Civil Engineering Association Software Software Product Bentley Products Bentley (ex. Microstran) MSTower 06.20.02.04
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1405
11-23-2015, 07:51 PM (This post was last modified: 11-23-2015, 07:54 PM by rami1976.)
Bentley (ex. Microstran) MSTower 06.20.02.04 build 12/10/2015
[Image: 26467856476424074495.jpg]
MStower  is a Windows program for the analysis and checking of latticed towers and masts. It is used by designers and authorities for the checking of transmission line structures and communications towers and masts.
The program has options for the generation of geometry and loading, analysis, application of gust factors to member forces, and checking of members. There are comprehensive facilities for plotting of the structure, loading, and results. The structure geometry is specified by data describing panels, dimensions, sections, and ancillary equipment. Section properties and ancillary data are taken from standard library files. Wind and ice loads on members, antennas, and ancillaries are computed automatically.
Loads may be computed according to the rules of:
   BS 8100:Part 1:1986 (towers)
   BS8100:Part 4:1995 (guyed masts)
   ANSI EIA/TIA-222-F-1996
   ANSI/TIA-222-G-2005
   AS3995-1994
   AS/NZS 1170.2:2011
   Malaysian Electricity Supply Regulations 1990.
Thanks to LAVteam
[Image: tips.png]
Unrar
Install the app in the default path.
apply patch (run as admin).
  • Related Link:
    how to use hulkload.com , pls refer to :
[-] The following 17 users Like rami1976's post:17 users Like rami1976's post
  • oanm2000, joker™, telecivil, Dell_Brett, subin91, malc, f_slikken, emmi, Williams, knrsa, nyungaw, monter, jayborre, harsono, nan54, derywira, hieucuto9x
 monter
User ID: 31175
Threads: 1
Likes: 664 in 50 posts
Given Likes: 1831
05-16-2020, 11:56 AM (This post was last modified: 05-17-2020, 09:41 AM by Dell_Brett. Edit Reason: N/A )
new link for post #1
File Size: RAR 23.2+3.6 MB,
Standard Forum Password
[-] The following 10 users Like monter's post:10 users Like monter's post
  • blaze, jcbv, Dell_Brett, durden, PinkPant, oanm2000, dovsky, limberjmc, narendra, spat
  Bentley Microstran V9 pezhmankhan 4 12,065 06-29-2025, 05:51 AM
Last Post: j4fz
  Bentley MSTower 06.20.01.09 build 02.07.2014 bigone 2 9,839 08-09-2015, 09:20 AM
Last Post: eng donny
