Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] Piled raft foundations on stiff clays - Geotechnique
[Request] Piled raft foundations on stiff clays - Geotechnique
 PIGAS
Brazil
User ID: 67701
Threads: 21
Likes: 17 in 6 posts
Given Likes: 19
08-14-2015, 07:22 PM
Hi, please
I need this document:
Author: R. W. Cooke
Source: Géotechnique, Volume 36, Issue 2, 01 June 1986 , pages 169 –203
Paper Geotechnique
Thanks!!
 Mohammad6299
User ID: 42302
Threads: 251
Likes: 7,913 in 854 posts
Given Likes: 4212
09-29-2015, 10:07 AM
Piled raft foundations on stiff clays — a contribution to design philosophy
[Image: 95614946277978640761.jpg]
  • Author(s): R. W. Cooke
  • Published By: Géotechnique, Volume 36, Issue 2
  • Published Year: 1986
  • DOI: 10.1680/geot.1986.36.2.169
  • Size: 2.47 MB
  • Quality: Scanner (OCR)
  • Related Link:
    http://www.icevirtuallibrary.com/content...6.36.2.169
  • Abstract: To design piled raft foundations on stiff clays with precision and economy it is necessary to know how the structural loads are transferred to the supporting soil by the components of the foundation and to understand the factors affecting the overall and differential settlements under working conditions. In cases where piles are essential from the viewpoint of stability it is important to know the distribution of pile loads and whether the raft contributes significantly to the total support. However, where a raft alone can provide adequate bearing capacity but may settle excessively the designer will not wish to include more piles than are necessary to control the settlements. This Paper attempts to bring together information on some of these aspects of design. It presents the results of model tests on unpiled rafts, free-standing piles and piled rafts of various sizes. These are used as a framework to which field measurements carried out by the Building Research Establishment and settlement observations made by workers elsewhere are related. The study suggests that at the same overall safety factors the settlements of structures on piled rafts are likely to be comparable with the settlements of structures on unpiled rafts of similar sizes. Since piled raft foundations are frequently employed because the settlements of unpiled rafts are considered to be excessive, the small settlements that structures on these foundations normally experience are probably due to the fact that the safety factors in practice are higher than those assumed in design. This, and empirical methods of assessing the contribution of the raft to the total support and of calculating the numbers of piles required for settlement reduction are discussed. The need for piles to be as long as possible in relation to the breadth of the foundation is demonstrated.
[-] The following 14 users Like Mohammad6299's post:14 users Like Mohammad6299's post
  • f_slikken, mary, amindoxiti, PinkPant, learner20, cace-01, oanm2000, ting tsai huang, Dell_Brett, ssobhan, PIGAS, malc, geomahesh, zrilek
  [REQUEST] Methods of Analysis of Piled Raft Foundations - H.G. Poulos atenx 0 1,661 04-01-2017, 04:17 AM
Last Post: atenx
  [REQUEST] Papers - Géotechnique PIGAS 2 2,173 05-23-2016, 02:02 PM
Last Post: freequo
  [REQUEST] P. W. Rowe Papers (Géotechnique) PIGAS 1 1,739 05-04-2016, 08:13 PM
Last Post: xnr09
  [REQUEST] ASCE Geotechnical and Géotechnique papers GrGandalf85 4 2,690 04-23-2016, 09:37 AM
Last Post: xnr09
  [REQUEST] Géotechnique, Volume 54, Issue 2, 01 January 2004 , pages 149 –150 cippolo 1 1,990 08-20-2015, 09:33 AM
Last Post: freequo
  [REQUEST] Paper Geotechnique - Structural behaviour of residual soils PIGAS 1 1,779 05-27-2015, 12:34 AM
Last Post: ska51
  [REQUEST] Articles on Behavior of Clays in Slope Stability oanm2000 1 2,021 02-04-2015, 11:09 PM
Last Post: StefanC
