Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 8007:1987 Code of practice for Design of concrete structures for retaining aqueous
Threads: 1,298
01-29-2011, 06:53 PM
Code of practice for BS 8007:1987 Design of concrete structures for retaining aqueous liquids
Author: Technical Committee CSB/60 | Size: 0.9 MB | Format: PDF | Publisher: BSI | Year: 1987 | pages: 38 | ISBN: 058016134X
[Image: 59527619521909381267.jpg]
This British Standard provides recommendations for the design and construction of normal reinforced and prestressed concrete structures used for the containment or exclusion of aqueous liquids. The term “liquid” in this code includes any contained or excluded aqueous liquids but excludes aggressive liquids. The code does not cover dams, pipes, pipelines, lined structures, or the damp-proofing of basements. The term “structure” is used herein for the vessel that contains or excludes the liquid, and includes tanks, reservoirs, and other vessels.
NOTE 1 The design of structures of special form or in unusual circumstances is a matter for the judgement of the designer.
NOTE 2 The titles of the publications referred to in this standard are listed on the inside back cover.
  • blaze, Dell_Brett, oanm2000, kowheng, rendel_©, usman, Adam Smith, salahcivil, roaming79, Grunf, zrilek, DamaD, bhawk0, vvvv
 Alexander
User ID: 5365
Threads: 8
Likes: 59 in 16 posts
Given Likes: 114
05-22-2012, 10:57 PM
I also found a link to DL here
*************************************** Content of this section is hidden, You must be registered and activate your account to see this content. See this link to read how you can remove this limitation: http://forum.civilea.com/thread-27464.html ***************************************[/CODE]
[-] The following 7 users Like Alexander's post:7 users Like Alexander's post
  • malc, zrilek, Jackass, vvvv, Dell_Brett, paulocs, andersen3
 f_slikken
User ID: 21091
Threads: 13
Likes: 910 in 88 posts
Given Likes: 778
02-28-2015, 06:48 PM
Hi,
Here you go!
[-] The following 6 users Like f_slikken's post:6 users Like f_slikken's post
  • amindoxiti, bridgeengineer, malc, Dell_Brett, PinkPant, uetian19
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 7,895 05-29-2024, 12:10 PM
  BS EN 1992-1-2: Eurocode 2. Design of concrete structures-Structural fire design poolmand 0 3,321 01-14-2024, 10:04 AM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,788 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 9,803 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,328 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,596 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 5,118 07-31-2021, 07:54 PM
Last Post: monter
