Civil Engineering Association eBooks Structural Books Analysis & Design Mechanics of Optimal Structural Design
 i_kabir
Bangladesh
User ID: 741
Threads: 122
Likes: 3,231 in 259 posts
Given Likes: 446
07-27-2014, 09:16 AM
Mechanics of Optimal Structural Design: Minimum Weight Structures
Author: David W. A. Rees | Size: 5.86 MB | Format: PDF | Quality: Original preprint | Publisher: John Wiley and Sons | Year: 2009 | pages: 565 | ISBN: 9780470746233
[Image: 28198516593722386682.jpg]
In a global climate where engineers are increasingly under pressure to make the most of limited resources, there are huge potential financial and environmental benefits to be gained by designing for minimum weight. With Mechanics of Optimal Structural Design, David Rees brings the original approach of weight optimization to the existing structural design literature, providing a methodology for attaining minimum weight of a range of structures under their working loads. He addresses the current gap in education between formal structural design teaching at undergraduate level and the practical application of this knowledge in industry, describing the analytical techniques that students need to understand before applying computational techniques that can be easy to misuse without this grounding.
> Shows engineers how to approach structural design for minimum weight in clear, concise terms
> Contains many new least-weight design techniques, taking into consideration different manners of loading and including new topics that have not previously been considered within the least-weight theme
> Considers the demands for least-weight road, air and space vehicles for the future
> Enhanced by illustrative worked examples to enlighten the theory, exercises at the end of each chapter that enable application of the theory covered, and an accompanying website with worked examples and solutions housed at www.wiley.com/go/rees
The least-weight analyses of basic structural elements ensure a spread of interest with many applications in mechanical, civil, aircraft and automobile engineering. Consequently, this book fills the gap between the basic material taught at undergraduate level and other approaches to optimum design, for example computer simulations and the finite element method.
[-] The following 21 users Like i_kabir's post:21 users Like i_kabir's post
  â€¢ zrilek, ykhackhack, vardan, blaze, malc, slowet, PinkPant, cace-01, ruaumoko, apocalipse, herea, gulilero, bridgeengineer, jfjdm, Mohammad6299, Dell_Brett, ibg0203, optima, mgdario, cristi, kamehameha
  Optimal Design of Flexural Systems: Beams, Grillages, Slabs, Plates and Shells apocalipse 1 5,570 01-11-2015, 10:12 PM
Last Post: Veggeta
  Optimal Structural Analysis amindoxiti 0 3,824 09-19-2014, 03:13 PM
  Advances in Metaheuristic Algorithms for Optimal Design of Structures pezhmankhan 0 3,941 08-08-2014, 02:00 PM
Last Post: pezhmankhan
