Civil Engineering Association eBooks Structural Books Concrete FIB 30: Acceptance of stay cable systems using prestressing steels
 Mohammad6299
User ID: 42302
Threads: 251
Likes: 7,913 in 854 posts
Given Likes: 4212
03-29-2014, 10:09 AM
Size: 3 MB | Format: PDF | Quality: Unspecified | Publisher: FIB - The International Federation for Structural Concrete (fédération internationale du béton) | Year: 2005 | Pages: 86 | ISBN: 9782883940703
[Image: 87193811650335608783.jpg]
This fib Recommendation gives technical guidelines regarding design, testing, acceptance, installation, qualification, inspection and maintenance of stay cable systems using prestressing steels (strands, wires or bars) as tensile elements, which can be applied internationally. This Recommendation is applicable for cable-stayed bridges and other suspended structures such as roofs. It may also be used for hangers in arch structures and as suspension cables, as appropriate.
This Recommendations has been formulated by an international working group comprising more than 20 experts from administrative authorities, universities, laboratories, owners, structural designers, suppliers of prestressing steels and stay cable suppliers. The text has been written to cover best construction practices around the world, and to provide material specifications that are considered to be the most advanced available at the time of preparing this text. For ease of use (for client, designer and cable supplier), the complex content has been arranged thematically according to the system components into chapters focusing on performance characteristics, requirements and acceptance criteria.
Requirements and comments have been specified for all parties involved in design and construction in order to aim for a uniform and high quality and durability. The interfaces to the structural designer are highlighted. The essential subjects are:
Design and detailing of stay cables including saddles and damping devices
Durability requirements and corrosion protection systems
Requirements for the materials
Testing requirements for the stay cables
Installation, tolerances, qualification of companies and personnel
Inspection, maintenance and repair.
This Recommendation does not cover the technology of stay cables whose tensile elements are ropes, locked-coil cables, etc. or which consist of composite materials. Nevertheless, in many cases the specified performance criteria may also be applicable to these systems, although numerical values given for the acceptance criteria may need to be adjusted. For these systems it has been difficult to provide multiple protective layers similar to those specified for stay cables made from prestressing steel and therefore, the quality of corrosion protection may not be equivalent. While extradosed cables have similarities with stay cables, generally agreed design and system acceptance criteria are not yet available and therefore, this type of cable is not covered.
[-] The following 5 users Like Mohammad6299's post:5 users Like Mohammad6299's post
  • malc, vardan, zrilek, faros3000, febo927
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
03-29-2014, 10:12 AM (This post was last modified: 03-29-2014, 10:22 AM by arshiakh.)
Size: 3 MB | Format: PDF | Quality: Unspecified | Year: 2005 | pages: 86 | ISBN: 9782883940703
[Image: 94553130446640390599.jpg]
[-] The following 8 users Like arshiakh's post:8 users Like arshiakh's post
  • blaze, metrox, lucky_b2me, zrilek, mgdario, ting tsai huang, Jackass, Andrew seah
  Acceptance Tests for Surface Characteristics of Steel Strands in Prestressed Concr mahyarov 0 1,582 10-23-2012, 06:14 PM
Last Post: mahyarov
  DYWIDAG Post-Tensioning Systems Multistrand Systems Bar Systems mowafi3m 0 1,913 02-02-2011, 07:16 PM
Last Post: mowafi3m
