Civil Engineering Association Software Software Product Non Engineering Software IRIS Readiris Corporate 14.1 build 2826 Multilingual
 dl4all
User ID: 41680
Threads: 15
Likes: 210 in 26 posts
Given Likes: 137
10-21-2013, 04:47 PM (This post was last modified: 10-21-2013, 04:48 PM by dl4all.)
[Image: 52677575621409947533.png]
Scan, Convert & Manage your documents. Readiris 14 is a powerful OCR software designed to convert all your paper documents, images or PDF into editable and searchable digital text (Word, Excel, PDF…) in just a click ! Readiris 14 converts your paper, images or PDF files into editable and searchable digital text (Word, Excel, PDF,...) Convert standard document images & PDF files into a fully indexed, keyword-retrievable PDF documents.Upload your documents to the Cloud and retrieve them anywhere, anytime and on any device. Import your paper documents from any scanner using Readiris 14’s embedded scanning wizard.
Never retype text again
Convert any paper document, image or PDF into editable and searchable digital files (Word, Excel, PDF, HTML, etc.) using Readiris 14's Optical Character Recognition (OCR) technology. Simply scan your paper document using the built-in scanning wizard or import image from folders or digital camera. Readiris 14 will instantly convert it to the format of your choice without altering the original layout. Your digital documents will now be easy to edit, archived and shared!
Create searchable PDF
Readiris 14 makes it easy to create searchable and indexed PDF files compatible with virtually any computer. The produced PDF will look exactly the same as the original image while adding a text layer ready to be searched and indexed. It will now be very convenient to find the exact information you are looking for amongst tons of archived documents!
Store your documents in the Cloud
Store, access and manage your converted documents from any computer, tablet or mobile phone using Readiris 14's new Cloud connector.
Simply select your favourite Cloud hosting service after the conversion process and your document will automatically be exported, ready to be accessed anywhere you are! All your digital archives will now be safely backed-up and accessible when and where you need it the most! Supported Cloud services: Evernote, Dropbox, Box & Google Drive.
Reduce the size of your digital files
Drastically reduce the size of your images and PDF files using I.R.I.S.'s exclusive high compression technology. This new feature will let you compress your files up to 50 times smaller than the original size without affecting the visual quality. Your compressed documents, in standard PDF format, will be fully searchable and compatible with any usual PDF viewer! The size of your digital documents will no longer be an issue while being stored or shared!
Process Multi-page documents
Readiris 14 lets you quickly convert multi-page documents into one or many output files. If you have different documents to process, you can also combine and organize them into one single file (PDF, Word,...).
For those who use a scanner with document feeding options, Readiris 14 corporate features advanced scanning options that will optimize the multi-page scanning and conversion process. From one up to thousands of pages, Readiris 14 will always bring you the solution that fits your document processing needs!
Drop, convert and manage your documents … Automatically
Drop your scanned documents to any folder folder. Readiris will monitor them and whenever Readiris spots a new document inside one of the Watched Folders, it will processes it , covert it and exports it to a destination of your choice: in an output folder, in the Cloud or on an FTP web site. (Only available in Readiris 14 Corporate edition) Simply drop your document in the right folder and it will be processed in the right format and exported to right place... Automatically!
[-] The following 5 users Like dl4all's post:5 users Like dl4all's post
  • maad59, sructme, chenamoy, jonny78, ska51
 ykhackhack
United States
User ID: 36960
Threads: 81
Likes: 3,670 in 707 posts
Given Likes: 8693
12-29-2013, 12:58 PM
@rimrany:
Just sharing the links. I checked the links , they work
[-] The following 6 users Like ykhackhack's post:6 users Like ykhackhack's post
  • oanm2000, TAFATNEB, malc, Dell_Brett, geomahesh, ska51
 henrybill
User ID: 30355
Threads: 67
Likes: 1,527 in 157 posts
Given Likes: 246
01-14-2014, 02:52 AM
IRIS Readiris Corporate v14.1.Build.2826 + IRIS Readiris Pro v14.1.Build.2573 -ML
Size: 222.92 (CE), 211.53 (Pro) MB
[Image: homepage.png]
[-] The following 4 users Like henrybill's post:4 users Like henrybill's post
  • milvio, Dell_Brett, warlord1, ska51
 henrybill
User ID: 30355
Threads: 67
Given Likes: 246
04-09-2015, 09:25 AM
IRIS.Readiris.Corporate.v15.01.Build.6453-ML
[-] The following 2 users Like henrybill's post:2 users Like henrybill's post
  • oanm2000, ska51
Threads: 1,128
04-10-2015, 06:59 AM
Our VIP can use a full license i created for the corporate version.
You can see screanhots of the PDF and the DOC creted using the PDF file.
[Image: 44611763507493357596.gif]
[Image: 50401653501152664552.gif]
[Image: 40626230452974157193.gif]
[-] The following 7 users Like BennyP's post:7 users Like BennyP's post
  • amindoxiti, cace-01, Dell_Brett, milvio, oanm2000, ska51, henrybill
Users browsing this thread:
  TechSmith Camtasia 2022.0.2 Build 38524 (x64) Multilingual straightrun65 1 4,352 08-26-2022, 03:44 PM
Last Post: alireza55
