Civil Engineering Association eBooks Structural Books Analysis & Design Design of Steel-to-Concrete Joints Design Manual I
 rami1976
User ID: 34597
Threads: 341
Likes: 9,523 in 1,137 posts
Given Likes: 1387
01-17-2016, 09:59 AM
Design of Steel-to-Concrete Joints -Design Manual I
Author(s)/Editor(s): František Wald ,Jan Hofmann & Ulrike Kuhlmann | Size: 3.5 MB | Format: PDF | Quality: Original preprint | Year: 2014 | pages: 179
[Image: 96721066030496929074.jpg]
The mixed building technology allows to utilise the best performance of all structural materials available such as steel, concrete, timber and glass.Engineers of steel structures in practice are often faced with the question of economical design of steel to concrete joints, because some structural elements, such as foundations, stair cases and fire protection walls, are optimal of concrete. A gap in knowledge between the design of fastenings in concrete and steel design was abridged by standardized joint solutions developed in the INFASO project, which profit from the advantage of steel as a very flexible and applicable material and allow an intelligent connection between steel and concrete building elements.
The requirements for such joint solutions are easy fabrication, quick erection, applicability in existing structures, high loading capacity and sufficient deformation capacity. One joint solution is the use of anchor plates with welded headed studs or other fasteners such as post-installed anchors. Thereby a steel beam can be connected by butt straps, cams or a beam end plate connected by threaded bolts on the steel plate encased in concrete.
[-] The following 15 users Like rami1976's post:15 users Like rami1976's post
  • amindoxiti, f_slikken, stosto6666, zrilek, milova, bridgeengineer, agelos100, oanm2000, ting tsai huang, ssobhan, igor1234, psk62, allagui10, stigtg, zego2000
 sabooryan
Senior Member
User ID: 163767
Threads: 77
Likes: 1,962 in 167 posts
Given Likes: 547
01-17-2016, 02:51 PM
forum standard mandatory password should be used.
[-] The following 7 users Like sabooryan's post:7 users Like sabooryan's post
  • Kurucz, subin91, hmwere, cace-01, ykhackhack, oanm2000, chrono146
 civilnextgen
User ID: 45875
Likes: 32 in 3 posts
Given Likes: 15
01-17-2016, 03:20 PM
[-] The following 23 users Like civilnextgen's post:23 users Like civilnextgen's post
  • cace-01, zrilek, Dell_Brett, gulilero, oanm2000, concreteok, telecivil, Andrew seah, tomtumx, rendel_©, ebzr, blaze, slowet, avge, ssobhan, yanburak, cordoba123, sodapas, psk62, Kurucz, knrsa, simanta, konstobo
 rami1976
User ID: 34597
Threads: 341
Given Likes: 1387
01-17-2016, 04:22 PM (This post was last modified: 01-17-2016, 04:52 PM by rami1976.)
Design of Steel-to-Concrete Joints -Design Manual II
[-] The following 16 users Like rami1976's post:16 users Like rami1976's post
  • Jackass, cace-01, rezart, jcbv, carolinandra, Dell_Brett, oanm2000, telecivil, ting tsai huang, malc, bridgeengineer, sodapas, draluka, stigtg, zrilek, subin91
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 50
Likes: 4,962 in 637 posts
Given Likes: 3501
01-18-2016, 12:47 AM
for those who are not keen on hulkload and having problem with uploadboy
manual I (manual II posted in #3) direct link
concrete solution advocate
[-] The following 29 users Like concreteok's post:29 users Like concreteok's post
  • telecivil, Andrew seah, oanm2000, Dell_Brett, tomtumx, malc, rendel_©, ebzr, zrilek, Trishu999, ruaumoko, PinkPant, Jackass, araza023, mgdario, yanburak, cordoba123, sodapas, ykhackhack, chairatpk, Kurucz, draluka, promo8, zego2000, heogay43, simanta, monter, harsono, konstobo
  Aluminum Design Manual poolmand 0 3,762 05-03-2023, 09:17 AM
  Design of Hybrid Structures: Where Steel Profiles Meet Concrete carolinandra 0 4,284 04-07-2023, 02:54 PM
Last Post: carolinandra
  Tall building design: steel, concrete, and composite systems asim99 3 8,762 12-23-2021, 01:10 PM
Last Post: babakfeyzi
  Principles of Structural Design: Wood, Steel, and Concrete, Second Edition cace-01 4 11,526 11-24-2019, 01:32 PM
  Technical Manual: Seismic Design for Buildings jamildear4u 1 6,559 05-13-2019, 01:55 AM
  Structures Engineering Design Manual ir_71 1 8,142 05-13-2019, 01:24 AM
  SDI diaphragm design manual 4th edition sabooryan 2 8,333 11-17-2018, 08:22 AM
Last Post: gianniorlati
