Civil Engineering Association Software Software Product Csi Products CSiCol CSiCOL V9
CSiCOL V9
Threads: 274
Likes: 12,075 in 1,233 posts
04-14-2014, 07:18 AM (This post was last modified: 08-23-2022, 09:07 AM by Dell_Brett.)
CSiCOL v9.0.0
[Image: 13186039211593277183.png]
CSI CSiCOL is a comprehensive software package used for the analysis and design of columns. The design of columns of any concrete, reinforced concrete, or composite cross-section can be carried out by the program. CSI CSiCOL provides a 'Quick Design Wizard' tool that guides the users step-by-step, through the whole process of column design. This makes the design process simple, organized and efficient. The design can be carried out in accordance with ACI-318-02, ACI-318-99, BS8110 or CSA A-23.3-94 codes.
[Image: tips.png]
[align=left][Image: download.png]
This post has been made by CivilEA Post-Generator v2.2.0[url=http://postgen.civilea.com/index.html][/url]
[-] The following 36 users Like pezhmankhan's post:36 users Like pezhmankhan's post
  • rezart, giga, Dell_Brett, avscorreia, aslam, melkat, ibg0203, joker™, PinkPant, cace-01, amareen2000, learner20, MOSS2000, Andrew seah, dl4all, TAFATNEB, malc, Diquan, bigone, mowafi3m, ssobhan, Rodmo376, oanm2000, ebzr, ykhackhack, pohpo, chairatpk, melekeen, Rami11, narendra, harsono, icmrb7777, ibmarin, cenlara, zrilek, blaze
04-14-2014, 11:17 AM
CSI CSiCOL v9.0.0
[Image: 76463158143414131714.gif]
CSiCOL is a comprehensive software package used for the analysis and design of columns. The design of columns of any concrete, reinforced concrete, or composite cross-section can be carried out by the program. CSiCOL provides a 'Quick Design Wizard' tool that guides the users step-by-step, through the whole process of column design. This makes the design process simple, organized and efficient. The design can be carried out in accordance with ACI-318-11, ACI-318-08, ACI 318-05, ACI 318-02, ACI 318-99, BS8110, CSA A-23.3-04, CSA A23.3-94, Eurocode 2-2004 and IS 456-2000 codes.
CSiCOL is capable of handling an unlimited number of load combinations both for sway and non-sway conditions. The design actions may be specified directly or may be computed by the program using the moment magnification method. The design and analysis take into account the slenderness effects. Sway or non-sway condition checks may also be performed by the program as specified by the selected design code. Moreover, CSiCOL is capable of determining the Effective Length Factor based on the framing and end conditions of the column. CSiCOL output includes the capacity interaction surface, load-moment curves, moment-moment curves, moment-curvature curves for various failure criteria, combined axial-flexural elastic stress contours, rebar stresses, cracked section stresses, load point location, capacity vector, neutral axis depth and orientation, etc. Reports may be created as part of the output for the analysis and design process. The reports may be customized by adding information and graphics of your choice.
CSiCOL provides several predefined parametric shapes, including a variety of solids, hollow, and flanged shapes, in addition to a large collection of Standard Steel Database Shapes, which can be used in composite columns. It is easy to merge, edit and draw Shapes to suit geometry requirements and create complex cross-sections. The program provides tools for the alignment, stacking, and placement of these Shapes. Rebars can be placed anywhere (corner, perimeter, sides, circle, irregular, etc.) in the cross-section using several addition and placement tools. Standard (ASTM, Metric, and Imperial ) as well as user defined rebar sets may be used
[Image: tips.png]
[-] The following 20 users Like TAFATNEB's post:20 users Like TAFATNEB's post
  • Diquan, joker™, bigone, chenamoy, pedzaquino, Ultra Zone, oanm2000, slowet, mgdario, toa011, zipatton, simanta, faros3000, ykhackhack, pohpo, wa_sin_29, knrsa, Arigato, Rami11, ibmarin
Away  joker™
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
04-14-2014, 11:28 AM
Only VIP members can send their own code by PM and I will generate the license file works for 900 days
No limits to creativity
[-] The following 8 users Like joker™'s post:8 users Like joker™'s post
  • oanm2000, Dell_Brett, milvio, concreteok, zipatton, ykhackhack, bigone, miquan
 zipatton
User ID: 1594
Threads: 2
Likes: 251 in 66 posts
Given Likes: 123
04-15-2014, 05:06 AM
Hi Gentlemen,
by using Run-as-Date software, it works permanently, without limitations of days.
it works for me on Windows7.
