Civil Engineering Association eBooks Water & Hydraulic Engineering Handbook of Engineering Hydrology: Fundamentals and Applications
 cace-01
User ID: 15651
Threads: 433
Likes: 10,522 in 867 posts
Given Likes: 7468
07-07-2014, 07:47 PM (This post was last modified: 07-07-2014, 07:51 PM by cace-01.)
Author: Saeid Eslamian | Size: 14 MB | Format: PDF | Quality: Unspecified | Publisher: CRC Press | Year: 2014 | pages: 636 | ISBN: 1466552417, 9781466552449, 1466552441
[Image: 17433191804455344557.jpeg]
While most books only examine the classical aspects of hydrology, the three-volume set covers multiple aspects of hydrology, and includes contributions from experts from more than 30 countries. It examines new approaches, addresses growing concerns about hydrological and ecological connectivity, and considers the worldwide impact of climate change.
It also provides updated material on hydrological science and engineering, discussing recent developments as well as classic approaches. Published in three books, Fundamentals and Applications; Modeling, Climate Change, and Variability; and Environmental Hydrology and Water Management, the entire set consists of 87 chapters, and contains 29 chapters in each book.
The chapters in this book contain information on:
Long-term generation of scheduling of hydro plants, check dam selection procedures in rainwater harvesting, and stochastic reservoir analysis
Ecohydrology for engineering harmony in the changing world, concepts, and plant water use
Conjunctive use of groundwater and surface water
Hydrologic and hydraulic design in green infrastructure
Data processing in hydrology, optimum hydrometric site selection and quality control, and homogenization of climatological series
Cold region hydrology, evapotranspiration, and water consumption
Modern flood prediction and warning systems, and satellite-based systems for flood monitoring and warning
Catchment water yield estimation, hydrograph analysis and base flow separation, and low flow hydrology
Sustainability in urban water systems and urban hydrology
Students, practitioners, policy makers, consultants and researchers can benefit from the use of this text.
Thanks to Original Uploader
[-] The following 20 users Like cace-01's post:20 users Like cace-01's post
  â€¢ amindoxiti, malc, Mohammad6299, ibg0203, inge911, ssobhan, pedzaquino, zrilek, PinkPant, Dell_Brett, ska51, jfjdm, blaze, isurya, Jackass, ykhackhack, Raktim, kowheng, tuanpecc1, nhim4mat2006
 i_kabir
Bangladesh
User ID: 741
Threads: 122
Likes: 3,231 in 259 posts
Given Likes: 446
08-02-2014, 04:41 PM (This post was last modified: 03-25-2019, 11:21 AM by lisine. Edit Reason: mirror to code )
[-] The following 6 users Like i_kabir's post:6 users Like i_kabir's post
  â€¢ Dell_Brett, gulilero, milova, emmaoyen, ykhackhack, ska51
 emmi
Laos
User ID: 26
Threads: 33
Likes: 969 in 102 posts
Given Likes: 1203
10-05-2015, 01:19 AM
Thanks to origonal uploader
[-] The following 9 users Like emmi's post:9 users Like emmi's post
  â€¢ ykhackhack, ting tsai huang, PinkPant, Dell_Brett, oanm2000, dinu69in, Andrew seah, ska51, blaze
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1405
03-07-2016, 10:50 PM
Size: 12.1 MB | Format: PDF | Quality: Original preprint
  â€¢ f_slikken, oanm2000, Dell_Brett, Raktim, ska51
 rigid_joint
Senior Member
Jamaica
User ID: 6110
Threads: 13
Likes: 333 in 122 posts
Given Likes: 244
09-04-2018, 01:59 PM (This post was last modified: 09-04-2018, 09:20 PM by oanm2000.)
[-] The following 5 users Like rigid_joint's post:5 users Like rigid_joint's post
  â€¢ oanm2000, Dell_Brett, PinkPant, subin91, kowheng
Threads: 57
03-24-2019, 08:34 AM
Size: 15.2 MB | Format: PDF
[-] The following 8 users Like kowheng's post:8 users Like kowheng's post
  â€¢ mgdario, PinkPant, tuanpecc1, Nita1391, oanm2000, spat, Dell_Brett, ska51
  Handbook of engineering hydrology : modeling, climate change, and variability cace-01 4 3,429 10-01-2018, 05:04 PM
Last Post: febo927
  Handbook of Engineering Hydrology: Environmental Hydrology and Water Management (Volu febo927 0 1,697 09-28-2018, 05:01 PM
Last Post: febo927
  Engineering Hydrology ska51 2 2,696 09-12-2017, 02:23 PM
  Stochastic and Statistical Methods in Hydrology and Environmental Engineering ska51 0 1,648 11-20-2016, 06:57 AM
Last Post: ska51
  Fluid Mechanics: Fundamentals and Applications 3rd edition rami1976 0 1,861 05-02-2016, 11:10 AM
  Handbook of Engineering Hydrology: Environmental Hydrology and Water Management cace-01 3 3,047 03-07-2016, 10:43 PM
  Handbook of Hydrology ska51 4 4,248 12-28-2015, 11:22 AM
Last Post: ska51
