Civil Engineering Association Software Software Product Non Engineering Software Any DWG to PDF Converter 2010
Threads: 1,128
01-01-2010, 09:41 AM
It is a batch converter that allows you to convert DWG and DXF to PDF without the need of AutoCAD. (New - 2010 support)
Key Features
* Stand-alone utility - AutoCAD NOT required.
* Convert DWG and DXF to vector PDF in batches.
* Supports paper space and model space.
* Supports every version of DWG/DXF files (Supports R2.5/2.6 to R2010 formats)
* Very easy to use.
* The "Pro" version supports command line.
[Image: 11503264406344461414.gif]
[-] The following 26 users Like BennyP's post:26 users Like BennyP's post
  • kowheng, Dell_Brett, timosi™, Ultra Zone, u4406014, michaelsoe, cve_jule, waly76, errohit, dex970, haze, duazo2009, isurya, jorgeramos, simanta, henrybill, oreslaw, hmwere, aungaung, tolesa54, STRAIN, civil, Quantumm, zzzz, riprap, maijuji
 caifan
User ID: 24611
Threads: 2
Likes: 17 in 8 posts
Given Likes: 992
07-14-2015, 05:45 AM
Please upload, thanks
  STDU Converter 2.0.61.0 [DJVU to PDF Converter] Dell_Brett 0 4,846 12-20-2010, 07:45 AM
Last Post: Dell_Brett
