Civil Engineering Association Software Software Product Bentley Products Bentley Limcon V3
Bentley Limcon V3
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
06-30-2014, 08:10 AM
Bentley Limcon v3.63.01.11 build 13.06.2014
[Image: 58465353538847425051.png]
In November of 2013 Microstran software products (Limcon, MStower, Microstran) are now part of Bentley Systems
Limcon is productivity-geared steel connection design software. Connection types include beam to column, brace end, member splices, anchorage to concrete, and complicated multi-member joints. By using a library of standard connection types, designers can arrive at results in a remarkably short time.
Comprehensive limit state design to a number of international standards.
Shear and moment connections, member splices, brace end connections, base plates, and hollow section connections.
Connections may be auto-designed by program or specified directly by user.
Concise calculation summary, reporting results for all relevant limit states.
Output to CAD format directly from design.
[Image: homepage.png]
[-] The following 40 users Like bigone's post:40 users Like bigone's post
  β€’ Andrew seah, blaze, Dell_Brett, cace-01, warlord1, Hengki, Mohammad6299, zrilek, dl4all, subin91, jokerβ„’, oanm2000, karthikeyans3d, icmrb7777, ruaumoko, olgabehe, Williams, ting tsai huang, malc, simanta, ranger, faros3000, jjmtz, stigtg, jacky899, Limpias72, narendra, harsono, Batman07, Iswandi, ykhackhack, anfaga, mastermind, adams, tescomuffinman, nan54, melekeen, jcoronellr, feron, valinhas
 l_namali
User ID: 2969
Threads: 11
Likes: 498 in 47 posts
Given Likes: 130
07-01-2014, 01:33 PM
Here it is, Sunilmtech
Source file from bigone. Thanks to the OP!
[-] The following 20 users Like l_namali's post:20 users Like l_namali's post
  β€’ zrilek, oanm2000, pedzaquino, bigone, Vincwilson, cristi, harsono, Batman07, hamarat007, Hengki, pousin, monter, dinu69in, anfaga, adams, ykhackhack, simanta, melekeen, valinhas, davegabj
 bigone
User ID: 4505
Threads: 85
Given Likes: 7145
04-24-2015, 02:04 PM (This post was last modified: 04-24-2015, 02:09 PM by bigone.)
Bentley Limcon v3.63.1.21
install file (size 19.47 MB)
[Image: 42690244820610821846.png]
.rar   Bentley.Limcon.v3.63.01.11 try it now! patch.rar (Size: 2.15 MB / Downloads: 247)
[-] The following 26 users Like bigone's post:26 users Like bigone's post
  β€’ PinkPant, MOSS2000, jokerβ„’, cristi, dovsky, faros3000, usman, hzaheer, Williams, oanm2000, ykhackhack, Munykong, pedzaquino, chenamoy, PSMUSACALA, mecheil.edwar, malc, eliseo.as, Limpias72, monter, harsono, rendel_Β©, emmi, knrsa, PanosP, melekeen
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1405
11-23-2015, 01:22 PM (This post was last modified: 11-23-2015, 01:24 PM by rami1976.)
Bentley Limcon 03.63.02.04 build 12/10/2015
[Image: 72749864359516519046.jpg]
What's New :
New Connections
Β  Β Hollow structural section connections.
Β  Β 4-bolt and 8-bolt moment end plate connections for RHS/SHS.
Β  Β AISC flush and extended multiple row moment end plate connections.
Β  Β Bolt goup and weld group.
Other New Features
Β  Β Options for checking to AISC LRFD and BS 5950*.
Β  Β Additional libraries, bolt sizes, and grades.
Β  Β Section library management / section input.
Β  Β Display of section and member mark in virtual reality view.
Β  Β Optional elastic/plastic analysis for splices and moment connections.
Additions to Existing Connections
Β  Β Axial loads in WSP, FEP, and ACLT connections.
Β  Β Column shear in haunched moment end plate connection.
Β  Β Option for 4 lines of bolts in splice plates and moment end plates.
