Civil Engineering Association Software Software Product Bentley Products RAM Connection V8i (SELECTseries 4) 8.0.0.23 1000 days trial
Threads: 1,118
09-26-2012, 06:05 AM
[Image: 62286413659563808405.gif]
[Image: 53595349213305750120.gif]
[Image: 92624226235396114701.gif]
RAM Connection, a flexible and powerful program for analysis and design of steel connection for W, HSS and similar sections.
This software offers the best flexibility for the design of different shear, moment, braces, splices and base plates connection types. It is based on the AISC, ASD and LRFD codes, and the British Standard.
The standalone version works independently of any other software.
The connections can be designed in three different ways in RAM Connection Standalone (RCSA).
The first method can be called trial and error, in which the user defines a database with all the different connections (notice that several connections are already provided by the software) and assign them, to the joint, one by one. The software will indicate if the connection assigned is adequate or not. If the connection is not adequate, the user can assign manually another connection or adjust the initial one in such a way that fulfills all the requirements.
The second method consists in making the program search in a list of the connections database until it founds a connection that works well in the joint (according to geometry and loads).
The third method is similar to the second but instead of searching in a pre-defined list the software assigns a smart connection that adapts to the joint. In these connections, the design is automatically where the parameters of the connections (e.g. bolt number, weld size, plate size, etc) are adjusted until the connection fulfills the requirements.
[Image: tips.png]
If not installed download and install IEG License Service. The Dashboard is optional.
Copy the dll in the installation folder. For me the Standalone version works without any crack but maybe some files are present from previous installations.
VIP can use the file and codes received from struceng in thread IEG License service v2.0.18.6
[-] The following 41 users Like BennyP's post:41 users Like BennyP's post
  β€’ coxxxyboy, pezhmankhan, Andrew seah, Dell_Brett, jokerβ„’, gacella, oanm2000, JOGAR71, ykhackhack, faros3000, seriousboy, haze, cordoba123, zrilek, Diquan, nickycruz, MOSS2000, Nilupa, bigone, valinhas, Hengki, napeera, panchotevi, hosseinnet, 3fan, nibbi, anf-b, ali akbar, engiman27, narendra, jonny78, simanta, DamaD, Rodmo376, ting tsai huang, Visitante, kutuuz, tentaeste, julioreptil, K.Lee, Clouseau
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
09-28-2012, 05:46 PM
No limits to creativity
[-] The following 14 users Like jokerβ„’'s post:14 users Like jokerβ„’'s post
  β€’ oanm2000, cordoba123, pedzaquino, zrilek, Diquan, malc, andyspak2, Nilupa, bigone, Dell_Brett, ykhackhack, jonny78, ting tsai huang, Clouseau
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
11-14-2012, 10:05 AM (This post was last modified: 11-14-2012, 10:24 AM by bigone.)
RAM Connection v8.0 Release Notes – Updated August 2012
Enhancements
AISC Design Guide 16 now allows for thin plate behavior on end plates, plus the ability to specify flushed end plates (not only extended per DG 4) and multiple rows of bolts.
Metal building connections for frames with tapered members (rafters and/or columns) per AISC 360 and Design Guide 25. These include knee (beam-to-column), splice and ridge connections. Base plates for tapered columns coming soon!
Portal frame connections for frames using rafters with haunches. The design can be carried out per AISC 360 or BS 5950. These include eave, splice and apex connections.
New column stiffener configurations.
Added support for Canadian steel sections.
Structural Synchronizer V8i (ISM) v3.0 compatible (only available in the RAM Connection for RAM Elements mode now):
a. Feature additions (gusset plates, base plates, end plates and stiffeners)
b. Connection tags
Resolved Issues
Member incompatibility warnings have been enriched substantially. His has been accomplished in three ways:
a. A bug was inadvertently introduced in v7.3.2 that triggered the majority of these warnings. That has been fixed.
b. Others are now handled automatically by the software and thus, disappeared, not shown anymore.
c. The rest, 100% valid, are now explained more clearly in the design report.
VIDEO : An overview of some of the new features found in RAM Connection v5.5, including an example of using the column-beam-brace connection.
(Note: The audio is relatively loud on this recording, so you may want to turn down - or even mute - your computer's speakers.)
