Civil Engineering Association eBooks Codes, Manual & Handbook ASME STS-1–2006 STEEL STACKS
 malc
User ID: 30599
Threads: 65
Likes: 1,520 in 155 posts
Given Likes: 15191
11-19-2011, 01:02 PM (This post was last modified: 08-22-2017, 01:29 AM by usman.)
Author: ASME | Size: 2 MB | Format: PDF | Publisher: ASME | Year: 2006 | pages: 108 | ISBN: 0791830055
[Image: 24748581176474850198.jpg]
The following Standard applies to steel stacks; that is, those stacks where the primary supporting shell is made of steel. It applies to both single- and multiple-walled steel stacks, either of which can be lined or unlined. It also applies to steel stacks that are guyed, or to certain aspects of tower stacks. The stack may be supported on a foundation or from another structure.
[Image: comments.png]
CONTENT:
Foreword . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . iv
Committee Roster . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . v
Correspondence with the Steel Stacks Committee . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . vi
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . vii
1 Mechanical Design . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
2 Materials . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
3 Linings and Coatings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
4 Structural Design . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
5 Dynamic Wind Loads . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20
6 Access and Safety . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23
7 Electrical . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28
8 Fabrication and Erection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29
9 Inspection and Maintenance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 31
10 References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 33
Figures
6.2.6-1 Example of the General Construction of Cages . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24
6.2.6-2 Minimum Ladder Clearances . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25
6.3.6 Ladder Dimensions, Support Spacing, and Side Clearances . . . . . . . . . . . . . . . . . . . 26
6.3.8 Landing Platform Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27
Tables
4.4.6 Factors of Safety . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
4.4.7 Minimum Structural Plate Thickness and Maximum Stiffener Spacing . . . . . . . . 16
4.10.1.3 Cable Selection Criteria . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18
5.2.1 Representative Structural Damping Values (_s) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21
Mandatory Appendix
I Structural Design . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35
Nonmandatory Appendices
A Mechanical Design . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 46
B Materials for Ambient and Elevated Temperature Service . . . . . . . . . . . . . . . . . . . . . 59
C Linings and Coatings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 75
D Structural Design . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 79
E Example Calculations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 86
F Conversion Factors: U.S. Customary to SI (Metric) . . . . . . . . . . . . . . . . . . . . . . . . . . . 97
Support this Association work if you get a direct benefit from it.
[-] The following 9 users Like malc's post:9 users Like malc's post
  • Jackass, kowheng, hcardenas, seriousboy, slowet, oanm2000, monter, oram, Dell_Brett
 shaker
User ID: 17336
Threads: 11
Likes: 714 in 73 posts
Given Likes: 537
10-27-2014, 03:29 AM
ASME STS-1–2006 - Steel Stacks
Author: The American Society of Mechanical Engineers | Size: 2.386 MB | Format: PDF | Quality: Original preprint | Year: 2006 | pages: 108 | ISBN: 0791830055
[Image: 08492932609497221202.jpg]
This Standard covers many facets of the design of steel stacks. It outlines the consideration which must be made for both the mechanical and structural design. It emphasizes what consideration must be taken for wind- and seismic-induced vibrations. It gives guidelines for the selection of material, linings, and coatings. It gives the requirements for lighting and lightning protection based upon existing building and federal codes. It gives the requirements for climbing and access based upon current Occupational Safety and Health Administration (OSHA) standards. It emphasizes the important areas regarding fabrication and construction. It outlines areas requiring maintenance and inspection following initial operation.
Although many of the topics within these guidelines may be used for all stacks, this Standard is intended to provide design guidelines for stacks containing nonflammable gases such as combustion exhaust gases at low internal pressures. For stacks containing combustible gases under pressure such as flare stacks and flammable vents, additional design considerations must be addressed, including design for internal pressure, design for internal deflagration pressure, and compatibility with adjoining piping design that is in accordance with piping and/or vessel design codes such as ASME B31.3 and Section VIII of the ASME Boiler and Pressure Vessel Code (BPVC). In addition, the materials of construction referenced in this Standard may not be allowed for use with flammable gases under pressure per ASME B31.3 and Section VIII of the ASME BPVC; materials suitable for pressure containment of flammable gases are listed in these codes. No attempt is made within this Standard to define the need or the methods to be used to consider these additional design considerations.
The information presented has been prepared in accordance with established engineering principles utilizing state-of-the-art information. It is intended for general information. While every effort has been made to ensure its accuracy, the information should not be relied upon for any specific application without the consultation of a competent, licensed professional engineer to determine its suitability. It is therefore recommended that Engineering/Design drawings of the stack bear the Professional Engineer Seal, signature, and date.
Nothing in the Standard shall be construed to alter or subvert the requirements of any existing code or authority having jurisdiction over the facility. Furthermore, alternate methods and materials to those herein indicated may be used, provided that the engineer can demonstrate their suitability to all affected agencies and authorities.
Use Winrar
[-] The following 13 users Like shaker's post:13 users Like shaker's post
  • gulilero, Hengki, ting tsai huang, zrilek, hatkam, Dell_Brett, blaze, jcbv, oanm2000, PinkPant, dinu69in, uncblue, febo927
  ASME SECTION VII 2013 - Recommended Guidelines for the Care of Power Boilers by ASME hodzicemir 1 2,173 09-28-2015, 01:44 PM
Last Post: PinkPant
