
Malaysia
User ID: 173237
Likes: 3 in 1 posts
Given Likes: 0
08-24-2016, 09:55 PM
Please reload, dead links for post #4,#5 and #6
[-] The following 3 users Like davidc's post:3 users Like davidc's post
  โ€ข gafi, apocalipse, vinnunsam
 KhaLed-S.E
Egypt
User ID: 48176
Threads: 39
Likes: 1,063 in 98 posts
Given Likes: 490
10-18-2016, 07:30 PM
The 4 Previous EXT.&Tools
[-] The following 15 users Like KhaLed-S.E's post:15 users Like KhaLed-S.E's post
  โ€ข temp1366, Dell_Brett, oanm2000, zrilek, cace-01, PinkPant, raymelito, bridgeengineer, malc, bao2004, mowafi3m, Williams, apocalipse, Batman07, melekeen
 tudao
User ID: 46591
Likes: 1 in 1 posts
Given Likes: 8
11-25-2016, 06:42 PM (This post was last modified: 11-25-2016, 06:44 PM by tudao. Edit Reason: N/A )
Where do I find the keygen
Moderator Note:
There's no keygen.
It's a "plug in" for REVIT. The software must be previously installed and patched.
[-] The following 1 user Likes tudao's post:1 user Likes tudao's post
  โ€ข Rihpi
  Autodesk Revit 2022 poolmand 9 12,164 11-16-2021, 08:14 AM
  Autodesk Revit LT 2021.1 (x64) Multilanguage BennyP 1 5,221 02-22-2021, 03:40 PM
  Autodesk Revit 2019 and Revit LT 2019 BennyP 7 15,780 02-12-2019, 02:02 PM
  AUTODESK REVIT STRUCTURE V2014 WIN32/WIN64-ISO BennyP 4 11,681 04-21-2018, 09:51 PM
Last Post: jokerโ„ข
  Autodesk Revit 2016 (x64) BennyP 1 9,685 10-19-2017, 09:10 PM
Last Post: jokerโ„ข
  AUTODESK REVIT MEP V2014-ISO (x32/x64) BennyP 1 6,640 10-15-2017, 01:33 PM
Last Post: jokerโ„ข
  AUTODESK REVIT ARCHITECTURE V2014-ISO (x32/x64) BennyP 1 6,774 10-15-2017, 01:31 PM
Last Post: jokerโ„ข
