Civil Engineering Association eBooks Journals, Papers and Presentations Simple Method for Pushover Curves of Asymmetric Structure with Displacement-Dependent
04-09-2014, 06:01 PM
Simple Method for Pushover Cu rves of Asymmetric Structure with Displacement-Dependent Passive Energy Dissipation Devices
Author: Santiago Naranjo ; | Size: 450 KB | Format: PDF | Quality: Unspecified | pages: 19
[Image: 34058888687811299897.jpg]
This paper presents a simple method to calculate pushover curves for
asymmetric structure with displacement-dependent passive energy dissipation devices
(DDPEDDs). The method analyzes the deformation of a symmetric structure in
translation and in torsion. These results are then combined in order to calculate the
pushover curve for an asymmetric structure with DDPEDDs. The numerical results
obtained by using the simple analysis method are then compared to the results obtained
from the analysis of the models using the software SAP2000. The results show that the
simple analysis method can be an effective tool for engineering analysis.
๐Ÿ‘‰ CLICK HERE ๐Ÿ‘ˆ
  โ€ข rezart, malc, gulilero, ting tsai huang, cace-01, vardan, blaze, faros3000, ykhackhack
  The Extension Of The N2 Method To Asymmetric Buildings TAFATNEB 0 4,588 09-05-2014, 02:15 PM
  Target acceleration in multimodal pushover method for R/C frames TAFATNEB 0 4,209 04-09-2014, 06:28 PM
  A DISPLACEMENT-BASED ADAPTIVE PUSHOVER ALGORITHM FOR ASSESSMENT OF VERTICALLY IRREGUL TAFATNEB 0 3,986 04-09-2014, 05:51 PM
  USING PUSHOVER ANALYSIS METHOD IN SEISMIC ANALYSIS OF BRIDGES TAFATNEB 0 4,444 09-04-2013, 08:44 PM
  METHOD OF MODAL COMBINATIONS FOR PUSHOVER ANALYSIS OF BUILDINGS TAFATNEB 0 3,772 09-04-2013, 08:42 AM
  A simple image-based strain measurement method for measuring the strain ๏ฌelds in an R amritarao 0 4,009 02-22-2013, 04:39 PM
Last Post: amritarao
  IMPLEMENTATION OF THE DIRECT DISPLACEMENT-BASED DESIGN METHOD FOR SEISMIC DESIGN OF H Veggeta 3 8,340 09-22-2012, 03:40 PM
Last Post: ssobhan
