Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 8490:2007 Guide to siphonic roof drainage systems
11-10-2010, 07:26 AM (This post was last modified: 08-16-2011, 04:38 PM by usman.)
[Image: 18772565111263710724.jpg]
BS 8490 is the British Standard applies to roof drainage systems using circular-section pipes that operate under siphonic action. It does not apply to siphonic drainage systems using rectangular or trapezoidal section conduits for water conveyance.
It gives information and provides guidance on design parameters, installation, verification and maintenance needs of siphonic roof drainage systems. Guidance is also given on carrying out checks of designs, for the use of specifiers and regulatory authorities. Particular issues for site drainage systems that receive flows from siphonic roof drainage systems are also covered.
BS 8490 should be read in conjunction with BS EN 12056-3 which deals with the layout and calculation of roof drainage. BS8490 gives information facilitating the use of BS EN 12056-3 in the United Kingdom with regard to siphonic roof drainage systems; it does not alter any of the provisions of that standard.
:JC_cheers:
  â€¢ ascetic19, Trishu999, hmwere, zrilek, roaming79, kowheng, ISTRAKTURA, vvvv, planeti_x, toa011, Grunf, snw1975, oanm2000, Dell_Brett, sivlad, peixoto
08-16-2011, 04:16 PM
New links:
Good luck!
  â€¢ herea, Dell_Brett, sujups, Jackass, cristi, sivlad, techno
 usman
User ID: 59
Threads: 131
Likes: 6,571 in 671 posts
Given Likes: 4974
08-16-2011, 04:39 PM
Mirror
[-] The following 5 users Like usman's post:5 users Like usman's post
  â€¢ herea, Dell_Brett, Trishu999, Jackass, sivlad
10-11-2012, 05:00 AM
New links:
[-] The following 2 users Like ir_71's post:2 users Like ir_71's post
  â€¢ lisine, zrilek
12-30-2014, 05:59 PM
  â€¢ blaze, Jackass, GMianG, Dell_Brett, PinkPant, knrsa, oanm2000, hodzicemir
 Veggeta
Guatemala
User ID: 114
Threads: 98
Likes: 4,273 in 520 posts
Given Likes: 403
12-30-2014, 09:56 PM
use official password
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 4 users Like Veggeta's post:4 users Like Veggeta's post
  â€¢ PinkPant, eliseo.as, bridgeengineer, oanm2000
  BS EN 14629:2007 Products and systems for the protection and repair of concrete structures ir_71 2 3,507 02-11-2022, 09:56 AM
Last Post: CAMSECT
  BS 6297:2007 Code of practice for the design and installation of drainage fields for ir_71 3 3,615 01-29-2015, 04:35 PM
Last Post: Veggeta
  BS EN 14636-1:2009 Plastics piping systems for non-pressure drainage and sewerage ir_71 1 2,206 02-22-2013, 03:46 PM
Last Post: arshiakh
  BS EN 12380:2002 Air admittance valves for drainage systems mybest 1 2,146 02-21-2013, 09:43 AM
Last Post: arshiakh
  BS 8747:2007 Reinforced bitumen membranes (RBMs) for roofing. Guide to selection and ir_71 1 2,185 09-28-2012, 04:47 AM
  BS 9250:2007 Design of the Airtightness of Ceilings in Pitched Roof ir_71 1 2,338 09-25-2012, 04:56 AM
  BS OHSAS 18001:2007 Occupational health and safety management systems. Requirements mybest 1 2,293 12-08-2011, 01:06 PM
Last Post: kvtasp
