Civil Engineering Association eBooks Journals, Papers and Presentations Seismic Retrofitting of Historic Masonry Buildings – Case Study
Threads: 307
11-23-2010, 09:16 PM (This post was last modified: 11-26-2010, 12:54 PM by Grunf.)
Journal: Advanced Materials Research (Volumes 133 - 134)
Volume: Structural Analysis of Historic Constructions
Edited by: Xianglin Gu and Xiaobin Song
Pages: 991-996
Citation: A.R. Santhakumar et al., 2010, Advanced Materials Research, 133-134, 991
Online since: October, 2010
Authors: A.R. Santhakumar, M.S. Mathews, S. Thirumurugan, Rao Uma
Brick, Burnt Clay Brick, Carbon Fiber Sheet (CFS), Ferro-Cement, Ferrocement Bands, Lime Concrete, Load-Bearing Masonry, Retrofitting, Wire-Mesh
Abstract Masonry heritage building built during early part of 19th century have characteristic colonial architecture using masonry walls and jack arch roofing supported on steel beams. They are highly vulnerable to failure during earthquakes. This paper describes a methodology to quantify their vulnerability and then based on this a scheme of structural retrofitting is suggested. The aim of this presentation, through 4 case studies of buildings located in Delhi, India, is to exemplify various aspects of analysis, design and execution methodology of the retrofitting scheme for such important heritage structures. The assessment of vulnerability is based on its location, codes of practice with respect to materials and loading. The main challenge in choosing the appropriate retrofitting scheme lies in retaining the architecture and aesthetics. Also the retrofitting has to be completed in the least possible time causing minimum disturbance to the occupants. This has been achieved through a combination of Ferro-cement bands and FRP sheets. The execution of retrofitting was considered to make use of available local materials and expertise. The building is analysed in detail and the areas where stress concentration takes place is further strengthened.
The article can be found at:
[-] The following 5 users Like Grunf's post:5 users Like Grunf's post
  • sasan7351, pingfan2, shanta, Quantumm, zrilek
 hich
User ID: 3732
Threads: 94
Likes: 5,003 in 418 posts
Given Likes: 101
11-26-2010, 10:16 AM
here
[-] The following 11 users Like hich's post:11 users Like hich's post
  • kowheng, avscorreia, zrilek, Dell_Brett, jcoronellr, Grunf, blaze, usman, sodapas, avge, seriousboy
 gulilero
Italy
User ID: 14057
Threads: 102
Likes: 4,989 in 647 posts
Given Likes: 6732
08-28-2014, 02:22 PM
i will greatly appreciate a reposting of a link to this paper.
Thx.
[-] The following 1 user Likes gulilero's post:1 user Likes gulilero's post
  • mr.nicus
 gulilero
Italy
User ID: 14057
Threads: 102
Given Likes: 6732
05-26-2016, 03:19 AM
[-] The following 15 users Like gulilero's post:15 users Like gulilero's post
  • PinkPant, slowet, f_slikken, oanm2000, malc, Dell_Brett, agelos100, cabpcabp, aema, Wijono, cace-01, subin91, monter, erthqkengnr™, civilgen
  RESPONSE ANALYSIS STUDY OF A BASE-ISOLATED BUILDING BASED ON SEISMIC CODES WORLDWIDE TAFATNEB 0 5,247 08-10-2014, 01:15 PM
  Constructing Seismic Resistant Masonry Houses in Indonesia RyanRS 0 4,307 07-19-2014, 04:44 AM
Last Post: RyanRS
  SEISMIC RETROFIT STUDY OF CABLE-STAYED BRIDGE ON TOKYO-GAIKAN EXPRESSWAY TAFATNEB 0 4,239 05-02-2014, 08:58 AM
  Analytical Case Study of Seismic Performance of Retrofit Strategies for Reinforced Co TAFATNEB 0 4,496 04-17-2014, 10:21 AM
  Seismic retrofit of masonry buildings with polymer grid TAFATNEB 0 4,261 04-03-2014, 12:50 PM
  Seismic Behaviour and Retrofit of Historic Masonry Minaret TAFATNEB 0 4,473 12-12-2013, 08:06 PM
  Study on corollary of seismic base isolation system on buildings with soft storey TAFATNEB 1 5,093 11-20-2013, 06:43 AM
