Civil Engineering Association eBooks Journals, Papers and Presentations The Design of Vibro Replacement
 PinkPant
Turkey
User ID: 25448
Threads: 67
Likes: 4,007 in 374 posts
Given Likes: 10354
06-17-2015, 06:48 AM (This post was last modified: 06-17-2015, 09:20 AM by Dell_Brett.)
Author: Heinz J. Priebe | Size: 292 KB | Format: PDF | Quality: Unspecified | Year: 1995 | pages: 17
[Image: 07903703816877561462.jpg]
Vibro Replacement is an accepted method for subsoil improvement, at which large-sized columns of coarse backfill material are installed in the soil by means of special depth vibrators. The performance of this composite system consisting of stone columns and soil, is not determinable by simple investigation methods like soundings, and therefore, such methods are not suitable for design purposes. However, theoretically, the efficiency of Vibro Replacement can be reliably evaluated. The method elaborated on a theoretical basis and described in this contribution, is easy to survey and adaptable to different conditions due to the separate consideration of significant parameters. Practically, it comprises design criteria for all frequently occurring applications.
PinkPant
[-] The following 13 users Like PinkPant's post:13 users Like PinkPant's post
  â€¢ blaze, cace-01, uetian19, oanm2000, zrilek, Jackass, gulilero, dizz, jfjdm, ykhackhack, amindoxiti, 3fan, oreslaw
 3fan
Romania
User ID: 29614
Threads: 141
Likes: 7,359 in 1,207 posts
Given Likes: 5546
06-19-2015, 08:03 AM
The Design of Vibro Replacement - The application of Priebe's method to extremly soft soils, "floating" foundations and proof against slope or embankment failure
DIRECT LINKS thumbup
[-] The following 8 users Like 3fan's post:8 users Like 3fan's post
  â€¢ PinkPant, Dell_Brett, oanm2000, cace-01, geomahesh, zrilek, malc, oreslaw
 oreslaw
User ID: 14360
Likes: 14 in 8 posts
Given Likes: 979
06-22-2015, 01:26 PM
Could you please kindly re-upload the document from post #2 as the link no longer work?
  â€¢
 zrilek
User ID: 3860
Threads: 10
Likes: 337 in 59 posts
Given Likes: 22028
06-22-2015, 01:34 PM
it work's. try harder
[-] The following 3 users Like zrilek's post:3 users Like zrilek's post
  â€¢ Dell_Brett, 3fan, oanm2000
  Design of Vibro Replacement shadabg 0 4,049 09-15-2012, 06:49 AM
Last Post: shadabg
