Civil Engineering Association eBooks Journals, Papers and Presentations Lateral-torsional buckling capacity assessment of web opening steel girders by artifi
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
08-02-2014, 10:21 AM (This post was last modified: 08-02-2014, 10:25 AM by ssobhan.)
Lateral-torsional buckling capacity assessment of web opening steel girders by artificial neural networks — elastic investigation
Author: Yasser Sharifi, Sajjad Tohidi | Size: 442 KB | Format: PDF | Quality: Original preprint | Publisher: Springer | Year: 2014 | pages: 11
[Image: 82125727895278560687.png]
Abstract
Bridge girders exposed to aggressive environmental conditions are subject to time-variant changes in resistance. There is therefore a need for evaluation procedures that produce accurate predictions of the load-carrying capacity and reliability of bridge structures to allow rational decisions to be made about repair, rehabilitation and expected life-cycle costs. This study deals with the stability of damaged steel I-beams with web opening subjected to bending loads. A three-dimensional (3D) finite element (FE) model using ABAQUS for the elastic flexural torsional analysis of I-beams has been used to assess the effect of web opening on the lateral buckling moment capacity. Artificial neural network (ANN) approach has been also employed to derive empirical formulae for predicting the lateral-torsional buckling moment capacity of deteriorated steel I-beams with different sizes of rectangular web opening using obtained FE results. It is found out that the proposed formulae can accurately predict residual lateral buckling capacities of doubly-symmetric steel I-beams with rectangular web opening. Hence, the results of this study can be used for better prediction of buckling life of web opening of steel beams by practice engineers.
[-] The following 10 users Like ssobhan's post:10 users Like ssobhan's post
  • amindoxiti, malc, blaze, Mohammad6299, Dell_Brett, jcbv, subin91, warlord1, zrilek, slowet
  Fire resistance assessment of steel structures mowafi3m 1 5,704 06-19-2015, 12:21 PM
Last Post: Dell_Brett
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 6,121 10-08-2014, 02:06 PM
  Seismic Vulnerability Assessment of Modular Steel Buildings TAFATNEB 0 4,355 05-09-2014, 10:16 AM
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 1 5,344 11-28-2013, 12:06 PM
  SEISMIC LATERAL FORCE DISTRIBUTION FOR DUCTILITY-BASED DESIGN OF STEEL PLATE SHEAR WA TAFATNEB 0 4,060 08-31-2013, 10:41 AM
  Assessment of the Environmental Effects on the Performance of FRP Repaired Steel Pipe asim99 0 3,778 05-21-2013, 07:42 PM
  The effects of long term uniform corrosion on the buckling of ground based steel tank arshiakh 0 5,064 04-24-2013, 07:38 PM
Last Post: arshiakh