Β  Β More than 2 columns of bolts in web splice plates.
Β  Β More than 2 columns of bolts in bracing cleat.
Β  Β Checking of attached plate and member in bracing cleat connection.
Β  Β Revised weld capacity requirement in web side plate connection.
[Image: comments.png]
Unrar
Install the app in the default path.
Apply patch (run as admin).
  • Related Link:
    how to use hulkload.com , pls refer to :
[-] The following 22 users Like rami1976's post:22 users Like rami1976's post
  β€’ oanm2000, jokerβ„’, ISTRAKTURA, faros3000, Dell_Brett, psk62, shaker, malc, adams, chenamoy, karthikeyans3d, Williams, harsono, ting tsai huang, monter, rendel_Β©, deltalead, jcbv, mowafi3m, jacky899, sodapas, Aviator
 Pitagora
User ID: 20731
Likes: 15 in 5 posts
Given Likes: 99
03-16-2016, 07:20 PM
Hello Guys,
The Link is not the original posted !
Malware
Malware detected by Kaspersky and no password is required to unzip the file ....
Can someone reload, Please ?
Thanks for the help in advance.
  β€’
 rami1976
User ID: 34597
Threads: 355
Given Likes: 1405
03-16-2016, 10:05 PM
The file was downloaded 128 times without problem , but due to your request this is a mirror :
[-] The following 8 users Like rami1976's post:8 users Like rami1976's post
  β€’ Dell_Brett, zrilek, Pitagora, simanta, jokerβ„’, bridgeengineer, mgdario, Arigato
 Pitagora
User ID: 20731
Given Likes: 99
03-17-2016, 04:02 PM
Thanks for Your upload.
I apologize for my insistence,
but the original Post refers for "Limcon 03.63.02.04" not "Limcon 03.63.01.11" as You posted Today.
Can You reload this release ?
Thanks in advance
[-] The following 1 user Likes Pitagora's post:1 user Likes Pitagora's post
  β€’ angelarias
 rami1976
User ID: 34597
Threads: 355
Given Likes: 1405
04-25-2016, 10:42 AM
Mirror of post 1:
[-] The following 9 users Like rami1976's post:9 users Like rami1976's post
  β€’ slowet, Dell_Brett, Albert, blaze, melekeen, Andrew seah, ykhackhack, MOSS2000, jacky899
 eng donny
Indonesia
User ID: 765
Threads: 19
Likes: 1,976 in 236 posts
Given Likes: 905
05-08-2016, 07:38 AM (This post was last modified: 02-27-2017, 10:19 PM by rami1976. Edit Reason: homepage was a link of a picture )
[Image: 86833554761322874408.jpg]
Quickly design and review your steel connections, such as beam to column, brace end, member splices, anchorage to concrete, complicated multi-member joints, and many more. Thanks to our library of international standard connection types, you save time and money by quickly designing connections and producing your CAD drawings all within one easy-to-use application. You can easily verify your connection results and quickly generate a concise design report summarizing all checks and connection statuses. -
[Image: tips.png]
Instructions: Unrar
Crack Included
[-] The following 10 users Like eng donny's post:10 users Like eng donny's post
  β€’ f_slikken, PinkPant, simanta, jaks, jacky899, harsono, Dell_Brett, hmwere, oanm2000, spat
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
#10
04-29-2017, 04:20 PM
Bentley Limcon 03.63.02.06 (Date: 2/16/2016)
[Image: 55886139150627189415.png]
copy and replace
No limits to creativity
[-] The following 26 users Like jokerβ„’'s post:26 users Like jokerβ„’'s post
  β€’ zrilek, slowet, pedzaquino, malc, Dell_Brett, hmwere, subin91, jcbv, Andrew seah, oanm2000, cristi, PinkPant, promo8, mowafi3m, monter, l_namali, jaks, febo927, caifan, harsono, rendel_Β©, Batman07, melekeen, rfireman, chenamoy, spat
Pages (2): 1 2 Next »