Or Direct link:
[-] The following 5 users Like bigone's post:5 users Like bigone's post
  β€’ eliseo.as, valinhas, Diquan, jonny78, Clouseau
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
12-06-2012, 08:26 PM (This post was last modified: 12-20-2012, 09:48 AM by LiviuM.)
Only Med ( Uploader By: ykhackhack )
Password
CivilEA
[-] The following 11 users Like jokerβ„’'s post:11 users Like jokerβ„’'s post
  β€’ ykhackhack, eng donny, haze, nickycruz, ASEC, engiman27, jonny78, DamaD, bigone, Diquan, Clouseau
 bigone
User ID: 4505
Threads: 85
Given Likes: 7145
06-05-2014, 11:14 AM (This post was last modified: 06-05-2014, 11:19 AM by bigone.)
RAM Connection V8i
(Version: 09.00.00.41 FileSize: 159 MB)
RAM Connection V9.0 Release notes
Enhancements
ANSI/AISC 360-10 Specification for Structural Steel Buildings.
ANSI/AISC 341-10 Seismic Provisions for Structural Steel Buildings
ANSI/AISC 358-10 with ANSI/AISC 358s1-11 Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications with 2011 Supp. No. 1
GB 50017-2003 Code for Design of Steel Structures.
Brand new and modern user interface for the Connection Pad.
RAM Connection for RAM Structural System can now be launched within RAM Manager.
Bentley Trust Licensing has been implemented. Thanks to Trust Licensing, users can always access the software they need to get their work done. It lets users access software whenever they need it, even if a license is not available.
Tapered columns are now allowed in base plate connections.
Flange plate connections now handle minor axis moments (M22) besides the major axis moment (M33).
Gusset plates keep their dimensions when switching from Automatic configuration to Manual.
European steel sections added to the database.
The assignment time
Resolved Issues
The MEP beam splice had a section depth validation problem that has been corrected.
There was a crash in certain instances when selecting the Results report for MEP with DG16 as some distances were not correctly initialized. This has been fixed.
The minimum cope depth in double angle connections was calculated to a greater value than the maximum cope depth, this occurs when the beam depth is too small to support the appropriate notches. A warning has been added when the cope dimensions are out of the standard practice.
The gusset length for CBB connections without a beam (β€œK” type) in the Manual option had a problem. This was solved and now the Manual option works correctly as well as the Automatic one.
In MEP connections, the thick plate behavior for the column flange was being printed in the wrong report section. The report was re-organized to have the end plate and column flange thick plate behavior checks together.
The distance from the connector to the top of the beam flange was miscalculated for gusset connections. The Data report now shows the location of the gusset connector relative to the beam top flange.
There was a problem in the base plate analysis for when no anchors were defined. The analysis now handles zero anchors.
Gusset base plates were being assigned to joints with braces framing from perpendicular directions. The braces have to be in the same plane (either X or Z) for this connection to work correctly. As this was not a valid joint, now this is not possible.
In some instances, different strength ratios were shown for thumbnail and the Design report in RAM Connection Standalone. This has been corrected.
[-] The following 24 users Like bigone's post:24 users Like bigone's post
  β€’ zrilek, aema, Dell_Brett, blaze, ting tsai huang, oanm2000, vvvv, jjmtz, MOSS2000, bridgeengineer, nickycruz, olgabehe, malc, Diquan, ykhackhack, malee, jokerβ„’, dovsky, Williams, ranger, raja, tooraj41, lesgiu, Clouseau
 bigone
User ID: 4505
Threads: 85
Given Likes: 7145
06-30-2014, 07:42 AM
RAM Connection V8i
(Version: 09.01.00.94 Date: 6/6/2014 12:00:00 AM FileSize: 29.69 MB)
RAM Connection V9.1 Release Notes
Updated June 2014
Enhancements
ACI 318-11 Appendix D update for anchor design in base plates.
Base plate assignment and design speed has been increased remarkably.
Option to include the footing/pedestal reinforcement in the anchor design per ACI 318-11 D.5.2.9 (tension) and D.6.2.9 (shear).
Option to include friction effects (base plate against concrete) in anchor shear resistance per AISC Design Guide 1 section 3.5.1.
The anchor bolts database can now be edited by the user, just like the regular bolts database.
Resolved Issues
The correct design code is now being reported in the design reports. Version 9.0 had this mishap inadvertently.
Shear rupture is no longer checked for beams with no copes.
Through plate connections now check compression buckling for long plates and eccentricity is properly calculated for bolts and welds.
