Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Books and Codes Request [REQUEST] BS 8597:2015 Steels for the reinforcement of concrete. Reinforcement couplers. Requir
[Request] BS 8597:2015 Steels for the reinforcement of concrete. Reinforcement couplers. Requir
 [email protected]
Malaysia
User ID: 94339
Threads: 3
Likes: 0 in 0 posts
Given Likes: 1
04-11-2016, 01:17 PM
  • Article/eBook Full Name:
  • BS 8597:2015 Steels for the reinforcement of concrete. Reinforcement couplers. Requirements and test methods
  • Publish Date:
  • 2015
  • ISBN:
  • 978 0 580 83058 7
  • Published By:
  • BSI
  • Related Links:
  • Code:
  â€¢
04-12-2016, 03:52 AM
[Image: 59192472053539358335.jpg]
  • Author(s): Technical Committee ISE/104, Concrete reinforcing and pre-stressing steels
  • Published By: BSI
  • Published Year: 2015
  • Size: 0.7 MB
  • Quality: Original preprint
  • Abstract: This British Standard specifies requirements and test methods for steel reinforcement couplers (hereafter called couplers) to be used for the mechanical splicing of steel reinforcing bars. It specifies requirements for couplers to be used for mechanical splices in reinforced concrete structures under predominantly static loads and additional requirements for couplers to be used in elements of structures subject to high cycle elastic fatigue loading. It also specifies requirements for the evaluation of conformity of couplers.
    This British Standard does not specify requirements for couplers which are to be used for mechanical splices in reinforced concrete structures subject to low cycle loading in the elastic-plastic range.
    This British Standard specifies performance requirements for couplers. The couplers are tested as part of a mechanical splice between two lengths of reinforcing steel, manufactured in accordance with BS 4449 or BS 6744. The performance tests specified are therefore for mechanical splices incorporating the coupler being assessed. The requirements of this standard apply to the manufacture of couplers and not the assembly or installation of mechanical
    splices on site.
[/align]
  â€¢ lamkin, zrilek, concreteok, f_slikken, Jackass, bridgeengineer, malc, PinkPant, Dell_Brett, sodapas, piseth
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 38
Likes: 4,964 in 638 posts
Given Likes: 3501
01-29-2021, 01:01 AM
concrete solution advocate
[-] The following 9 users Like concreteok's post:9 users Like concreteok's post
  â€¢ piseth, blaze, pezhmankhan, PinkPant, Aviator, babakfeyzi, Dell_Brett, Antony, KMABD
  [REQUEST] Concrete Manual Based on the 2015 IBC and ACI 318-14 OSHO 1 2,196 01-30-2022, 08:59 PM
Last Post: carolinandra
  [REQUEST] International Building Code 2015 (IBC 2015) aslam 5 3,808 05-31-2016, 12:21 PM
Last Post: psppsp
