Civil Engineering Association Software Software Product Autodesk Products Autodesk AutoCAD 2016 SP1
 ibg0203
China
User ID: 1557
Threads: 288
Likes: 6,208 in 686 posts
Given Likes: 1411
10-01-2015, 03:31 PM
[Image: 73580393738286606467.jpeg]
Design and shape the world with the powerful, connected design tools in AutoCAD® software for Windows. Create stunning 3D CAD designs and speed documentation with the reliability of TrustedDWG technology. Connect in the cloud to collaborate on designs and access them from your mobile device.
CAD tools for design and documentation
See how intelligent tools in AutoCAD® design and documentation software help speed your work, and how CAD features add precision to your drawings. View designs more clearly with Stunning Visual Experience and document in context with Coordination Model.
New Features in AutoCAD 2016:
• Enhanced PDFs
PDFs are smaller, smarter, and more
• Smart Dimensioning
Create measurements based on your drawing context.
• Stunning Visual Experience
See the details in your drawings more clearly.
• Coordination Model
Design within the context of existing BIM models.
• Sysvar monitor
Prevent unwanted changes to your system settings.
[Image: tips.png]
System Requirements for AutoCAD 2016:
- Windows 10 Enterprise edition
- Windows 10 Professional edition
- Microsoft® Windows® 8/8.1 Enterprise
- Microsoft Windows 8/8.1 Pro
- Microsoft Windows 7 Enterprise
- Microsoft Windows 7 Ultimate
- Microsoft Windows 7 Professional
- Microsoft Windows 7 Home Premium
[Image: homepage.png]
[Image: comments.png]
What's new in AutoCAD 2016 SP1:
[-] The following 8 users Like ibg0203's post:8 users Like ibg0203's post
  • zrilek, oanm2000, concreteok, slowet, PinkPant, bridgeengineer, ting tsai huang, learner20
 ykhackhack
United States
User ID: 36960
Likes: 3,670 in 707 posts
Given Likes: 8693
10-02-2015, 05:40 AM
Do you need AutoCad 2016 installed first?
Thanks
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,039 in 2,189 posts
Given Likes: 42508
10-02-2015, 09:54 AM
Moderator Comments:
The Service Pack 1 of AutoCAD 2016 could be downloaded free of charge in Autodesk site.
The file size in post #1 means it's a full program.
[-] The following 7 users Like Dell_Brett's post:7 users Like Dell_Brett's post
  • PinkPant, paulocs, oanm2000, zrilek, ykhackhack, cace-01, learner20
 ibg0203
China
User ID: 1557
Threads: 288
Given Likes: 1411
11-08-2015, 05:10 PM
Autodesk AutoCAD 2016 SP1 with SPDS Extension
[Image: 97419411866547181005.jpeg]
[Image: 86962625007050334615.png]
Autodesk Inc., a world leader in 3D design software for entertainment, natural resources, manufacturing, engineering, construction, and civil infrastructure, has released an update (SP1) for AutoCAD 2016, its the latest version of the popular drafting software features improvements in dimensioning, object snapping, PDF creation, and reality computing.
The latest version of the world’s most widely used CAD application has many new tools and improvements in the user experience, rendering engine, dimensioning capabilities, PDF exporting, and coordination with reality computing and BIM programs.
Better Graphics
Users now have settings for smooth-line display and high-quality geometry so that circles and arcs no longer look like polygons in model space. Instead, they’ll look like the vector graphics that they are, reducing pre-plotting panic. A more robust graphics engine also means that users can move and copy large selection sets in the 2D wireframe mode without the software appearing to stutter. The program's ribbon menus, file tabs, and layout tabs are more functional, versatile, and customizable; they look sleeker, too.
AutoCAD 2016 is powered by a new rendering engine and has a new rendering interface. Default presets allow users to specify how detailed and how large they want their rendering, or how much time the program should spend generating it. The program also offers preset image-based lighting environments to add a realistic effect to renderings, with options to adjust white balance and image exposure. While the rendering engine is churning, users have access to a status window that can zoom in and out on the image, take snapshots, or print.
Less to Undo
Autodesk has also expanded the program’s command preview tool to work with more commands—including erase, stretch, rotate, and scale—allowing users to test their actions before committing to them.
Similarly, AutoCAD's dimensioning tool has been made more intelligent. It now gives users the ability to preview whether the measured values are the appropriate dimension notes to include; it also suggests relevant measurements based on the object type. For example, users hovering over a circle will be shown diameters, radii, and angular dimensions. If dimensions overlap with similar dimensions, the command knows to either break up, insert, or stagger dimension notes. The DIM command also places dimensions automatically to a user-specified layer.
According to the AutoCAD 2016 Preview Guide, the second most-requested item on the Autodesk User Group International (AUGI) wish list has also been granted with this release: an automatic object snap for the geometric center of a polygon or closed polyline. No more integration or weighted-average calculations needed—well, fewer at least.
Revision clouds have become easier (and more fun!) to create and edit. Users can transform, add to, or delete revision clouds, in addition to creating them from nearly any object, such as drawings notes. This control was the fourth most-requested item on the AUGI wish list.
Expanded File Compatibility
In AutoCAD 2016, users can now export drawings as PDFs for the Web, emailing, and printing with searchable text. PDFs exported from AutoCAD drawings also maintain hyperlink functionality to other drawing pages, sheet sets, views, and external links.
With reality computing becoming more finessed, the program allows designers to use point clouds, which can be generated from laser scans, photogrammetry, and other sensing devices, as the building model. AutoCAD 2016 expands on its predecessor’s point-cloud editing tools with the ability to create and manipulate section planes from point clouds, adjust transparency levels to see geometry beyond, and access object snaps specific to point clouds. It also lets users create as-built drawings from data sets by extracting floor plans from a cross section of the point cloud.
About Autodesk
Autodesk helps people imagine, design and create a better world. Everyone—from design professionals, engineers and architects to digital artists, students and hobbyists—uses Autodesk software to unlock their creativity and solve important challenges.
[Image: tips.png]
Version: 2016 SP1 (M.107.0.0) with SPDS Extension
Interface: english, russian
OS: Windows 7even / 8 / 8.1
[-] The following 4 users Like ibg0203's post:4 users Like ibg0203's post
  • learner20, PinkPant, oanm2000, dizz
  AutoRebar for Autodesk AutoCAD poolmand 1 12,611 08-18-2025, 09:58 AM
  Autodesk AutoCAD Civil 3D 2025 poolmand 2 6,134 12-02-2024, 01:09 PM
  Autodesk AutoCAD Plant 3D 2022 (x64) Pre-Cracked BennyP 1 10,734 10-27-2023, 04:10 PM
Last Post: Dalvisahi014
  Autodesk AutoCAD 2022 (x64) BennyP 5 13,951 03-29-2022, 11:33 AM
Last Post: Arigato
  Autodesk AutoCAD Civil 3D 2022 poolmand 2 11,775 03-13-2022, 03:04 PM
Last Post: pilitro
  Autodesk AutoCAD Raster Design 2019 BennyP 5 11,059 09-22-2021, 09:07 AM
  Autodesk Autocad 2016 (x64 + x32) Trial BennyP 3 11,711 05-22-2021, 05:55 AM
Last Post: kirankumarklk
