Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 6089:Guide to assessment of concrete strength in existing structures
Threads: 1,298
05-13-2011, 11:58 AM (This post was last modified: 02-14-2022, 05:37 AM by Administrator.)
BS 6089:1981 Guide to assessment of concrete strength in existing structures
Author: Committee B/525/2 | Size: 0.9 MB | Format: PDF | Publisher: BSI | Year: 1981 | pages: 16 | ISBN: 058012441X
[Image: 65697397348809540666.jpg]
Guidance on planning and conducting investigations including a description of test methods and interpretation of results. Ilustrates the relationship between strength of standard test specimens and that in a structure.
  • Hengki, peixoto, kowheng, Jackass, techno, Dell_Brett, toa011, zrilek, monter, sivlad, jcbv, gulilero, oanm2000, vvvv, er.shyams, vinnunsam, levanduy, siscivil
Threads: 54
11-07-2012, 05:39 AM (This post was last modified: 11-07-2012, 05:40 AM by andersen3.)
word:
or
[-] The following 2 users Like andersen3's post:2 users Like andersen3's post
  • Dell_Brett, siscivil
Threads: 1,298
BS 6089 - new links:
  • Dell_Brett, lisine, oanm2000, mahyarov, zrilek, chenamoy, Trishu999, jayvijayyy, siscivil
Threads: 54
07-21-2014, 10:43 AM
new links
password
[-] The following 7 users Like andersen3's post:7 users Like andersen3's post
  • zrilek, malc, vvvv, Mohammad6299, er.shyams, Dell_Brett, pram
Threads: 1,298
03-24-2015, 06:01 PM
BS 6089:2010 Assessment of in-situ compressive strength in structures and precast concrete components – Complementary guidance to that given in BS EN 13791
Author: Technical Committee B/517 | Size: 1.62 MB | Format: PDF | Quality: Original preprint | Publisher: BSI | Year: 2010 | pages: 34 | ISBN: 9780580672743
[Image: 19901569259571281211.jpg]
This British Standard complements BS EN 13791, which gives methods for determining the characteristic in-situ compressive strength in concrete structures and precast concrete components based on:
a) core testing;
b) rebound hammer, ultrasonic pulse velocity and pull-out force measurements after a relationship with core strength has been determined for the particular concrete under investigation.
This British Standard provides additional guidance on:
• planning an investigation (see Clause 5);
• selection of test methods (see 5.4);
• selection of the test locations (see 5.5 and 5.6);
• assessment of individual core results within a group (see 6.1);
• assessment where the strength of concrete based on test specimens is in doubt (see Clause 7).
In addition, this British Standard provides guidance on the following cases not covered by BS EN 13791:
• assessment of an unknown structure using a margin based on the t-statistic (see 6.2);
• use of indirect methods without correlation to core strength (see 6.3);
• relative testing, i.e. comparison of a volume of concrete under investigation with concrete in similar elements that has been accepted (see 6.4);
• action when the producer has declared nonconformity (see Clause 8).
This British Standard does not provide guidance on:
• the use of cores with a diameter of less than 50 mm or the use of microcores;
• whether a structure has adequate durability;
• the use of in-situ testing as an alternative to conformity testing based on test specimens.
[-] The following 17 users Like ir_71's post:17 users Like ir_71's post
  • avscorreia, zrilek, oanm2000, Dell_Brett, Mohammad6299, milova, concreteok, cace-01, f_slikken, Trishu999, lisine, PinkPant, peixoto, malc, titko, nhim4mat2006, siscivil
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 51
Likes: 4,964 in 638 posts
Given Likes: 3501
03-31-2016, 05:41 AM
concrete solution advocate
[-] The following 10 users Like concreteok's post:10 users Like concreteok's post
  • blaze, er.shyams, PinkPant, bridgeengineer, f_slikken, jcbv, Dell_Brett, oanm2000, Andrew seah, knrsa
Threads: 1,298
04-01-2016, 12:41 PM
[Image: 48959414210973203515.jpg]
[*]Author(s): Technical Committee B/517, Concrete
[*]Published By: BSI
[*]Published Year: 2010
[*]Size: 2.09 MB
[*]Quality: Original preprint
[*]Abstract: This British Standard complements BS EN 13791, which gives methods for determining the characteristic in-situ compressive strength in concrete structures and precast concrete components based on:
a) core testing;
[/align]
  • blaze, jcbv, subin91, knrsa, f_slikken, Dell_Brett, PinkPant, siscivil
Threads: 1,298
12-25-2016, 06:52 AM
  • sabooryan, zrilek, cace-01, blaze, malc, Dell_Brett, hatkam, Aviator, haseef86, Hengki, PinkPant
Threads: 750
Likes: 8,270 in 1,355 posts
Given Likes: 88
02-14-2022, 05:40 AM
[-] The following 11 users Like poolmand's post:11 users Like poolmand's post
  • jcbv, Aviator, Dell_Brett, babakfeyzi, CAMSECT, oanm2000, zrilek, cace-01, kowheng, PinkPant, nhim4mat2006
  BS 7608:1993 Code of practice for fatigue design and assessment of steel structures ir_71 5 4,942 12-15-2015, 09:46 AM
Last Post: Dobblo
