Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 349.2: Guide to the Concrete Capacity Design (CCD) Method
 robertsas
Indonesia
User ID: 655
Threads: 155
Likes: 5,665 in 416 posts
Given Likes: 3149
02-12-2010, 04:39 AM (This post was last modified: 05-08-2023, 10:17 AM by Administrator.)
ACI 349.2R-07 - Guide Embedment Design Examples
Design (CCD) Method
Embedment Design Examples - ACI 349.2R-07
This report was prepared by the members of the ACI 349 Subcommittee on Steel Embedments to provide examples of the application of ACI 349 to the design of steel embedments. The first edition of this report, published in 1997, was based on ACI 349-97 that used the 45-degree cone breakout model for determining the concrete breakout strength. The 2001 edition of the Code* marked a major departure from the previous editions with the adoption of the concrete capacity design (CCD) method. The model for the concrete breakout strength used in the CCD method is a breakout prism having an angle of approximately 35 degrees. In addition, the concrete breakout strength for a single anchor away from the edge is proportional to the embedment depth raised to the power of 1.5 and not embedment depth squared, as used in the previous versions of the Code. These and other changes in the Code result in designs that are somewhat different than those obtained using previous editions of the Code. The examples used in this report are based on the ACI 349-06, Appendix D, and illustrate how the CCD method is applied. In previous editions of ACI 349, the anchorage design was given in Appendix B. Because ACI 349 is a dependent code, the chapters and Appendixes in ACI 349 are updated to be consistent with ACI 318.
[Image: 38827626944601659163.jpg]
[-] The following 30 users Like robertsas's post:30 users Like robertsas's post
  â€¢ gatob, kowheng, u4406014, Dell_Brett, thanzawtun, subin91, vvvv, nuttapolk, cardinal85, jason2180, lucky_b2me, yutt, goober, Visitante, vccalderon, novolgator, julioreptil, ting tsai huang, harsono, jp_rzal, anorona, nuh_civil, dbsimon29, afebry, Hengki, malc, hatkam, ykhackhack, bigone, oram
 subin91
User ID: 2232
Threads: 35
Likes: 2,192 in 111 posts
Given Likes: 4701
12-29-2014, 01:45 AM
New Link
[-] The following 24 users Like subin91's post:24 users Like subin91's post
  â€¢ Albert, malc, Dell_Brett, Jackass, zrilek, vardan, PinkPant, uncblue, eliseo.as, amindoxiti, knrsa, yalham2000, bridgeengineer, Mohammad6299, usman, bigone, mgdario, StaadEng, cabpcabp, ruaumoko, ting tsai huang, sacem, spat, TAFATNEB
 Veggeta
Guatemala
User ID: 114
Threads: 98
Likes: 4,273 in 520 posts
Given Likes: 403
12-29-2014, 04:44 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 4 users Like Veggeta's post:4 users Like Veggeta's post
  â€¢ PinkPant, jcbv, mr.nicus, bigone
 Rapaig
User ID: 20672
Threads: 2
Likes: 119 in 16 posts
Given Likes: 160
02-11-2015, 06:26 PM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 10 users Like Rapaig's post:10 users Like Rapaig's post
  â€¢ Mohammad6299, blaze, ruaumoko, jcbv, bridgeengineer, bigone, PinkPant, sodapas, Dell_Brett, lucaPOLInuvola
Likes: 8,311 in 1,373 posts
Given Likes: 94
05-08-2023, 10:16 AM
ACI PRC-349.2-07(20) Guide to the Concrete Capacity Design (CCD) Method - Embedment Design Examples (Reapproved 2020)
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
  â€¢ babakfeyzi, milova, PinkPant, Dell_Brett
  ACI 445.2: Strut-and-Tie Method Guidelines for ACI 318 - Guide poolmand 3 5,046 02-07-2025, 09:55 AM
Last Post: agelos100
  ACI SP-236: Deformation Capacity and Shear Strength of Reinforced Concrete Members poolmand 0 1,864 03-04-2024, 08:32 AM
  ACI 526: Guide for Design and Construction with Autoclaved Aerated Concrete Panels poolmand 0 1,999 01-17-2024, 07:27 AM
  ACI 343.1 Guide for the Analysis and Design of Reinforced and Prestressed Concrete Gu poolmand 0 2,054 11-26-2023, 11:51 AM
  [CivilEA Exclusive] ACI 364.2: Increasing Shear Capacity within Existing Reinforced Concrete Structures poolmand 0 1,757 11-05-2023, 06:37 AM
  ACI 551.2: Design Guide for Tilt-Up Concrete Panels ascetic19 3 3,702 05-09-2023, 12:46 PM
  ACI 440.1: Guide for the Design and Construction of Structural Concrete Reinforced wi poolmand 0 1,893 05-08-2023, 01:39 PM
