Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] Column Axial Load Effects on Performance of Panel Zone in Welded-Flange-Plate Connect
[Request] Column Axial Load Effects on Performance of Panel Zone in Welded-Flange-Plate Connect
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
10-04-2015, 04:45 PM
  • Article/eBook Full Name: Column Axial Load Effects on Performance of Panel Zone in Welded-Flange-Plate Connections
  • Author(s): Amir Homayoon Kosarieh
  • Publish Date: 2015
  • Related Links:
  â€¢
 Mohammad6299
User ID: 42302
Threads: 251
Likes: 7,913 in 854 posts
Given Likes: 4212
10-17-2015, 08:49 PM (This post was last modified: 10-17-2015, 09:08 PM by Mohammad6299.)
[Image: 54954042795221201240.jpg]
  • Author(s): Amir Homayoon Kosarieh, Fakhreddin Danesh, Ramin Shiri
  • Published By: Advances in Structural Engineering
  • Published Year: 2015
  • DOI: 10.1260/1369-4332.18.6.775
  • Size: 1.3 MB
  • Quality: Original preprint
  • Related Link:
    http://multi-science.atypon.com/doi/abs/...2.18.6.775
  • Abstract: In this study the effects of different levels of column axial load on seismic performance of Welded Flange Plate (WFP) connections with different panel zone strength are presented. Finite element method was used to do this investigation and reliability of the modelling method was verified by comparison with experimental available records in documents. Fifteen sub-assemblages of WFP connections were generated by means of ABAQUS software. The aim was to enhance the knowledge about the consequence of column axial load level on cyclic behaviour and fracture potential of the connections with different panel zone strength for external joints in Steel Moment Resisting Frames (SMRFs). Results showed that cyclic behaviour including hysteresis loops and energy dissipation were not affected significantly by increasing column axial load regardless of the panel zone strength. It was also found that increase of the fracture potential due to increase in column axial load became less pronounced when the panel zone strength was decreased.
[-] The following 9 users Like Mohammad6299's post:9 users Like Mohammad6299's post
  â€¢ amindoxiti, malc, ssobhan, blaze, ykhackhack, zrilek, Dell_Brett, PinkPant, K.Lee
  [REQUEST] Evaluation of bolted CHS flange-plate connections under axial tension civilfafa 1 3,446 07-08-2024, 10:58 AM
  [REQUEST] Effects of Column Creep and Shrinkage in Tall Structures-Prediction of Inelastic Colu temp1366 1 2,004 03-02-2016, 08:16 AM
Last Post: xnr09
  [REQUEST] Effects of Column Creep and Shrinkage in Tall Structures-Analysis for Differential Sh temp1366 0 1,622 03-02-2016, 07:58 AM
Last Post: temp1366
