Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] The relation between the shear strength of sand in triaxial compression plane strain
[Request] The relation between the shear strength of sand in triaxial compression plane strain
 StefanC
User ID: 13670
Threads: 2
Likes: 8 in 2 posts
Given Likes: 9
05-02-2014, 05:01 PM
Hello Everyone,
I need this article :
The relation between the shear strength of sand in triaxial compression plane strain and direct shear by P.W.Rowe
If someone has it please post a link for it.
Thank you !
 Mohammad6299
User ID: 42302
Threads: 251
Likes: 7,913 in 854 posts
Given Likes: 4212
05-02-2014, 06:58 PM
  • Article/eBook Full Name: The Relation Between the Shear Strength of Sands in Triaxial Compression, Plane Strain and Direct
  • Author(s): P. W. Rowe
  • Publish Date: 1969
  • DOI: 10.1680/geot.1969.19.1.75
  • Published By: Géotechnique, Volume 19, Issue 1
  • Related Links:
[-] The following 2 users Like Mohammad6299's post:2 users Like Mohammad6299's post
  • freequo, StefanC
 StefanC
User ID: 13670
Threads: 2
Likes: 8 in 2 posts
Given Likes: 9
05-03-2014, 08:33 AM
Found it here:
[-] The following 2 users Like StefanC's post:2 users Like StefanC's post
  • Mohammad6299, Dell_Brett
  [REQUEST] Effect of Rotation Rate on Field Vane Shear Strength tomcat007 0 1,607 06-27-2019, 01:03 PM
Last Post: tomcat007
  [REQUEST] How the strength properties of gravel soils depend on the type and state of the sand freequo 1 1,939 04-24-2013, 03:45 AM
  [REQUEST] Brief note on the influence of shape and percentage of gravel on the shear strength o freequo 1 1,784 04-22-2013, 11:23 AM
  [REQUEST] Shear Strength Estimation of Sandy Soils Using Shear Wave Velocity freequo 1 2,011 04-17-2013, 06:16 PM
Last Post: hich
  [REQUEST] Shear strength parameters from back-analysis of single slips pelelo 0 1,518 03-31-2013, 02:30 PM
Last Post: pelelo
  [REQUEST] An Empirical Ground-Motion Attenuation Relation for Inelastic Spectral Displacement erthqkengnr™ 0 1,503 02-11-2013, 06:44 PM
Last Post: erthqkengnr™
  [REQUEST] Corrections for Membrane Strength in the Triaxial Test tynhanh 2 2,579 01-26-2013, 06:07 PM
Last Post: kumar2010
