Civil Engineering Association eBooks Water & Hydraulic Engineering SMALL DAMS : Guidelines for Design, Construction and Monitoring
Threads: 154
04-11-2013, 09:32 AM
Author: GΓ©rard DEGOUTTE | Size: 1.5 MB | Format: RAR | Quality: Original preprint | Publisher: French Committee on Large Dams | Year: 2002 | pages: 179 | ISBN: 2-85362-448-X
[Image: 29243848720068173374.jpg]
These guidelines for the design and construction of small dams have been drafted under the aegis of the French Committee on Large Dams. Small dams are conventionally defined as dams less than approximately 25 metres high.
The designer of a small dam may face a difficult task because he will not have access to the design and monitoring resources commonly deployed for larger dams.
The recommendations and advice in these guidelines have been drawn up on the basis of the climate, population and economic conditions found in France. They may require some modification if used in a different context.
For example, safety criteria may be relaxed if the valley downstream of the dam is sparsely populated; greater caution may be required in the absence of abundant rainfall and streamflow records; and some of the arrangements recommended may be considered needlessly costly luxuries.
Nevertheless, the guidelines provide a consistent foundation on which country-specific alternatives can be built up. It is thus of undeniable general interest, and the French Committee has decided to support an English language version.
[-] The following 21 users Like shadabg's post:21 users Like shadabg's post
  β€’ blaze, Jackass, Dell_Brett, Evandrojr, cace-01, BuSeongKim, Rainbow, malc, peixoto, nhim4mat2006, kowheng, tospol, zrilek, cepot, kevin8107, CVega, amindoxiti, ykhackhack, axcel, oanm2000, tuanpecc1
 junaid
User ID: 402
Threads: 197
Likes: 8,170 in 732 posts
Given Likes: 983
12-24-2014, 06:09 PM
[-] The following 14 users Like junaid's post:14 users Like junaid's post
  β€’ amindoxiti, bridgeengineer, malc, PinkPant, zrilek, ykhackhack, Dell_Brett, axcel, oanm2000, eliseo.as, nhim4mat2006, tumangik, GMianG, tuanpecc1
 Veggeta
Guatemala
User ID: 114
Threads: 98
Likes: 4,273 in 520 posts
Given Likes: 403
12-24-2014, 08:05 PM
[-] The following 6 users Like Veggeta's post:6 users Like Veggeta's post
  β€’ PinkPant, ykhackhack, axcel, oanm2000, nhim4mat2006, hamarat007
  ICOLD Bulletin 141 Concrete face Rockfill Dams - Concepts for design and construction ir_71 1 5,838 06-20-2020, 06:26 AM
Last Post: melkat
  Small Dams - Planning, Construction and Maintenance junaid 3 2,859 12-07-2016, 12:01 AM
