Civil Engineering Association eBooks Codes, Manual & Handbook ASME BPVC 2013 - Section VIII, Division 2: Alternative Rules
 hodzicemir
Bosnia and Herzegovina
User ID: 36740
Threads: 19
Likes: 783 in 83 posts
Given Likes: 467
09-28-2015, 07:58 AM
Author(s)/Editor(s): ASME | Size: 25 MB | Format: PDF | Quality: Unspecified | Publisher: ASME | Year: 2013 | pages: 834 | ISBN: 9780791834732
This Division of Section VIII provides requirements applicable to the design, fabrication, inspection, testing, and certification of pressure vessels operating at either internal or external pressures exceeding 15 psig. Such vessels may be fired or unfired. This pressure may be obtained from an external source or by the application of heat from a direct or indirect source, or any combination thereof. These rules provide an alternative to the minimum requirements for pressure vessels under Division 1 rules. In comparison the Division 1, Division 2 requirements on materials, design, and nondestructive examination are more rigorous; however, higher design stress intensify values are permitted. Division 2 rules cover only vessels to be installed in a fixed location for a specific service where operation and maintenance control is retained during the useful life of the vessel by the user who prepares or causes to be prepared the design specifications. These rules may also apply to human occupancy pressure vessels typically in the diving industry. Rules pertaining to the use of the U2 and UV ASME Product Certification Marks are also included.
Careful application of this Section will help users to comply with applicable regulations within their jurisdictions, while achieving the operational, cost and safety benefits to be gained from the many industry best-practices detailed within these volumes.
[-] The following 3 users Like hodzicemir's post:3 users Like hodzicemir's post
  • PinkPant, Dell_Brett, oanm2000
 PinkPant
Turkey
User ID: 25448
Threads: 67
Likes: 4,007 in 374 posts
Given Likes: 10354
09-28-2015, 01:35 PM
PinkPant
[-] The following 3 users Like PinkPant's post:3 users Like PinkPant's post
  • Dell_Brett, Jackass, oanm2000
  ASME BPVC Section VI - Recommended Rules for the Care and Operation of Heating Boiler hodzicemir 1 2,005 09-28-2015, 01:58 PM
Last Post: PinkPant
  ASME SECTION VII 2013 - Recommended Guidelines for the Care of Power Boilers by ASME hodzicemir 1 2,061 09-28-2015, 01:44 PM
Last Post: PinkPant
  ASME SECTION VIII jamildear4u 2 3,107 09-28-2015, 01:38 PM
Last Post: PinkPant
  ASME Boiler & Pressure Vessel Code 2013: Rules for Construction of Pressure Vessels: hodzicemir 0 1,715 09-28-2015, 08:00 AM
Last Post: hodzicemir
  2010 ASME BPVC Section IX welding code duazo2009 3 4,265 04-28-2015, 08:48 AM
Last Post: PinkPant
  Design Guide on Use of Alternative Steel Materials to BS 5950 legarleon 2 2,978 09-08-2011, 10:40 AM
Last Post: cordoba123