Zippat
[-] The following 10 users Like zipatton's post:10 users Like zipatton's post
  • ykhackhack, bigone, cace-01, dl4all, warbeast, milvio, inge911, Williams, zrilek, Wiya Civil
 zrilek
User ID: 3860
Threads: 10
Likes: 337 in 59 posts
Given Likes: 22026
07-16-2015, 06:14 AM
mirror
[-] The following 8 users Like zrilek's post:8 users Like zrilek's post
  • PinkPant, stosto6666, oanm2000, eliseo.as, psk62, asumi, Wiya Civil, learner20
 mohsen1
User ID: 3424
Threads: 1
Likes: 295 in 9 posts
Given Likes: 2
07-16-2015, 10:34 PM (This post was last modified: 07-17-2015, 01:39 AM by Dell_Brett.)
here an modified old crack ,, you can set a time as you wish ,,, for example 2 or 3 years ,
happy eid for all ,,,,
[-] The following 18 users Like mohsen1's post:18 users Like mohsen1's post
  • psk62, asumi, malc, zrilek, stosto6666, sodapas, oanm2000, concreteok, cace-01, subin91, slowet, zipatton, faxel, simanta, cristi, shaker, PinkPant, cod-X
 eng donny
Indonesia
User ID: 765
Threads: 19
Likes: 1,976 in 236 posts
Given Likes: 905
07-18-2015, 08:15 AM
Dear Mohsen1,
your crack still not work, it give us blank lservrc if you opened with notepad.
Eng Donny
 mohsen1
User ID: 3424
Threads: 1
Given Likes: 2
07-19-2015, 10:57 AM (This post was last modified: 07-19-2015, 11:10 AM by Dell_Brett.)
@eng donny
try to unrar the folder csi old in safe mode ,, it will work and generate will ,,, may be your anti virus  erase some file from a crack ,,
[-] The following 5 users Like mohsen1's post:5 users Like mohsen1's post
  • Dell_Brett, eng donny, oanm2000, slowet, MOSS2000
 PinkPant
Turkey
User ID: 25448
Threads: 67
Likes: 4,007 in 374 posts
Given Likes: 10354
09-26-2015, 02:17 PM (This post was last modified: 05-15-2024, 06:09 AM by Administrator.)
CSI CSiCOL v9.0.0 repack
[Image: 73986104527360526703.jpg]
[Image: tips.png]
[align=left][Image: homepage.png]
PinkPant
[-] The following 27 users Like PinkPant's post:27 users Like PinkPant's post
  • cace-01, oanm2000, zrilek, eng donny, gianniorlati, yutt, amindoxiti, ykhackhack, kirankumarklk, joker™, blaze, Hengki, sodapas, ranger, Rapaig, MOSS2000, araza023, harsono, highcivil, rendel_©, HellboyRBJ, ting tsai huang, Williams, faxel, mohcivil, einarmag, mgdario
 PinkPant
Turkey
User ID: 25448
Threads: 67
Given Likes: 10354
#10
12-07-2015, 03:21 PM
Use regular forum pass
PinkPanther
[-] The following 16 users Like PinkPant's post:16 users Like PinkPant's post
  • joker™, slowet, Dell_Brett, oanm2000, ykhackhack, simanta, malc, bridgeengineer, nibbi, harsono, tumangik, kuyasipil, salahcivil, Wijono, apocalipse, Arigato
Pages (2): 1 2 Next »
  CSI CSiCol 12 poolmand 0 334 06-21-2026, 06:53 AM
  CSI CSiCol v11 Administrator 0 2,899 05-15-2024, 06:20 AM
Last Post: Administrator
  CSiCol V10 temp1366 4 9,558 08-23-2022, 08:47 AM
Last Post: alireza55
  CSiCol v8 struceng 16 43,940 12-31-2015, 03:43 AM
Last Post: Achye
