Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) FRP Deck and Steel Girder Bridge Systems
06-25-2013, 06:32 AM
Author: Julio F. Davalos, An Chen, and Pizhong Qiao | Size: 12.48 MB | Format: PDF | Quality: Original preprint | Publisher: CRC Press | Year: 2013 | pages: 333 | ISBN: 9781439877616
[Image: 40918867605042045343.jpg]
Fiber-reinforced polymer (FRP) decks have been increasingly used for new construction and rehabilitation projects worldwide. The benefits of using FRP bridge decks, such as durability, light weight, high strength, reduced maintenance costs, and rapid installation, outweigh their initial in-place material costs when implemented in highway bridge projects. FRP Deck and Steel Girder Bridge Systems: Analysis and Design compiles the necessary information to facilitate the development of the standards and guidelines needed to promote further adoption of composite sandwich panels in construction. It also, for the first time, proposes a complete set of design guidelines.
Providing both experimental investigations and theoretical analyses, this book covers three complementary parts: FRP decks, shear connectors between the deck and steel girders, and the behavior of bridge systems. The text presents stiffness and strength evaluations for FRP deck panels and FRP deck-girder bridge systems. While the FRP deck studies focus on honeycomb FPR sandwich panels over steel girder bridge systems, they can be adapted to other sandwich configurations. Similarly, the shear connection and bridge system studies can be applied to other types of FRP decks. Chapters discuss skin effect, core configuration, facesheet laminates, out-of-plane compression and sheer, mechanical shear connectors, and FRP deck–steel girder bridge systems.
Based on the findings described in the text, the authors propose design guidelines and present design examples to illustrate application of the guidelines. In the final chapter, they also provide a systematic analysis and design approach for single-span FRP deck-stringer bridges. This book presents new and improved theories and combines analytical models, numerical analyses, and experimental investigations to devise a practical analysis procedure, resulting in FRP deck design formulations.
[-] The following 27 users Like ir_71's post:27 users Like ir_71's post
  β€’ rendel_Β©, subin91, cace-01, malc, Jackass, tluc, PinkPant, fred2010, warbeast, lamkin, mahyarov, lisine, marion33, seriousboy, oanm2000, ibg0203, Ultra Zone, ingchio, kowheng, Sumatra, Dell_Brett, vardan, peixoto, Andrew seah, slowet, jfjdm, vvvv
 cace-01
User ID: 15651
Threads: 433
Likes: 10,522 in 867 posts
Given Likes: 7468
10-24-2013, 02:07 PM
FRP Deck and Steel Girder Bridge Systems: Analysis and Design (Composite Materials: Design and Analysis)
Author: Julio F. Davalos, An Chen and Pizhong Qiao | Size: 23.4 MB | Format: PDF | Quality: Unspecified | Publisher: CRC Press | Year: 2013 | pages: 351 | ISBN: 1439877610
[Image: 05201726686491971096.jpeg]
Thanks to Original Uploader
[-] The following 6 users Like cace-01's post:6 users Like cace-01's post
  β€’ marion33, warlord1, malc, Dell_Brett, Jackass, blaze
 al_frd
User ID: 382
Likes: 435 in 78 posts
Given Likes: 5
10-25-2013, 04:35 PM
Mirror for post #2
[-] The following 3 users Like al_frd's post:3 users Like al_frd's post
  β€’ vardan, Dell_Brett, mgdario
 ibg0203
China
User ID: 1557
Threads: 288
Likes: 6,208 in 686 posts
Given Likes: 1411
10-23-2015, 03:25 PM
[-] The following 7 users Like ibg0203's post:7 users Like ibg0203's post
  β€’ zrilek, malc, subin91, oanm2000, Dell_Brett, PinkPant, mgdario
 febo927
User ID: 23688
Threads: 105
Likes: 4,179 in 339 posts
Given Likes: 1279
09-25-2018, 01:01 PM
[-] The following 10 users Like febo927's post:10 users Like febo927's post
  β€’ vvvv, Andrew seah, oanm2000, Nita1391, gulilero, rendel_Β©, PinkPant, Aviator, cace-01, Dell_Brett
  Bridge Deck Analysis Flexi 10 10,781 08-19-2019, 10:22 PM
Last Post: Nita1391
  Bridge Deck Analysis from Pama - Cusens gianniorlati 2 3,217 02-06-2018, 11:13 PM
Last Post: Kurucz
  Grillage analogy in Bridge Deck Analysis Dell_Brett 3 4,995 07-03-2016, 06:09 AM
Last Post: Dell_Brett
  Analysis of Beam Grids and Orthotropic Plates - Bridge Deck Design gianniorlati 1 2,818 10-06-2015, 06:35 AM
Last Post: subin91
  AASHTO - Guide Specifications for Horizontally Curved Steel Girder Highway Bridges chrono146 1 3,034 07-02-2014, 03:35 PM
Last Post: i_kabir
  Bridge Deck Behaviour, 2nd Edition Flexi 8 6,662 01-22-2014, 05:19 PM
Last Post: ssobhan
  Laser Welded Steel Sandwich Panel Bridge Deck Development mahyarov 0 1,834 11-13-2012, 10:35 AM
Last Post: mahyarov