Connection IDs and Descriptions are no longer missing in the report.
Shear lug dimensions were not being displayed correctly in the DXF view.
Splice plates were not drawing one plate only when the single plate option was being checked in the Connection Pad.
The slip coefficient Β΅ for Class A surfaces was using the AISC 360-05 value (0.35), even when AISC 360-10 (0.30) was being selected. This has now been fixed.
[-] The following 17 users Like bigone's post:17 users Like bigone's post
  β€’ cace-01, malc, raja, Dell_Brett, zrilek, oanm2000, ykhackhack, Williams, jjmtz, simanta, kardels, jcbv, Rodmo376, faros3000, lesgiu, Diquan, Clouseau
 bigone
User ID: 4505
Threads: 85
Given Likes: 7145
07-01-2014, 11:23 AM (This post was last modified: 07-01-2014, 11:26 AM by bigone.)
RAM Connection V8i
(Version: 09.01.00.94 )
Bentley Limcon v3.63.01.11 crack is working for ram connection - worked with me-
[-] The following 18 users Like bigone's post:18 users Like bigone's post
  β€’ ykhackhack, Dell_Brett, jcbv, Mohammad6299, rigid_joint, dl4all, faros3000, zrilek, Williams, mecheil.edwar, malc, oanm2000, blaze, lesgiu, Diquan, oreslaw, ting tsai huang, Clouseau
 rigid_joint
Senior Member
Jamaica
User ID: 6110
Threads: 13
Likes: 333 in 122 posts
Given Likes: 244
07-01-2014, 02:54 PM (This post was last modified: 07-01-2014, 03:00 PM by rigid_joint.)
Thank you for the hint. I think that the provided link needs a password for the creation of the download link.
Also, is there any place to download the above trial version because I didn't find any download trial section in Bentley site
[-] The following 2 users Like rigid_joint's post:2 users Like rigid_joint's post
  β€’ Diquan, Clouseau
 Williams
Nigeria
User ID: 24556
Threads: 15
Likes: 422 in 87 posts
Given Likes: 779
07-01-2014, 04:52 PM (This post was last modified: 07-02-2014, 12:18 AM by Dell_Brett.)
use "www.civilea.com"
[-] The following 3 users Like Williams's post:3 users Like Williams's post
  β€’ Diquan, oreslaw, Clouseau
 mecheil.edwar
Senior Member
User ID: 27088
Threads: 25
Likes: 612 in 216 posts
Given Likes: 1759
#10
07-30-2014, 09:32 AM (This post was last modified: 07-30-2014, 09:38 AM by mecheil.edwar.)
RAM Connection V8i Version: 09.01.00.94
Cr**ck for Li** m**con v3.63.01.11 Tested on Windows 8/ 64 Bit and working very well.
[-] The following 7 users Like mecheil.edwar's post:7 users Like mecheil.edwar's post
  β€’ malc, Dell_Brett, oanm2000, Diquan, bigone, eng donny, Clouseau
Pages (2): 1 2 Next »
  RAM Elements V8i (SELECTseries 4) 13.0.0.22 1000 days trial BennyP 9 25,585 08-23-2015, 06:24 AM
Last Post: ykhackhack
  Bentley PondPack 08.11.01.54 V8i (30 days trial and renew) BennyP 4 14,058 02-15-2015, 12:06 AM
Last Post: fayezkazi
  Bentley Staad Pro v8 (SELECTseries 4) 20.07.09.31 (15 days trial) BennyP 4 16,076 09-09-2013, 05:23 AM
Last Post: pezhmankhan
  Bentley Watercad V8i (SELECTseries 2) 08.11.02.31 (Trial) BennyP 2 10,644 04-20-2013, 07:47 PM
Last Post: jokerβ„’
  Bentley SewerGEMS v8i (SELECTseries 2) 08.11.02.46 (Trial) BennyP 8 19,915 01-22-2013, 02:37 PM
Last Post: jokerβ„’
  STAAD.Pro V8i SELECTseries 4 (20.07.09.11) - Trial Version kardels 4 17,859 11-25-2012, 10:03 AM
Last Post: jokerβ„’
  STAAD(X) Tower V8i (SELECTseries 1) 08.02.01.48 (trial only) BennyP 2 11,294 08-19-2012, 09:03 AM
Last Post: jupe01
