Civil Engineering Association Software Software Product Csi Products Bridge CSi Bridge V17
CSi Bridge V17
 aslam
Abu Dhabi
User ID: 64
Threads: 284
Likes: 7,707 in 755 posts
Given Likes: 2168
08-07-2014, 04:59 AM (This post was last modified: 10-18-2023, 08:44 AM by Administrator.)
CSI BRIDGE 2015 v17
CSiBridge 2015 Enhancements
The following Enhancements have been implemented for CSiBridge 2015 v17.0.0:
The responsiveness of the user interface has been improved.
The DirectX graphics functionality has been enhanced.
A friction-spring hysteretic damper has been implemented as a new link property. The force-displacement relationship exhibits linear slipping stiffness when loading, but unloads with a smaller slipping stiffness. A pre-compression displacement and a displacement stop-limit may be specified.
A bilinear Maxwell damper has been implemented as a new link property. This device is a linear spring in series with a dashpot whose force-velocity relationship exhibits bilinear viscous behavior, typical of certain oil dampers having a relief valve.
Improved convergence behavior and increased speed for nonlinear static and direct-integration time-history analysis.
Increased speed of moving load analysis by parallelization.
Superstructure design checking has been extended to include composite bridge superstructures with steel U-girders according to the Canadian CAN/CSA-S6-06 code.
Superstructure design checking has been extended to include composite bridge superstructures with steel U-girders according to the Indian IRC-2011 code.
Superstructure design checking has been implemented for concrete superstructure sections according to the Russian SNiP 2.05.03-84 code. Superstructure types supported include prestressed concrete box girders and composite sections with precast I-girders and U-girders.
Superstructure design reports have been enhanced to include step-by-step detailed output, including equations and code references. These are currently available for AASHTO LRFD 2007 and 2012, for multi-cell concrete box shear and flexure checks and precast composite I-beam shear and flexure checks.
A traditional menu has been added as an alternative to the ribbon. Users can switch between the two options.
The ribbon style has been updated to be similar to current Microsoft applications.
Other minor enhancements.
[Image: homepage.png]
[-] The following 24 users Like aslam's post:24 users Like aslam's post
  β€’ blaze, zrilek, yamacdere, bridgeengineer, TAFATNEB, dquan373, milvio, ykhackhack, PinkPant, Rodmo376, haiquyppl1984, Visitante, bigone, pohpo, jamesmakeez, malc, Mohammad6299, faros3000, Rami11, slowet, nickycruz, oanm2000, pram, terrorruban
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
08-07-2014, 02:31 PM
CSI BRIDGE 2015 v17
[-] The following 17 users Like arshiakh's post:17 users Like arshiakh's post
  β€’ PinkPant, oanm2000, stosto6666, toa011, Jackass, Visitante, bigone, pohpo, jfjdm, Mohammad6299, Rami11, slowet, mgdario, simanta, nickycruz, Dell_Brett, blaze
 jamesmakeez
Scotland
User ID: 86344
Threads: 4
Likes: 210 in 10 posts
Given Likes: 20
08-07-2014, 09:46 PM (This post was last modified: 08-07-2014, 09:47 PM by jamesmakeez.)
CSi Bridge 2015 Keygen
Confirmed Keygen for 2014 works for CSi Bridge 2015. (As it did for SAP2000 v17)
[-] The following 29 users Like jamesmakeez's post:29 users Like jamesmakeez's post
  β€’ Visitante, bigone, pohpo, malc, jfjdm, Mohammad6299, stosto6666, ykhackhack, zrilek, PinkPant, Rami11, Jackass, slowet, oanm2000, faros3000, mgdario, arshiakh, fretts08, nibbi, nickycruz, MOSS2000, Andrew seah, Dell_Brett, blaze, stigtg, jcbv, TAFATNEB, pram, tang1942
 aslam
Abu Dhabi
User ID: 64
Threads: 284
Given Likes: 2168
09-04-2014, 04:13 PM (This post was last modified: 09-04-2014, 04:14 PM by aslam.)
CSI BRIDGE 2015 v17.1.0
[-] The following 21 users Like aslam's post:21 users Like aslam's post
  β€’ zrilek, oanm2000, rezart, malc, jamesmakeez, Andrew seah, faros3000, Mohammad6299, cace-01, simanta, blaze, mgdario, Rodmo376, Dell_Brett, Jackass, SCREAM7890, bhowmik, bigone, axcel, TAFATNEB, tang1942
Threads: 1,118
09-05-2014, 02:26 PM
The old KG works giving 117 days (you know how to extend using
Date Fake
The new of Lavteam give 317 days but is identified as virus (at least by my Antivirus). Disable it for a few minutes. The same generated license works in SAP2000 too.
