Civil Engineering Association eBooks Structural Books Steel SHS Welding
SHS Welding
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1388
04-01-2016, 10:48 PM
SHS Welding
Author(s)/Editor(s): Corus Tubes | Size: 1.7 MB | Format: PDF |  Publisher: Structural & Conveyance Business | Year: 2005
[Image: 39045480872365473606.jpg]
Welding represents the major method by which structural hollow sections are joined. When considering welding, the most essential requirement is that the deposited weld should have mechanical properties not less than the minima specified for the sections being joined.
Welding is a subject which encompasses the materials, types of joint, welding conditions/positions and the required quality or mechanical properties of the finished joint. The recommendations made in this publication are thus of guidance towards good practice and should be used in conjunction with other standards, especially EN 1011*: Welding - Recommendations for welding of metallic materials, ENV 1090 and EN 29692.
[-] The following 12 users Like rami1976's post:12 users Like rami1976's post
  • tomtumx, f_slikken, milova, subin91, agelos100, Dell_Brett, zrilek, oanm2000, K.Lee, malc, anfaga, kowheng
 gulilero
Italy
User ID: 14057
Threads: 102
Likes: 4,989 in 647 posts
Given Likes: 6732
04-02-2016, 05:14 AM
The link below is a clean pdf
[-] The following 22 users Like gulilero's post:22 users Like gulilero's post
  • jcbv, Andrew seah, blaze, Dell_Brett, PinkPant, zrilek, oanm2000, melekeen, mgdario, er.shyams, psk62, Trishu999, knrsa, Jackass, Wijono, malc, cace-01, sodapas, anfaga, yanburak, slowet, febo927
  Handbook of Structural Welding, Processes, materials and methods used in the welding arshiakh 2 2,989 02-11-2015, 04:07 AM
Last Post: Veggeta
