Civil Engineering Association eBooks Structural Books Concrete Guide to the Construction of Reinforced Concrete in the Arabian Peninsula
 Jackass
Bolivia
User ID: 29460
Threads: 24
Likes: 1,138 in 115 posts
Given Likes: 7399
03-10-2012, 01:34 AM (This post was last modified: 03-25-2014, 09:38 AM by Dell_Brett.)
Author: M. Walker (Editor) | Size: 18 MB | Format: PDF | Quality: Scanner | Publisher: Concrete Society | Year: (1 Mar) 2002 | pages: 208 | ISBN: ISBN-10: 0946691932 ISBN-13: 978-0946691937
[Image: 32774809753002670588.jpg]
Outlines the principles underlying the successful use of concrete construction in the Arabian Peninsula. The extreme environment, and the geological and geomorphological conditions, are discussed in relation to these principles. Provides guidance on the materials available. Covers site operations and guidance on mix design. Also includes data on local climate and formwork pressures.
History Published in collaboration with CIRIA and is also known as CIRIA Publication C577. Edited by Mike Walker. Supersedes Special Publication 31, 'Guide to concrete construction in the Gulf region' (1984).
[Image: comments.png]
Only For Civilea Team
[-] The following 19 users Like Jackass's post:19 users Like Jackass's post
  â€¢ kowheng, Mouh@ndiss, malc, 3fan, ssi3k, Dell_Brett, zrilek, eliseo.as, jaejeong, tang1942, pezhmankhan, bigone, ashcivilea, ssobhan, krasheed, oanm2000, tuanpecc1, riesen, wangyipeng1130
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 38
Likes: 4,964 in 638 posts
Given Likes: 3501
03-25-2014, 04:37 AM
This title provides those working with reinforced concrete in the Arabian Peninsula with information and guidance on the production of high-quality, durable concrete, able to withstand the region's extremely harsh environment. Much of the guidance is also applicable to concrete construction in other hot-wet and hot-dry environments around the world. The principles set out in the Guide are applicable for the whole range of construction activity, from small-scale building works to large civil engineering projects. The Guide is in four parts. The first outlines the principles underlying the successful use of concrete construction in the Arabian Peninsula. The extreme environment and the geological and geomorphological conditions are discussed in detail. The second part provides a comprehensive guide to the materials available. Execution of concrete works is covered in the third part, while the final part presents guidance on mix design. Appendices provide data on local climate and on formwork pressures. A detailed subject is included. The book was prepared by a working party as part of a collaborative project between CIRIA and The Concrete Society, working with authorities and organisations based in Arabia.
*@mod: there are some mistakes in the TS. Please replace the description with those in this post. TQ.
concrete solution advocate
[-] The following 15 users Like concreteok's post:15 users Like concreteok's post
  â€¢ Mohammad6299, vardan, viet2010, arshiakh, andersen3, pezhmankhan, blaze, bigone, Dell_Brett, ykhackhack, zrilek, gulilero, knrsa, ashcivilea, TurboXUser
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
05-24-2014, 10:12 AM
Size: 18.3 MB | Format: PDF | Quality: Unspecified
[-] The following 6 users Like arshiakh's post:6 users Like arshiakh's post
  â€¢ Mohammad6299, blaze, araza023, bigone, malc, Trishu999
 Jackass
Bolivia
User ID: 29460
Threads: 24
Given Likes: 7399
08-15-2016, 11:53 AM
[align][align=left]
  • Quality: Unspecified
[-] The following 11 users Like Jackass's post:11 users Like Jackass's post
  â€¢ jaks, PinkPant, er.shyams, highcivil, oanm2000, Dell_Brett, Wijono, Aviator, TurboXUser, vinnunsam, dinu69in
 cace-01
User ID: 15651
Threads: 433
Likes: 10,522 in 867 posts
Given Likes: 7468
03-04-2019, 07:00 AM
Corrected Link of post #5
[-] The following 10 users Like cace-01's post:10 users Like cace-01's post
  â€¢ concreteok, melekeen, PinkPant, hatkam, oanm2000, Dell_Brett, er.shyams, tuanpecc1, Nita1391, moh_towhid
  Guide to concrete construction-2nd edi civilfafa 0 3,217 05-04-2024, 12:25 AM
Last Post: civilfafa
  Design Guide for Reinforced Concrete Diaphragms A guide to assist design professional sabooryan 2 2,609 02-10-2020, 03:15 PM
  Design Guide for Economical Reinforced Concrete Structures 2016 A guide to assist des sabooryan 1 2,294 01-11-2020, 08:53 AM
  Tilt-up Concrete Buildings: Design and Construction Guide ir_71 1 2,974 05-21-2019, 06:56 AM
  Blast Resistant Design Guide for Reinforced Concrete Structures Nita1391 2 2,817 05-01-2019, 02:34 AM
  Ciria - Guide to the Reinforced Construction of Reinforced Concrete in the Arabian Pe Jackass 1 3,990 02-23-2019, 11:34 AM
Last Post: Icivilea
  Guide to the design and construction of reinforced concrete flat slabs gulilero 3 3,879 04-14-2018, 09:08 AM
Last Post: gianniorlati