[Image: 24890511134263636109.gif]
  β€’ Mohammad6299, blaze, aslam, Dell_Brett, ykhackhack, PinkPant, oanm2000, Diquan, bigone, bridgeengineer, axcel
 Jackass
Bolivia
User ID: 29460
Threads: 24
Likes: 1,138 in 115 posts
Given Likes: 7399
10-02-2014, 05:03 PM (This post was last modified: 10-02-2014, 05:04 PM by Jackass.)
Hi
CSI Bridge 15 v17.1.1
[-] The following 20 users Like Jackass's post:20 users Like Jackass's post
  β€’ seriousboy, bridgeengineer, zrilek, rezart, oanm2000, inge911, bigone, faros3000, TAFATNEB, malc, blaze, simanta, PinkPant, amindoxiti, Dell_Brett, stigtg, SCREAM7890, jcbv, Williams, pram
 mowafi3m
Egypt
User ID: 1236
Threads: 384
Likes: 9,319 in 677 posts
Given Likes: 1667
10-05-2014, 10:18 AM (This post was last modified: 10-05-2014, 12:31 PM by Dell_Brett.)
new csi license generator
Moderator note:
This keygen is the same as LT forum.
Some antivirus detects a virus (ESET SMART SECURITY and others). It's a FALSE POSITIVE.
But, use at your own risk!
[-] The following 21 users Like mowafi3m's post:21 users Like mowafi3m's post
  β€’ malc, jokerβ„’, stigtg, cace-01, zrilek, Andrew seah, jcbv, dl4all, blaze, oanm2000, aslam, TAFATNEB, simanta, Limpias72, bigone, MOSS2000, knrsa, melekeen, terrorruban, nibbi, slowet
01-11-2015, 05:35 PM
TORRENT CSI Bridge 2015 17.1.1.1099
Modeling, analysis and design of bridge structures have been integrated into CSI Bridge to create the ultimate in computerized engineering tools. The ease with which all of these tasks can be accomplished makes CSI Bridge the most versatile and productive software program available on the market today.
Using CSI Bridge, engineers can easily define complex bridge geometries, boundary conditions and load cases. The bridge models are defined parametrically, using terms that are familiar to bridge engineers such as layout lines, spans, bearings, abutments, bents, hinges and post-tensioning. The software creates spine, shell or solid object models that update automatically as the bridge definition parameters are changed.
CSI Bridge design allows for quick and easy design and retrofitting of steel and concrete bridges. The parametric modeler allows the user to build simple or complex bridge models and to make changes efficiently while maintaining total control over the design process. Lanes and vehicles can be defined quickly and include width effects. Simple and practical Gantt charts are available to simulate modeling of construction sequences and scheduling.
CSI Bridge includes an easy to follow wizard that outlines the steps necessary to create a bridge model.
[-] The following 14 users Like TAFATNEB's post:14 users Like TAFATNEB's post
  β€’ blaze, oanm2000, zrilek, Dell_Brett, PinkPant, Munykong, hamarat007, nibbi, bridgeengineer, rendel_Β©, Williams, apocalipse, bigone, narendra
 rezart
User ID: 25808
Threads: 66
Likes: 2,748 in 178 posts
Given Likes: 5842
05-21-2015, 12:02 PM
CSi BRIDGE v17.2
[-] The following 12 users Like rezart's post:12 users Like rezart's post
  β€’ jokerβ„’, RyanRS, PinkPant, oanm2000, milvio, emmi, aslam, blaze, slowet, simanta, faros3000, bigone
Threads: 1,118
#10
05-25-2015, 05:01 AM
Bridge2015 17.2 License (including for SAP2000 17.2)
Curtesy of Lavteam
Password
In case you want other links (soft+med)
[Image: 23731714102649588995.gif]
[-] The following 21 users Like BennyP's post:21 users Like BennyP's post
  β€’ ykhackhack, cace-01, emmi, pezhmankhan, Andrew seah, blaze, slowet, avscorreia, Dell_Brett, PinkPant, milvio, faros3000, oanm2000, apocalipse, Williams, alcalan57, faxel, bigone, jik686, engrezi, ting tsai huang
Pages (2): 1 2 Next »
